Old 01-01-2016, 04:44 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Headlight Restore kit
First time I've ever used a headlight restore kit and I like it as it gave me good results.
[ame="http://www.amazon.com/gp/product/B00429NKWK?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s00"]Sylvania 46135387715SYLVANIA Headlight Restoration Kit[/ame]
Reason why I chose this one was because people on other forums recommend it, it lasts a year or more and most importantly, came with the UV Clear Coat.
Directions were easy to follow, I've never done this sort of thing before. My headlights weren't yellow or foggy but were in the process of that because my aftermarket headlight's UV Coat was peeling. Just follow the steps of Prep, Sanding, Polishing, and Clear.
Will try to report back when I have to redo it again and how long it lasts.
YamahaR86 is offline   Reply With Quote
The Following 2 Users Say Thank You to YamahaR86 For This Useful Post:
mdm (01-13-2016), soulreapersteve (01-02-2016)
Old 01-01-2016, 06:17 PM   #2
radroach
Drives: car
Any ideas on how to apply a new UV coating after doing this?
Old 01-01-2016, 07:00 PM   #3
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
There's a UV coating liquid in the kit, which is what also leaned me toward it. It's the last step.
Steps are spray prep, wet sand 400, 1000, 2000. Polishing wipe.
After those steps I was sort of upset since it still had that white hazy fog you get after you sand but as soon as the clear coat touches it it clears up.
Clear coat direction is pretty much dip the supplied paper towel sheet into the clear coat bottle, wipe it on the headlight on a left to right motion working top down. Don't overlap your old wipes and a thick layer of it is recommended.
Let it dry for an hour before you touch it and a full 4-6 hours after for it to fully cure.
I messed up a bit since I did it outside and it lightly rained after an hour so I have a small smudge but it looks way better than before.
The Following User Says Thank You to YamahaR86 For This Useful Post:
radroach (01-01-2016)
Old 01-01-2016, 07:27 PM   #4
radroach
Drives: car
@YamahaR86
Hmm, did it come with any plastic polishing compound? I'd imagine if you used Meguiar's Plastic-X or their headlight compound it would have cleared up the haziness before you did the clear coat phase.
Old 01-01-2016, 10:41 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
@YamahaR86
Yeah it did. It was called clearing compound. It felt kind of like a polishing compound as it had a gritty feeling to it. Which is applied after the last wet sanding phase.
Though they did say after you'll still get the white haze it's perfectly normal. It didn't clear up until I applied the clear coat.
Old 01-03-2016, 04:35 AM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
quick question. That headlight is plastic right? Not glass? I'm in the market for glass headlights.... lol
Old 01-03-2016, 12:34 PM   #7
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Plastic Yeah. It'll be hard to find glass headlights nowadays because they're more expensive and heavier.
Packofcrows (01-03-2016)
Old 01-03-2016, 12:40 PM   #8
twag4
Drives: frs
And illegal, as most governments are trying to make a pedestrian strike more survivable for the pedestrian. They believe broken headlight glass is dangerous to pedestrians.
twag4 is offline   Reply With Quote
The Following 2 Users Say Thank You to twag4 For This Useful Post:
funwheeldrive (04-14-2017), Packofcrows (01-03-2016)
Old 01-03-2016, 02:00 PM   #9
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
My spyder headlights are doing the same thing I was thinking about having a shop do them and clear coat them. But I guess I'll try one of these kits first. Thanks.
Old 01-13-2016, 04:35 AM   #10
wil5bart
Drives: '16 BRZ
Sounds like a good alternative to 3m and Megs though I'm curious how long it will last.
wil5bart is offline   Reply With Quote
Old 01-13-2016, 11:32 AM   #11
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I had 3M before and to be honest I had no idea what I was doing and it didn't work out in the end.
I had the kit where it came with a power drill head attachment.
Old 01-13-2016, 07:26 PM   #12
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
Great video about this, and the different ways to go about it, with slightly more in-depth step by step:
AzureShadow is offline   Reply With Quote
Old 01-16-2016, 12:09 AM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yup that's exactly the reason why, plastic doesn't shatter out and become shrapnel and also don't become a clean up issue in a crash causing tire blowouts in the future. Also plastic is way easier and cheaper to manufacture and mold into an aerodynamic body piece. The fog lights however are a small easy to mass produce glass enclosure on our cars.
Old 03-27-2017, 06:30 PM   #14
FR-S Runner
Drives: 2013 FR-S Whiteout
Update on this? I've had my spec d lights for maybe 6 months, and it's starting to peel around the corners.
FR-S Runner is offline   Reply With Quote
Restore 1 Stay Fresh Car Care Cleaning and Detailing 0 05-03-2014 05:26 PM
Restore the Performance of your Car with Functional Fluids at FRSport! FRSport.com Mechanical Maintenance and Tools 0 04-25-2014 01:27 PM
Headlights Restore FRS_Sovereign Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-28-2013 01:57 AM
How to restore OEM brake pads after a track day? torqdork Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-24-2013 01:45 PM
