Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-12-2016, 03:36 PM | #1 |
Ohne Titel
Drives: 2017 BRZ PP ISM
GCS Automatic Paddle Shifter Extensions
Has anyone tried the GCS paddle shifter extensions for AT cars? I was eyeballing these on eBay for a while at $60 shipped.
Now they're available in the U.S. for $34.99 + shipping. http://www.ft86speedfactory.com/gcs-...er-xt-cvt.html Install looks super simple with an allen key setup. My only worry is that they may scratch the paddle shifters. Anyone have these? |
02-13-2016, 02:18 PM | #2 |
Drives: 2013 Firestorm FRS
sub'd
02-14-2016, 01:19 PM | #3 |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
A buddy of mine in Taiwan had a few friends get these and they were pissed that the set screws damaged the factory paddles. The set screws are really small diameter and in order to apply sufficient force to retain the aluminum extensions, the pressure is more than the factory plastic can sustain without permanent deformation. In addition, since the OEM plastic isn't exactly the stiffest material in the world, the set screws will eventually rip through it.
While these look kinda cool, I'm not a big fan of touching scalding hot metal in the middle of summer. I generally keep my fingers on the paddles while I'm driving and this would be rather painful when the interior is at 150+ degrees after sitting in the sun all day. |
The Following User Says Thank You to Sithspawn For This Useful Post: | TofuJoe (02-14-2016) |
02-14-2016, 01:59 PM | #4 |
Ohne Titel
@Sithspawn - thanks. I was worried the screws might ding up the paddles. Maybe I'll just shell out the $86 for the Stark extensions instead.
02-14-2016, 04:24 PM | #5 |
Drives: 14' firestorm
Those seem like easy pieces to 3D print. I'm willing to bet with a little bit of work you could make some that snap into place.
02-14-2016, 04:47 PM | #6 |
Drives: 2014 whiteout, scion fr-s
i bought some, ill let u guys know how they feel when they arrive
02-14-2016, 05:58 PM | #7 |
Drives: 2013 Subaru BRZ
I've got some and yes they do damage the standard paddles with those allen key screws I wish I had used 3M to stick them on instead
The Following User Says Thank You to Tareim For This Useful Post: | TofuJoe (02-14-2016) |
02-14-2016, 07:34 PM | #8 |
Drives: 2015 Ultramarine FR-S AT
+ 1 for the Stark shifters
The Following User Says Thank You to Kestrel For This Useful Post: | Stark Performance (02-14-2016) |
02-14-2016, 08:42 PM | #9 | |
Drives: Subaru BRZ Limited M/T
Just to let you guys know, I had the Stark paddles on my 13 AT and when the interior gets to that ~150' mark the glue "softens" and they do come off. I ended up using Gorilla glue to keep them. This is my experience with these paddles and no one else's. I liked them very much. Sent from my iPhone using Tapatalk |
02-15-2016, 10:24 AM | #10 |
Member of the year - 2016
Drives: Scion FRS
I can't get these paddles to stay on. They eventually just come off when you press on them too low. Not only do i have useless paddle extensions but also two damaged paddle shifters.
02-15-2016, 01:17 PM | #11 | ||
just thinking of ways I can over the front face to hide the damaged paddles whilst still looking ok |
02-15-2016, 01:41 PM | #12 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
+1 for stark I love them.
The Following User Says Thank You to go_a_way1 For This Useful Post: | Stark Performance (02-15-2016) |
02-15-2016, 02:59 PM | #13 |
Ohne Titel
@FT-86 SpeedFactory - are you concerned about selling this product that may damage people's shifters?
02-15-2016, 03:19 PM | #14 | |
Drives: 2014 FR-S
Thanks, -Mike |
The Following User Says Thank You to Stark Performance For This Useful Post: | Ammunition (11-24-2016) |
Similar Threads | ||||
Stark Performance Paddle Shifter Extensions | Stark Performance | Interior Parts (Incl. Lighting) | 44 | 08-24-2017 02:26 PM |
Stark Performance Paddle Shifter Extensions | Stark Performance | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 02-27-2016 05:25 PM |
DIY: Installing Stark Performance Shift Paddle Extensions for the A/T FRS/BRZ | continuecrushing | DIY (Do-It-Yourself) Guides | 19 | 02-23-2016 10:04 PM |
AT Paddle Shift Extensions look pretty sick | continuecrushing | Cosmetic Modification (Interior/Exterior/Lighting) | 44 | 04-02-2015 02:08 AM |
Stark Performance Paddle Shifter Extensions Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 12-02-2014 08:58 PM |
