Old 01-09-2016, 02:19 AM   #435
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Might be a silly Q, but does it matter if it's left hand or right hand drive?
I like driving!
86 South Africa is offline   Reply With Quote
Old 01-10-2016, 11:51 AM   #436
86 South Africa
Originally Posted by sanmarcosfrs View Post
Just installed today. No rattles or noise and a massively improved feel. Throws are shorter then my friends 997 gt3. It's that good.... Could not recommend it more!!
After reading your thread I'm keen on this mod now too.
Perhaps you could help me with a few Q's?
1. Is it easy to install for a beginner (not an experienced mechanic myself)!
2. Rough install time?
3. Shorter throw sounds good... Is it smoother than stock, but still with that nice positive feel?
4. I'm assuming it won't affect an aftermarket drive shaft if I want one in future?
I like driving!
Old 01-10-2016, 02:13 PM   #437
stevesnj
stevesnj's Avatar
Originally Posted by weederr33 View Post
I caked the bolt with red threadlocker and a week in it hasn't come loose.
I didn't over do it but i did add red high strength locktight based on this thread. No issue since July.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
CxG (01-15-2016)
Old 01-11-2016, 07:58 PM   #438
MaxxCann
I agree,I went ahead and used the red and so far, so good.
Thanks guys, I thought for sure I was going to yank it out (giggity) but it works great now. The loose bolt was the problem.
If your bolt is loose, you don't lose 1st and 2nd, but you really need to wrench it over to the left engage it. Now my problem is it slides so well into those gears and my muscle memory already kicked in for the loose bolt.
2013 Asphalt FR-86 (badge conversion) | TRD wheels | TRD CAI | TRD exhaust | TRD lowering springs | TRD front strut tower brace | TRD door stabilizers | TRD member brace kit | TRD spoiler | TRD quick shifter | TRD door speaker panels | TRD seat gap fillers | GT86 Armrest | Red Perrin Lightweight Pulleys, Drift Button, and Reverse Lockout | Winjet Foglights | Full LED swap | Custom dash and HVAC LEDs
MaxxCann is offline   Reply With Quote
Old 01-11-2016, 08:01 PM   #439
MaxxCann
1. Pretty easy. You have to be patient, the parts are a little difficult to get to, especially with my big ass ham hands, but if you take it slow and follow the instructions, it's very easy.
2. About an hour at most.
3. In my opinion, it's much more positive in that you feel it go into gear. It takes very little wrist movement now.
4. Shouldn't. It fits in the same footprint as stock but hangs down about 1.5" more for the adapter. I didn't see it even get close to my driveshaft.
The Following 2 Users Say Thank You to MaxxCann For This Useful Post:
86 South Africa (01-12-2016), Tcoat (01-12-2016)
Old 01-12-2016, 06:26 AM   #440
86 South Africa
Sweet - thanks!
I like driving!
Old 01-12-2016, 12:53 PM   #441
MaxxCann
Sweet - thanks!
Also make sure you have your tools ready. I have hex head sockets which made it easy and definitely have the red loctite ready to go.
The Following User Says Thank You to MaxxCann For This Useful Post:
86 South Africa (01-13-2016)
Old 01-18-2016, 08:25 PM   #442
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Q: would the whiteline transmission mount bushing interfere with the quickshifter? I don't recall it would.
MS, CSCS, TSAC-F, CPT
Old 01-18-2016, 08:39 PM   #443
SPCorBUST
SPCorBUST's Avatar
There was a previous owner who installed the kit with an aftermarket driveshaft and he encountered rubbing issues.
I have the kit and driveshaft but have yet to install the bracket piece, I've been waiting to double check this very thing. The aluminum driveshaft I have is different than that poster, but comparing it to the stock driveshaft it is significantly thicker.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
MaxxCann (01-20-2016)
Old 01-19-2016, 07:50 AM   #444
86 South Africa
Please do post updates once you've finished with the bracket... I am tempted to just go with whiteline bushings...
I like driving!
Old 01-20-2016, 02:42 AM   #445
MaxxCann
I wouldn't think so. The bushing is pretty far away from the shifter and a totally different mechanism.
CxG (01-22-2016)
Old 01-20-2016, 02:43 AM   #446
MaxxCann
I'm thinking about doing the driveshaft too. What did you get?
Old 01-20-2016, 05:01 AM   #447
SPCorBUST
SPCorBUST's Avatar
DSS aluminum
Sent from my SM-G925T using Tapatalk
MaxxCann (01-21-2016)
Old 02-21-2016, 03:52 AM   #448
KevinA
Drives: Toyota GT86
Do you think this kit would fit a RHD GT 86
Thanks
KevinA is offline   Reply With Quote
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
