VizMark Performance
Drives: 2014 Scion FR-S Monogram Series 6MT
Traction control not working properly/ malfunction
I have a 2014 FR-S Monogram Series 6MT. Three days ago the car stopped letting me turn the traction control off. When I hold down the track off button for more than 5 sec staying still or moving the only thing that comes on is the track off light but not the other light. This is the same with vsc sport mode. I noticed that last night I was able to activate it until the car was completely warmed up and then while I was driving it just turned itself off and wouldn't turn back on. I was just driving down the road at normal speeds. I tried the peddle dance and the same thing happened, just the track off light and not the other. Any idea guys?????
PS: I know "Traction" is misspelled in the thread title. I don't know how to change it.
Regards,
Jeff Gray 904-566-5505 VizMark Performance Last edited by Jeff Gray; 01-29-2016 at 12:55 PM. |
#2 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Reset battery. May work.
Maybe fuses? Lose wiring?
| The Following User Says Thank You to Packofcrows For This Useful Post: | humfrz (01-29-2016) |
#3 |
VizMark Performance
Traction controle not working properly/ malfunction
Regards,
Jeff Gray 904-566-5505 VizMark Performance |
#4 |
VizMark Performance
I was thinking that except it will turn off when the engine isn't fully warmed up
Regards,
#5 |
Drives: Full race 4cyl boxer
Maybe the dash bulb is just burned out?
#6 |
Drives: 2014 Monogram FR-S
just to be sure we're covering everything, normally the TRAC OFF thing comes back on after like 25-30mph, unless you're totally stopped and hold the button down.
I think you should do as others have instructed, maybe disconnect battery, make sure you do it when car is stopped and in neutral, etc. |
#7 | |
VizMark Performance
Regards,
#8 |
Yikes, yea then I don't know man
#9 |
#10 | |
If you press the button on the right (VSC Sport), then the car logo with the squiglies underneath comes on, and the VSC Sport lights comes on. if you're stopped and HOLD the button on the left, then the TRAC OFF and logo withe squiglies will both come on and now that's all your traction control systems off that is a terrible way to explain it, but pretty sure i'm accurate. (i don't have pics to help illustrate what's what) |
#11 | |
#12 |
Drives: 2016 Raven FR-S
Have you "tested" to see if traction control is full off and may be a lighting issue?
Sent from my SM-G900P using Tapatalk |
#13 | |
FT86
Drives: 2015 FRS Ultramarine
2015 FRS Ultramarine 8/20/15
TRD Exhaust System | Suntek | Opti - Coat | K&N D.I.F Future mods: Vortech or Fullblown! Need to more then read some more. |
#14 |
Dude! You have the same thing in two threads?
http://www.ft86club.com/forums/showthread.php?t=100720
| Tags |
| malfunction, traction control |
| Cruise control malfunction | totally | Issues | Warranty | Recalls / TSB | 20 | 02-26-2018 10:13 PM |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| Cruise Control Malfunction | Wyattkb | Issues | Warranty | Recalls / TSB | 6 | 12-21-2014 05:37 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
