Old 02-04-2016, 02:31 PM   #1
D_Thissen
D_Thissen's Avatar
What is this sound?
Hey everyone. Been trying to diagnose this sound for a while. It sounds like a popping or binding sound in the front left of the car. I'm lowered on RCE yellows with whiteline camber bolts. Dealership as well as a local Subaru shop (who removed the strut assembly and spring and reinstalled it) couldn't find the source of the problem. I'll upload a video here in a second.
Thanks in advance
Dan
Sent from my Nexus 6P using Tapatalk
Old 02-04-2016, 02:52 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks in advance
Dan
isnt that normal for aftermarket springs to do once in a while?
Old 02-04-2016, 02:55 PM   #3
D_Thissen
D_Thissen's Avatar
Not sure man. It started about 5000km after the car was lowered and will make that noise 9/10 times when I'm at low speed. It doesn't make that noise when there car is off the ground though, so I'm wondering if the endlinks are too long and causing the sway bar to bind on something??
Old 02-04-2016, 02:57 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
That could be possible? I would wonder if the spring is rotating on the perch because that will make a poping/binding noise
Old 02-04-2016, 03:03 PM   #5
D_Thissen
D_Thissen's Avatar
That's what I thought too. I took it into a shop and they took the spring off and reinstalled it and torqued everything down to spec so it shouldn't be rotating. I hate hunting down noises lol
Old 02-04-2016, 03:04 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
me too haha!! I don't have any other ideas so good luck finding it
Old 02-04-2016, 03:05 PM   #7
D_Thissen
D_Thissen's Avatar
Well... Some help you are
Lol thanks anyways man
The Following User Says Thank You to D_Thissen For This Useful Post:
go_a_way1 (02-04-2016)
Old 02-04-2016, 03:06 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
LOL I tried, my only guess would be spring binding if everything is torqued to spec
D_Thissen (02-04-2016)
Old 02-04-2016, 10:57 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Welcome to the joys of owning a car with front MacPherson strut suspension.
-alex
Old 02-04-2016, 11:04 PM   #10
frslee
Just drive it
Drives: 13' FR-S
Take some time this weekend to disassemble front strut and see what's causing the noise. Before taking off the part, mark the camber bolt so you can put it back to where it was.
frslee is offline   Reply With Quote
Old 02-04-2016, 11:07 PM   #11
D_Thissen
D_Thissen's Avatar
Already tore it apart and re assembled. No play in anything. Can't rotate the spring on the strut either.
Old 02-04-2016, 11:08 PM   #12
D_Thissen
D_Thissen's Avatar
-alex
Lol yeah I think it's something I might have to live with. What are the odd that the end links are too long ?
Old 02-04-2016, 11:09 PM   #13
mav1178
mav1178's Avatar
Zero.
Endlinks being long just means you may bind at full lock or compression or both. Only a problem because it causes steering lock.
-alex
Old 02-04-2016, 11:14 PM   #14
D_Thissen
D_Thissen's Avatar
Zero.
-alex
Right on. Well I'm not overly worried about it yet, just more of an annoyance.
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 11:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 07:03 PM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 11:34 AM
