Sam Strano
Old 01-20-2016, 04:15 PM   #3963
DaWorstPlaya
Drives: 2016 FR-S
How much -ve camber are you guys getting in the front with the crash bolts and stock shocks?
DaWorstPlaya is offline   Reply With Quote
Old 01-20-2016, 04:29 PM   #3964
JB86'd
JB86'd's Avatar
Drives: JAWS
It's usually about -1 to -1.2 I believe. I got -1.1 on both sides.
JB86'd is offline   Reply With Quote
Old 01-20-2016, 04:38 PM   #3965
DaWorstPlaya
Drives: 2016 FR-S
Was this with the TRD springs?
Old 01-20-2016, 04:40 PM   #3966
Jawnathin
Drives: Toyobaru FRZ
Originally Posted by TMF View Post
Last year I was on the TRD springs, bars (F and R), and Koni full replacements. -2.2 degrees camber up front and I think -1.6 degrees camber in the rear. 0 toe all the way around. I ran the Koni's 1/2 turn from full stiff up front and 1/2 from full soft in the rear.
...And I got oversteer on corner exit on throttle. It was controllable if I eased into the throttle, but it definitely didn't push imho.
This year, I'll have to run the inserts in the front Konis and I'll probably lose about a degree of negative camber. I obviously haven't had a chance to try it that way yet, but my guess is I will still get some oversteer on corner exit.
From the factory, BRZ's understeer (typical Subaru) whereas the FRS has a bit more rotation. The TRD springs are "apparently" the same spring ratio when compared front to back, so the handling characteristics should be similar with the TRD's vs stock on the FRS.
I've always run 0 toe on my cars, but if I still have excessive oversteer on corner exit, I may try a hair of toe-in in the rear.
Thanks for sharing your experiences. A little bit of oversteer on corner exit is nice, I can get the car pointed in the right direction. I rather have that than the push I was getting on my BRZ. I think the stiffer springs and sways will help neutralize the car a bit. Hopefully it doesn't get too loose during the slaloms. I think my BRZ was well balanced there.
First event in the car is this weekend, but looking like its going to rain
Jawnathin is offline   Reply With Quote
Old 01-20-2016, 04:48 PM   #3967
TMF
TMF's Avatar
Drives: '14 FRS TT5
Oh must be rough...rain! Boo hoo, my car has been in storage since November and won't come out until March/April
Anyway, you might want to try zero toe all the way around with as much negative camber you can get up front on the new setup. Then after you've experimented a bit, I'd fine tune with strut rebound adjustments, then toe.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
The Following User Says Thank You to TMF For This Useful Post:
Jawnathin (01-20-2016)
Old 01-20-2016, 04:58 PM   #3968
JB86'd
JB86'd's Avatar
Drives: JAWS
No sorry, stock
Old 01-20-2016, 05:20 PM   #3969
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
I would imagine the TRD springs will provide us with a little more negative camber since the car is being lowered. That will probably be the biggest advantage of the TRD springs.
86_Freak is offline   Reply With Quote
Old 01-20-2016, 05:59 PM   #3970
johhnc479
Drives: White FRS, 2011 Cayman, 1986 944
C street mods that may turn to STX
I've done very little autox, and zero HPDE with my FR-S. For several years I've been tracking my Porsche 944, and autoxing my completely stock Boxster 986S with PCA. In the last few years, I have only been autoxing. Now I've "retired" my 944 from track duty and returned it back to mostly stock. I've been contemplating getting back into HPDE in the FR-S and competing in SCCA autocross with it. I'll definitely continue to be at most of our local PCA events in the Boxster (I'm active on the PCA autox committee).
I've been thinking about STX for the FR-S only because of the potential need for brake and cooling upgrades for HPDE use. I'll be lucky to make more than a 3 or so HPDE's in a year, so I really don't want to put a bunch of money in the car for a "maybe" use.
If I go the C Street route for SCCA autocross, what mods would you suggest that won't be a waste of money should I end up going the STX route? I don't mind having an extra set of 17x7 wheels, so that wouldn't be wasted money.
johhnc479 is offline   Reply With Quote
Old 01-20-2016, 06:27 PM   #3971
gtslow
Drives: 2015 Halo FR-S
Most people run 17x9 in STX and are forced to stay 17x7 in CS. That being said, another set of 17x7 would then be a waste of money if you want to be nationally competitive. The only things I could think of that carry over for class prepared cars might be brake pads, a sway bar and fluid refreshing.
gtslow is offline   Reply With Quote
Old 01-20-2016, 06:28 PM   #3972
Jawnathin
Depends on how far you want to go in STX. All of the stuff you can do in CS would still work for STX, but it may not necessarily be the best option for STX. If you're looking for components that would be 'best' for both, that list is going to be quite small.
I think you can get some MCS shocks. I think on its own its normally a coilover but you can some spring perches that make legal for CS. You would just back to the non CS spring perch for STX.
A lightweight catback or axleback may be usable, but you're going to want headers and a tune for STX. So the catback/axleback would still need to hook up to whatever you do exhaust wise.
You may also be able to keep a sway bar. That is all that comes to mind.
Old 01-20-2016, 07:01 PM   #3973
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Pads and fluid will cover the brakes and imo cooling is not a necessity on stock powertrain, I'd say save a few bucks and do CS.
If you're determined to run an oil cooler I doubt the local guys will throw a fit as it's unlikely to be a performance advantage.
ineedyourdiddly
Old 01-20-2016, 07:02 PM   #3974
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
-0.9 both sides with TRD springs.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-21-2016, 12:08 PM   #3975
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I post here because we're OEM
how fast do you guys lose alignment after racing?
my last 3 alignments, about 8 months apart each, show a trend of the rear going considerably out of spec, while the front maintains it's spec much better.
could this be an issue with the OEM alignment bolt in the rear, or the fact our rear crossmember shifts around a lot from having soft bushings?
Old 01-21-2016, 01:10 PM   #3976
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Originally Posted by TrqlessWonder View Post
Max camber rear? No real such thing. It's not adjustable. You can play with the rear subframe to get it even side-to-side though
Just to clarify: do you mean there is enough play in the linkage attachment points to the rear subframe to change rear camber slightly? All of the the rear linkage attachment points are connected to the subframe, so the only adjustment that can be achieved through moving the rear sub frame in relation to the body is track. I'm curious if you have actually been able to change your rear camber by taking advantage of play in the linkage bolt holes. Please do tell if so.
My first guess would be that the bushing/suspension preload method used prior to checking the alignment hasn't been consistent. The factory service manual has a very specific method for preloading prior to checking the alignment and this has to be done every time an adjustment is made. I could be wrong but I think you'll see significant changes in alignment readings if the preload procedure hasn't been followed correctly.
Briankbot is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
