#4019 | |
Drives: 2013 Scion FR-S - Raven
You can buy these on ebay from dealer store fronts for cheap
#4020 |
Drives: '13 FRS - STX
Mix and match, try both, try just changing the front and just changing the rear, if you have the opportunity to verify what's the best setup for you instead of just following what the internet tells you to do then absolutely do it.
And hey, if you end up finding out that contrary to popular opinion you like TRD rear, OE front then you can make back a decent amount of money selling the front to someone who doesn't want to put the effort into testing it. |
#4021 |
Drives: '15 Scion FR-S
I was planning to run with the TRD springs a hotchkis front sway, 245 71R' and possibly this TRD rear sway. I'm going to have to do some research and see what these TRD sways are like. I don't like the fact theirs no adjustment...
#4022 |
Drives: Scion FR-S
I just picked up the TRD set. I'm going to do a bit of testing. I have the strano front/stock rear now. I'm going to (one at a time) test out different combinations to see if I get a better feel out of a new setup. I never go solely on what others might tell me what works. See for yourself. Plus everyone's driving style is a bit different. What works for one might not work for another.
| The Following User Says Thank You to Gearhd79 For This Useful Post: | strat61caster (02-07-2016) |
#4023 |
The Stig's German cousin
This was almost exactly my setup, Hotchkis front and TRD rear, except I had BFGs. The rear bar is a game changer. You won't wanna take it off after you try it.
#4024 |
I'm going to do some hunting around to see if I can find just the rear, if not I'll end up with the set and have a nice powder coated fire poker.
#4025 | |
Im debating which route to go here, I know there's tons of discussion it's just hard to come up with a verdict. In my region there are no CS competitors. All the twins are in STX. If I get my setup right hopefully I can out-pax a few of them. Our courses tend to be pretty tight, rarely do we ever need to grab 3rd so the shorter sidewalls is likely the better route. Last year I ran 235/45 R-S3' they were used when I got them and heat-cycled pretty bad. The pinch wasn't bad though and they were fairly responsive. If I still need to put the time in to get my driving style up to 10/10, would you recommend going with the 225 over the 245 to get a better feel? Thanks |
#4026 | |
FYI CS winner at nats last year ran 225s, so you *can* get it done on those. They're also cheaper. If you are still learning, nothing beats seat time and that means your tire budget goes up. If you run Prosolos the 245 advantage gets big due to the drag start. In Lincoln at spring nats and at the finale I consistently cut 2.1-2.2 60' times. The only ones faster than me were the MR2 (1.9 or lower! That mid engine is helpful) and the NC Miata with cushy springs and fancy DA shocks (they were more consistent about 2.1 than I was). |
#4027 |
Drives: 2015 FR-S
I just ordered 235/45 RE71-R's. Went with the taller tires to get a little better top end.
#4028 |
Drives: Scion FR-S
I always thought the magic size for street was 225 45. That all I've run the last 4 seasons. Has anyone had any real results from other sizes ?
#4029 |
Drives: Yes
I've run every possible relevant 17" size in the past few years. It depends on the tire and the lots you run (if you need gearing). The BfG 245s worked well on renfield90's car even though I didn't love their "feel." I regularly run 225 re71r now, but I'm probably going to try the rival s in 225 a bit this year.
#4030 |
Drives: C-Street FR-S
renfield90, did you run the Hotchkis bar on the Hard or soft setting? did that feel a more loose like stock or more neutral to understeer prone off throttle?
#4031 |
I started on hard but went to soft not long after I got Konis and stayed there for nats. The soft setting is still pretty damn stiff. It was fairly neutral off throttle, pushy on throttle. But I could go WOT whenever I wanted without spinning, and it was a total monster through slaloms.
| The Following User Says Thank You to renfield90 For This Useful Post: | drewbot (02-24-2016) |
#4032 | |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
