#421 | |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I e-mailed them but got no response. If you see them in SEMA and can get some info, please share!
#422 |
Drives: 2015 Scion FRS
Defi red racer gauges in a triple gauge dash pod. The gauges are recessed and angled just enough to make it easy for the driver to see them. I wrapped the pod in white carbon vinyl. First time doing it and it came out pretty good. Not 100% perfect but good enough for now.
#423 | ||
DrivinginDreams...Cloud86
Drives: Toyota GT86
http://www.ortizcustompods.com/scion.html http://www.ortizcustompods.com/subaru.html
#424 | |
#425 |
Drives: Toyota GT86
Yes. I will post up details and a pic of the trim piece later today.
#426 | |
thats fine, i was just trying to confirm it was included before i placed an order. thanks! |
#427 | |
Drives: Toyota GT86
Also, it is funny how the site states no modification required. When I went to fit the gauge cluster it will not fit into place on the right hand side, due to inner dash plastic conflicting with the pod tunnel. I will have to get some dremel work done to get this to fit. Other than the long wait time I am extremely satisfied with the final product. Some minor imperfections on the product, but I found this as well with the powdercoating on the MSA triple pillar pod as well. I may end up painting the cluster and/or the triple guage/pillars piano black to eliminate all imperfections. Below is a picture of the custom trim piece. In the meantime I will try cleaning this up as there is a bunch of glue mess around the buttons. In the end everything will fit together for an awesome setup.
#428 |
Drives: Subaru
It's hard to tell from pics, but is the left gauge pod angled towards the driver? Could you post pics of how the gauge cluster looks when installed?
#429 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
made it myself.
didn't have to relocate shit. 2 52mm gauges (oil temp & pressure) just go get some PVC pipe and mold it into an em pod, you'll spend maybe 70$ all said and done with a new donor core (its 35$ for a new cluster trim piece online)
| The Following User Says Thank You to Jive Turkey For This Useful Post: | Irace86 (01-24-2016) |
#430 | |
Drives: Toyota GT86
#431 |
Drives: Toyota gt86
Here is my depo racing 4in1 after install
#432 |
Drives: BRZ + Ducati M796
I feel like such a noob when it comes to gauges. Why have so many gauges?
OK, I think I understand the argument about how bad the stock gauges are, so let me restate the position: the stock water temp gauge for instance may have only a few output signals like low, normal and high, so the accuracy isn't good enough; or for the oil pressure warning light, the light is either on or off, good or bad, so it isn't good enough. But I guess the question is why isn't it good enough? And why is that guy who gets a fuel pressure, oil pressure, oil temp, water temp, afr, egt, boost, vacuum, and maybe other gauges I didn't list, not just completely over doing it? I searched, but what I can't figure out is if the water temp is relaying engine temperature and oil temperature is also relaying engine temperature then why have both? And why is there a need for knowing such small changes? If the engine gets too hot then stop or drive slow, right, to cool it? If the fuel pressure drops the AFR is going to get dramatically lean, so besides having an immediate answer as to why the AFR is jacked, the fuel pressure gauge seems like overkill if someone has a WB, right? I get the EGT is a good tuning option, but is it a necessary monitor for engine health? In short, I feel like the most important gauge is an AFR gauge from a WB because the stock warning lights/gauges are sufficient to protect against engine harm/failure. The other necessary gauge is boost for boosted cars. Please educate me because my thinking goes against what almost everyone is doing, so it must be wrong :ion: :respect:
#433 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Oil and water temps are very important. Oil starts to break down when it gets too hot so you need to be sure you don't over heat it. I also like oil temp to know when it is at operating temp. Water temp is good to keep an eye on so you don't boil your coolant off. Oil pressure is very important as you know so its a good idea to keep an eye on it. As oil temps go up pressure will go down. Also if a line falls off on something like an oil cooler I rather know right away then waiting for the light to come on once no oil is left. On a street car these are all useless TBH as the car will never get close to its limits. On the track its easy to over heat your car. sorry for the crude simple reply haha! If you have any specific questions you can PM me so this thread doesn't get too off topic. |
#434 | |
Drives: 86
I wish everyone on this forum was this "crude" and "simple" |
| The Following User Says Thank You to Celica00 For This Useful Post: | go_a_way1 (01-12-2016) |
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 05:46 PM |
| LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 06:19 PM |
| Gas Gauge Issue | Jruex22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-04-2013 10:28 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) — General Topics | 17 | 12-12-2011 11:39 AM |
