go_a_way1, MisterSheep
Old 01-07-2016, 07:33 PM   #43
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
100% city and i am getting 22-23mpg.
Muaddib is offline   Reply With Quote
Old 01-07-2016, 07:40 PM   #44
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by RichardsFRS View Post
What would cause this car to average 26.5. That's pretty low I would think. This was around 80mph average speed on the freeway. Far as u know it has no mods
Want 30+? Drive around 60mph or keep under 3k rpm. Keep all shifts around 2.6k and speed up slow, lower car interior weight (i.e. lose weight)
If you bought this car for mpg, may I recommend a trade in for a Yaris?
BTW, elevation also matters. I drive 68mph in cruise control. I get 28.6 mpg avg with some city driving. My elevation is about 48ft above sea level. Without city driving I range 30-32. I can totally see higher rpm=less mpg.
Originally Posted by fumanchu1 View Post
I get more smoke per mile than miles per gallons, being Sc'd I don't count but let's just say you guys with your 18-20 mpg in the high rev have it good, I start led footing and bye bye mpg's
I took my car to track and got from 9mpg to like 19mpg hahah I can imagine you!~
Old 01-07-2016, 07:44 PM   #45
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
17 to 18 mpg city. Now 15.5 soopahcharged
shiumai is offline   Reply With Quote
Old 01-07-2016, 08:05 PM   #46
DJCarbine
Thupercharged
DJCarbine's Avatar
24mpg city/highway, highway only gets closer to 28-29 if I can control myself
Hint : I can't
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-07-2016, 08:06 PM   #47
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Good thing to know everyone 's mpg is so low. LOL... I was wondering if my cat is getting clogged since my avg mpg dropped to like 24.
After all I made the 1200+ mile trip to seattle in 3 tank of gas only 5 months ago.
Old 01-07-2016, 08:58 PM   #48
This hasn't been my experience. I have (eventually) posted every tank since new(May 2012) in my Owner's Journal thread. During that time I've made 14 trips where the entire full measurement was at a speed of 70MPH or greater. Of those my lowest mileage was 31 and the highest was a little below 36. This was based on calculated speed (distance/time). The lower ones included some stop and go traffic in the process usually followed by exceeding the speed limit more than normal. At least one of them includes periods of speeds between 90 and 100 for about 30 minutes.
Bristecom (01-10-2016), Tcoat (01-07-2016)
Old 01-07-2016, 09:03 PM   #49
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Umm... you're cruising at 80mph. Atmosphere is pretty hard to push through at that speed. Deez ain't no Prius drag coefficients we be dealing wit herre.
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed
1996 Mazda Miata (Track car.)
2007 Suzuki SV650 (Track bike.)
akiranakayama is offline   Reply With Quote
Old 01-07-2016, 09:09 PM   #50
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Although, something to keep in mind is that with automatic transmission, your highway cruising RPM in 6th gear is a fair bit lower than with manual, so it's not surprising that you see a bit better highway mileage than most people are getting.
I've only calculated my mileage manually two or three times, but the car MPG display shows an average of between 30 and 31 MPG with a mix of city and highway driving. Car is stock, manual transmission.
With MT, I've noticed that any speed past about 72-74 MPH and you're going to start taking fairly significant MPG hits.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
Dadhawk (01-07-2016)
Old 01-07-2016, 09:19 PM   #51
Yea, I should have noted I had the Auto, and actually meant to in the post above. All you say is correct.
Over 74,219 lifetime miles I've averaged 32.7MPG which includes a lot of tom-foolery during commuting (I race nearly everyone away from the lights and rarely see an off-ramp I don't take twice as fast as I should). That said, even with commuting 40 miles each way to work I spend a lot of time on cruise at 45 to 65MPH.
Lelantas (01-07-2016)
Old 01-07-2016, 09:26 PM   #52
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've tracked every fill-up I've EVER done since I bought the car. That means I've got 14 months of data spanning 24,400 miles, and 912.17 gallons of gas (costing $3,004.11) to draw from. Here's my information:
Avg MPG: 26.846
Min MPG: 18.324 (that was snow-storm shenanigans)
Max MPG: 33.979 (highway road trip)
Avg gal/fillup: 9.21
Avg mi/fillup: 246.8
I've noticed that the in-vehicle average readout is consistently 1.5 MPG HIGHER than what I am actually getting.
I live in Chicago. So my average will be lower than many because a lot of my time is spent in heavy traffic, or on streets with low speed limits and lots of traffic lights. When I'm driving on the highway, I tend to do somewhere between 70-80 MPH unless the speed limits are lower.
I have a 2015 Series.Blue, which is important to note because the underbody aero trays are good for a Cd of 0.27, as opposed to 0.28 for a limited (with the wing) or 0.29 for a wingless Toyobaru. This means I theoretically get slightly better highway mileage than most.
This driving was split between the OEM Michelin Primacy HP "low rolling resistance" tires during the warm months (mounted on the stock STi wheels, which weigh 18.4 lb, or ~2 lb less than the normal wheels), and General Altimax Arctic winter tires (205/55R16) mounted on very heavy steelies in the winter months.
I rarely spend much time above 4K RPM. I tend to shift between 3-4K.
One thing I did notice on my most recent road trip (which was on the winter tires) was that when the temperature was in the 30-50 degree range, I was only managing 29 MPG on the highway, whereas the second half of my trip occurred in 60-65 degree weather, and I got 33 MPG. A pretty big difference that one might attribute to the colder, denser air putting up more of a fight against a 78 MPH moving object.
Hope this info is interesting to some
Stang70Fastback is offline   Reply With Quote
Old 01-07-2016, 09:35 PM   #53
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
so either i started driving different after the 20k mile mark or something else ..
I used to average 28 mpg ... now im averaging 23 mpg ...
im hoping its the ignition coils/batteries going bad lol
Old 01-08-2016, 12:01 AM   #54
Packofcrows
what has elevation been? weight? fuel type (91 only in CA doesnt give as much mpg as 93, the recommended one) how often stops? Weather/temp? etc..
Old 01-08-2016, 12:24 AM   #55
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
I average 26-28mpg with 30% city and 70% highway. But I work in the LA area where highway driving is pretty much city.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 01-08-2016, 12:50 AM   #56
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
My worst recorded was 16.36mpg / 14.38L for my stock auto. Mostly city driving.
See sig for history along with mods and their effect.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
