Old 11-20-2013, 09:19 AM   #57
nalc
Drives: 13 BRZ Limited 6MT GBS
Originally Posted by kakarot1657 View Post
This is a concept I'm think of.
now it's just figuring out what components I can use with the space provided. But really it's just a idea nothing more lol
I had given some thought to this as well, I think the way to go would be a D-Pad, maybe salvaged from an old video game controller. Use up/down for volume, left/right for seek, and if there's a center button, use that for mode. It should be compact and ergonomic.
Remember, what the head unit is looking for is just shorting out two pins with a resistor. It's going to be much easier with a discrete on/off switch than using a potentiometer or an analog joystick or anything like that that has variable resistance. You'll need some intermediate circuitry to turn that into the type of signal that the HU is looking for. I'm not an electronics guy and I really don't know what you'd need to do to make that conversion, so I'd lean towards simple switches and resistors.
nalc is offline   Reply With Quote
The Following User Says Thank You to nalc For This Useful Post:
kakarot1657 (11-20-2013)
Old 02-11-2016, 04:43 AM   #58
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
@foglesre @nalc
so basically you are just bridging the poles with the correct resistors (or just a wire in case of 0 ohms) if I'm reading this all correctly.
the part that confuses me is how i connect 21/23 for my volume/seek and do 1 without a backfeed or am i wrong for thinking of this in terms of normal power/ground?
also how do i connect pin 21/23 to 6 poles per switch? just solder it off into branches? so that 1 wire becomes 3 (in the case of a single switch)?
lbroskee is offline   Reply With Quote
nalc's BRZ steering wheel audio control saga nalc Electronics | Audio | NAV | Infotainment 69 12-20-2016 11:07 PM
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 04:00 PM
need help on jpm center console Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2013 08:57 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 10:56 AM
Center Console encity5 Electronics | Audio | NAV | Infotainment 1 06-10-2012 10:22 AM
