Old 02-02-2016, 12:46 PM   #295
Teseo
Drives: frs
Anyone tried double oil cooler? Like RX8
Old 02-02-2016, 12:49 PM   #296
ajc209
Drives: GT86 Cosworth
Another Cosworth SC owner to add to the list:
BRZUK
http://www.ft86club.com/forums/showthread.php?t=91641
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (02-02-2016)
Old 02-02-2016, 02:15 PM   #297
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Added them to our long proud list!
MS, CSCS, TSAC-F, CPT
Old 02-02-2016, 02:21 PM   #298
ajc209
There's a few more on the UK forum but I dont think they have profiles on this club.
Old 02-02-2016, 06:40 PM   #299
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
Originally Posted by Matt@Cosworth View Post
I like your belt cover very swish, who makes that?
also with regard to the high intake temps I note that on your image of the installation I can see some sort of spacer block under the temperature / pressure sensor on the manifold?
the bead needs to be in the airstream to function properly otherwise you'll get a false reading?
Hi Matt, the Belt cover is the Carbign Craft Carbon fibre cover, trimmed down to fit. In order for me to be legal on the street, it is a requirement for my charger pulley and belt to be covered, so this seemed like the best option. The stock A/C and alternator covers sit underneath it.
As for the alloy sandwich, my boost gauge is running off that. It does not seem to make any difference to my readings whether installed or not, as that was my first thought as well.( I'll pull it off again just to double check and be sure)
Yesterday was 37C with 98 percent humidity and today is shaping up to be about the same. Giving the front exchanger a mist with a spray bottle will make the temps drop rapidly, so everything appears normal. I live on the Gold Coast, and we are in the height of Summer here, so I think it may just be a case of climate ?
muckypuppy is offline   Reply With Quote
Old 02-03-2016, 03:17 AM   #300
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
thanks for the information
thats pretty hot and humid
so its good to hear the kit is still holding up well with 12 degrees over ambient in these conditions?
Matt@Cosworth is offline   Reply With Quote
Old 02-03-2016, 04:21 AM   #301
muckypuppy
Yep, seems fine. I took it to my tuner who not only specialise in supercharger installations but are a big name in Australian Motorsport and they said is normal. I pulled the spacer today and still ran 12C over ambient (34C) just taking it easy. I do have the Perrin cooler up front so that may be a factor as well, but I think the proper solution to my intake temps is most likely going to be venting the bonnet for heat extraction. Seriously considering the Trackspec vents.
Old 02-03-2016, 05:00 AM   #302
Matt@Cosworth
I'd agree that some bonnet vents on the leading edge would help considerably
only thing to consider is any rain running through a vent and onto electrics
as while most auto electrics are splash proof they're not water tight
The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (02-03-2016), CounterSpace Garage (02-03-2016), muckypuppy (02-03-2016)
Old 02-04-2016, 04:47 PM   #303
JerryIII
Drives: Subaru BRZ
It happened again WTF ?[IMG][/IMG]
And the coating didn't last on the header[IMG][/IMG]
JerryIII is offline   Reply With Quote
Old 02-04-2016, 05:09 PM   #304
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Are there flex points in that exhaust? Usually when it keeps cracking like that, it's because the engine is moving like normal during accel/decel, but there is not enough flexibility in the exhaust to accommodate that movement, and it end up cracking.
I think the coating flaking off is pretty normal for the really hot spots on the exhaust, and it's just a layer that flakes away. The rest should stay and function somewhat. This is why I prefer wraps though.
killboy is offline   Reply With Quote
Old 02-04-2016, 05:56 PM   #305
weederr33
weederr33's Avatar
Considering it's supposed to have a total of 4 layers of coating, I think you'll be fine. Besides, it would flake anyway after a few thousand miles or plenty of hard driving.
Old 02-06-2016, 04:24 AM   #306
Matt@Cosworth
Jerry
I've forwarded these images to Nameless and I'm awaiting their feedback
Old 02-07-2016, 07:56 PM   #307
JerryIII
Drives: Subaru BRZ
Jerry
I have already talked with them, a new one is on the way.
Old 02-08-2016, 04:43 AM   #308
ajc209
Did they give any idea why that silencer weld failed twice? Is it in the same spot? Bad batch?
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
