View Poll Results: Should I run Nitrous
Yes 29 47.54%
No 11 18.03%
Popcorn, cuz dis gon b gub 28 45.90%
Multiple Choice Poll. Voters: 61. You may not vote on this poll
go_a_way1, MisterSheep
Old 02-09-2016, 09:48 AM   #15
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Yeah I wonder how many seconds I can get with a 15lb bottle. Do you think a bottle warmer is a good initial investment or should I wait and see if I need it? I cant wait to blow the welds on my intake manifold..... oh wait its plastic hahaha I win!
I would suggest getting a bottle heater from the get go. In my experience, I needed it to get a consistent steady shot. If it was too cold it was weak. You need the bottle blanket with a regulator so that it heats it to what PSI you need, but it won't let it get too hot.
Without the blanket I never had it get too hot, it would just be consistently too cold.
10 lb bottle was good for about 5-6 1/4 mile passes using 75-100 shot with good pressure. All depends on how good the guy you buy from is.
Also, it isn't NOS....
The Following User Says Thank You to Summerwolf For This Useful Post:
go_a_way1 (02-09-2016)
Old 02-09-2016, 09:54 AM   #16
Ashikabi
Ashikabi's Avatar
You should get 2 of the big ones!
I'm actually kinda curious about the usage myself... when do you spray it? How long does it last?
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 02-09-2016, 09:56 AM   #17
SoundsOfTheUniverse
Sideways
Drives: '13 & '15 Asphalt FR-S
If you do happen to run 100 shot of nitrous, make sure not to granny shift and double-clutch like you should.
SoundsOfTheUniverse is offline   Reply With Quote
The Following 2 Users Say Thank You to SoundsOfTheUniverse For This Useful Post:
go_a_way1 (02-09-2016), zberz (02-13-2016)
Old 02-09-2016, 10:45 AM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Depends on jetting and bottle size. If I go this way I will beable to do lots of tests
Awesome Thanks for the input, I hate the extra cost but I am the do it right or GTFO kinda guy
Without the blanket I never had it get too hot, it would just be consistently too cold. did yours ever get too hot?
Did you spray the whole way down the 1/4mile?
LOL I know, thats why I have been calling it nitrous, but these other guys LMAO
Love it. Was waiting for all the FF jokes I drive an auto (its a DD so we can debate about that in another thread) The advantage here is I will not need a clutch or worry about it slipping. Also the taller gear ratio will work in my favor if I decide to spray
SoundsOfTheUniverse (02-09-2016)
Old 02-09-2016, 10:49 AM   #19
Ashikabi
Ashikabi's Avatar
Why not a 200 shot? Or 1000
Old 02-09-2016, 10:51 AM   #20
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
It would definitely be interesting to see I'll give you that.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
Old 02-09-2016, 10:57 AM   #21
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
You spray it to edge out the competition just about 1/3rd way from the line your neck and neck. PSSSST bye..instant boost!
RichardsFRS is offline   Reply With Quote
Old 02-09-2016, 11:02 AM   #22
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
go_a_way1 (02-09-2016), soulreapersteve (02-09-2016)
Old 02-09-2016, 11:03 AM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
The vehicle I had it on, I would launch in first without it and it came on about halfway through 2nd gear. Basically the vehicle had enough torque in 1st and 2nd and it would blow the tires off if I didn't do it that way. I never ran drag radials or slicks on it either so that didn't help...From 2nd on it was on, would hit the top of 4th crossing the traps.
Also, if you're doing this....invest in a purge kit. Otherwise you will sometimes have a momentary hiccup after the nitrous comes on while the lines completely fill.
Basically, to do this right....you're spending as much as some "all the time" "true" FI options, lol.
No, my bottle never got too hot. I didn't generally leave the bottle in the vehicle unless I knew I was going to do some type of racing. Even still I had it parked in Texas heat for long periods of time without issue. It would take some very odd circumstances to get too hot as to have the bottle build enough pressure to explode or something.
Even if that happens you'll have a blow down tube and pressure release disk as safety features.
Old 02-09-2016, 11:26 AM   #24
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
The vehicle I had it on, I would launch in first without it and it came on about halfway through 2nd gear. Basically the vehicle had enough torque in 1st and 2nd and it would blow the tires off if I didn't do it that way. I never ran drag radials or slicks on it either so that didn't help...From 2nd on it was on, would hit the top of 4th crossing the traps. Neat, Thanks for the input
Also, if you're doing this....invest in a purge kit. Otherwise you will sometimes have a momentary hiccup after the nitrous comes on while the lines completely fill. I was planning on getting a purge kit. I still haven't decided it I am going to purge in the engine bay (no one will see it) or onto the windshield through the cowl, or I might cut a hole in those fake vents and purge out the passenger side fake vent for a little extra "effect" hahaha!
Basically, to do this right....you're spending as much as some "all the time" "true" FI options, lol. Yup, but I feel this will put less stress on my car in the long run if I don't use it much.
No, my bottle never got too hot. I didn't generally leave the bottle in the vehicle unless I knew I was going to do some type of racing. Even still I had it parked in Texas heat for long periods of time without issue. It would take some very odd circumstances to get too hot as to have the bottle build enough pressure to explode or something.Okay good, I was worried these would be super temperature sensitive haha. I am still on the fence about storing the bottle in the car as it is a DD.
Another question, where in the FRS do you think I should mount the bottle? I am open to all options. I was thinking under the glove box in the passenger footwell would be a neat place for it. I think that way I can avoid having to buy a $500 mount (waste of money IMO I can build one cheaper lol)
Old 02-09-2016, 11:29 AM   #25
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Go for it just be careful not to blow the welds on your intake.
Instagram: trevor.parque
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
go_a_way1 (02-09-2016), soulreapersteve (02-09-2016), SoundsOfTheUniverse (02-09-2016)
Old 02-09-2016, 11:29 AM   #26
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I would fry my piston rings and blow the welds on my intake dhu?
Thanks! I think alot of people would be interested in following this so part of the reason is to do it for the community
LOL a 15lb bottle will last alot more then 1 run, but when it does run out
Old 02-09-2016, 11:31 AM   #27
Summerwolf
Panda Trueno
Summerwolf's Avatar
I don't see how you would effectively mount a 10 lb + bottle with a blow down tube there. The only "logical" place would be the spare wheel well to me. You have to drill a hole through the body for the blow down, and with the wiring for the heater and everything you want some space around the bottle. Plus the wiring and lines and everything are not attractive per se.
The purge, you ideally want it where YOU can see it so you know you have a good purge, out the cowl or out the side vent would be ideal...just in the engine bay, probably not.
The stress / cost comment.... I'm not sure. You can have a stress related failure no matter what. You just have to make sure you're doing it as safe as possible. A 50 shot really isn't that much though, lol.
Old 02-09-2016, 11:31 AM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
You will need to tub out the car and put on Mickey Thompson tires on 12" W wheels to hook up. Sounds like a plan if you want to start drag racing, which these cars were not designed for.
So, no.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
go_a_way1 (02-09-2016), Summerwolf (02-09-2016)
Nitrous Express, Nitrous Plate mrk1 Engine, Exhaust, Bolt-Ons 5 09-06-2017 11:37 PM
Nitrous setup Subaru86 Engine, Exhaust, Transmission 6 08-03-2015 02:54 AM
Nitrous build dallenj Forced Induction 34 08-01-2015 04:27 AM
nitrous? ender2664 Forced Induction 48 06-13-2015 11:36 PM
nitrous eindio Forced Induction 17 09-22-2012 02:09 AM
