Old 01-15-2016, 07:32 PM   #1
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Ground Control Camber Plates
FOR SALE: $300 including shipping
I purchased these Ground Control camber plates in Oct 2015 from a good friend who originally bought them in Dec 2014. I actually bought them before I purchased my BRZ recently. I won't be putting coilovers on the car anytime soon so I need a different setup. These won't work with stock shocks unless you have a coilover conversion kit, which Ground Control also sells.
If you look closely at the pictures, you'll notice they have a very handy modification with a thru bolt / set screw setup that keeps the bearing from suddenly moving when loosened and doing an alignment. This allows you to fine tune the camber setting easily.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline
Old 01-25-2016, 10:32 PM   #2
jmimac351
jmimac351's Avatar
2015 Subaru BRZ
Old 01-30-2016, 09:44 PM   #3
xxGiXxeRxx
Drives: 2014 FRS
Will this work with a KW V3 coilover? And does this let you adjust caster too?
xxGiXxeRxx is offline
Old 01-30-2016, 10:44 PM   #4
jmimac351
jmimac351's Avatar
These were used on a car with Racecomp Tarmac 2 coilovers, which are based on the KW Clubsport coilover. I'm not an expert on these different fitments but "I think" they will work on your KW shocks. When you order these from Ground Control you select KW shock and 2.5" spring. Assuming you have 2.5" springs on your KW's, I don't see why they won't. It wouldn't hurt to call KW to make sure.
You can adjust camber and caster.
See the picture below and check your spring size.
2015 Subaru BRZ
Old 01-31-2016, 01:22 PM   #5
Robbie
In the slipstream
You'd need the 60 mm perch, which you could buy from GC. They adjust caster and camber.
Robbie is offline
Old 02-02-2016, 12:02 PM   #6
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
Are these compatible with st's
tumbla.jr is offline
Old 02-02-2016, 09:19 PM   #7
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
PM'D
killerkid08 is offline
Old 02-03-2016, 08:53 PM   #8
jmimac351
jmimac351's Avatar
I don't know. Best bet is to contact the vendor of your shocks to confirm. Reference the spring perch measurement in the picture I posted and note that 2.25" and 60mm spring perches can also be acquired from Ground Control.
2015 Subaru BRZ
Old 02-08-2016, 10:21 AM   #9
jmimac351
jmimac351's Avatar
***SOLD***
2015 Subaru BRZ
Ground control Camber plates -Phil Brakes, Suspension, Chassis 13 01-14-2016 08:08 AM
FS: RCE Tarmac 2 Clubsport coilovers, Ground Control Camber Plates/rear mounts gatorac Brakes, Suspension, Chassis 5 08-25-2015 02:31 PM
Ground Control Camber Plates and Eibach R2 ReThink Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-20-2014 10:54 PM
Testing Waters: FS KWV3s with Ground control camber plates and robispec rear mounts YDNA Brakes, Suspension, Chassis 0 01-25-2014 03:34 AM
Vorshlagg plates (vs) ground control thoughts and question OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-05-2013 03:23 AM
