Old 02-14-2016, 12:48 PM   #15
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
There probably is one someplace yes. I only bring it up as a possible not as a given. I would hope that the ECU would prevent any issues and under normal driving it would almost be guaranteed that it would. Hard driving on the other hand could be a bit of a gamble to trust that it would all the time. They require high octane for a reason and I don't think I would want to trust the ECU to protect my engine for a prolonged period. That isn't even taking the retarded timing and resulting loss of power into the equation.
Touché. That's a reasonable way of putting it.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
The Following User Says Thank You to olsonpg For This Useful Post:
Tcoat (02-14-2016)
Old 02-14-2016, 01:22 PM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by mdm View Post
Doesn't it actually pull back the engine AFTER it detects knock? In other words, there some knock must happen before the ECU adjusts the engine, so it only can prevent more knock?
Originally Posted by olsonpg View Post
Your engine control unit adapts to the changes of octane running through the engine. I honestly have made 4000 mile road trips in the car on 87 and when i get back home i put 93/91 one back into it and its fine and over 80,000 miles of 87 into a supercharged mercedes that called for nothing but 91/93 and never had a problem.
I have heard from many engine mechanics that 87 has absolutely NO lasting negative effects on the engine besides temporary reduction of power and torque while it's in the tank.
But there are a lot of guys on here think its a cardinal sin and a slow death of the 86 to put 87 into the tank.
Would absolutely love it if some professionals in the field could clear the air when it comes to this.
Isn't there a sticker inside the fulel filler door that says PREMIUM unleaded fuel only?
Long term there could definitely be ill effects, the IAM (ignition advance multiplier) should be at 0.7-1 on 91 or 93, it must drop well below that in order to counter the knock and sometimes that doesn't even work. It can only detect and change that when the knock occurs as well. At that point you're increasing the probability of pre-detonation because the ECU can only adjust so much after a knock occurs.
The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
mdm (02-14-2016), olsonpg (02-14-2016), Tcoat (02-14-2016), YXEBears (02-14-2016)
Old 02-14-2016, 01:29 PM   #17
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Once the engine is warmed up it doesn't matter if it is 50 or minus 50 out. It will run exactly the same. Was minus 12 here yesterday and mine ran the same as it does in August once it warmed up. Now the interior creaks, clicks, squeaks and rattles you get at that temperate are a whole different matter.
Ambient temp is one of the variables the ECU uses to determine several engine parameters, including A/F ratio. The engine definitely runs richer at lower ambient temps.
billwot is offline   Reply With Quote
The Following 2 Users Say Thank You to billwot For This Useful Post:
FRSBRZGT86FAN (02-14-2016), Tcoat (02-14-2016)
Old 02-14-2016, 01:59 PM   #18
olsonpg
olsonpg's Avatar
Thanks for that good info!
Old 06-01-2016, 12:29 AM   #19
-Willis-86touge
Drives: Stock
I was having some off the same issues but also seemed as if the handing was off too. And I know this seems crazy but I check my rev limiter setting and it was set at (--00) wtf?!? Yea that's right it like it was set at all so I set it and turned on the shift light and trans number display and now she runs like the day I got her. Crazy huh!! Also she steers so much better?!? Don't know why but check it just in case maybe it's a programming problem?
-Willis-86touge is offline   Reply With Quote
How Much slower is current F1 Joakim3 Other Vehicles & General Automotive Discussions 21 12-03-2015 02:07 PM
Is this normal? BlackyRose Engine, Exhaust, Transmission 8 10-04-2013 12:54 PM
Passenger/Right Rear-View Mirror Slower then... SPEEDGOD Issues | Warranty | Recalls / TSB 3 07-30-2013 11:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 03:54 PM
AT officially 1 sec slower than MT at Tsukuba madfast Engine, Exhaust, Transmission 42 05-22-2012 05:24 AM
