Old 01-28-2016, 02:28 PM   #1
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Widebody Fender Liner solution?
Hey everyone,
Now that I've installed my wide angle steering kit, I'm having even more issues with my front tires rubbing on both the outer fender and inside fender liner on full lock, so I've decided to get wheel spacers and wider front fenders like the Todoroki ones.
Since this is my DD, I'd like to keep/replace the fender liners. Will I still be able to keep the OEM liners on when I install wider fenders? Does anyone have any ideas for filling in the extra 30mm gap? I'm mostly worried about rust and debris getting into the engine bay. What does everyone else with a widebody kit do about this?
As you can see without the fender liners, there's pretty big holes leading into the engine bay
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
The Following User Says Thank You to campy For This Useful Post:
NahumCC (01-30-2016)
Old 01-29-2016, 12:41 AM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The todoroki's aren't fully wider. Since they are narrow in the front and back and only get wider at the top wheel arch most that run liners just run the stock ones. You can use zip ties to hold them at the tops and the factory pushpins for the front and rear.
Or you can undo the fender liner and pull it outward (and drill new holes) so it fill the gap. The front sections and the opening in the engine bay should have enough overlap to close the 30mm gap.
The Following User Says Thank You to Kiske For This Useful Post:
campy (01-30-2016)
Old 01-29-2016, 08:28 AM   #3
Ashikabi
Ashikabi's Avatar
You could attach a piece of plastic(like the fender liner) to the hole in the engine bay and just leave the rest of the fender uncovered
Old 01-29-2016, 02:21 PM   #4
danny_d19
danny_d19's Avatar
Drives: Whiteout RBv1 FRS
The fender liners are surprisingly rigid so even after you lose the stock fender they should still sit in place just fine. Mine with RB kit are trimmed a bit on the outer edge and on the front, but still hang in place with OEM clips and totally cover those holes into the engine bay.
danny_d19 is offline   Reply With Quote
The Following User Says Thank You to danny_d19 For This Useful Post:
campy (01-30-2016)
Old 01-30-2016, 05:49 PM   #5
campy
No rice, no life
campy's Avatar
I'll have to experiment with pulling it over to cover the hole. I just don't want a bunch of road debris getting stuck in my fenders.
Did you trim this bit of frame that sticks out behind the wheel? I already rub on the back of the liner so I'd need to cut that and look for another spot to attach it (or just let the liner rub).
I thought about that I'd also like to avoid the sounds of rocks hitting the bare metal and rust caused from the paint getting sandblasted every day.
Old 01-30-2016, 05:56 PM   #6
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If your worried about the sound, just hit the backside/wheel well with some SEM/3M Black undercoating. Comes in a rattle can and is like a softer ruberized bed liner. Just remember to mask off everything as it does splatter and go on thick.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
danny_d19 (01-31-2016), TRAKRAVN (01-30-2016)
Old 01-30-2016, 07:53 PM   #7
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by campy View Post
That looks amazing. I'd love to see more pictures of the build and where all the support systems got moved to.
Definitely is becoming a desktop screen on one of my devices.
Sent from my SAMSUNG-SM-G870A using Tapatalk
NahumCC is offline   Reply With Quote
Old 02-02-2016, 02:20 PM   #8
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
I formed some new ones out of aluminum. They bolt in in 4 places and then used self leveling seam sealer around the edges before the engine bay was sprayed.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
danny_d19 (02-02-2016), olsonpg (02-02-2016)
Fender Liner Removal? smg1138 Tracking / Autocross / HPDE / Drifting 2 11-04-2015 01:11 PM
WTB Driver Side Fender Liner #maverick# Want-To-Buy Requests 0 06-02-2015 03:49 AM
Fender liner replacement cost? impossible Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 11-01-2014 09:48 PM
Fender Liner Dilemma FRSure Scion FR-S / Toyota 86 GT86 General Forum 10 03-31-2014 09:45 PM
WTB: FRONT FENDER LINER mr. slim Want-To-Buy Requests 0 01-06-2014 06:05 PM
