Old 11-30-2014, 04:33 PM   #15
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Originally Posted by dj2020 View Post
General oil cooler question here: how do you drain the oil that is in the core and oil lines when you drain the oil pan during an oil change? Or is the amount negligible and simply just drain what's in the pan and then fill her up with new oil?
You could pump air in the line and try draining it, but typically you just do a regular oil change draining it from the oil pan. I could be wrong...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 12-01-2014, 03:16 AM   #16
CSG Mike
CSG Mike's Avatar
Just drain what's in the pan, and fill her up.
You'll be draining and filling the same amount in stock, a small amount remains in the oil cooler core that doesn't get drained, so you don't need to fill any extra.
dj2020 (12-08-2014), Jmonty (05-01-2015)
Old 03-11-2015, 11:24 AM   #17
fasteddy
How much extra oil capacity does this add? I am going to be installing this shortly and just need to know if I need more than 6 quarts.
Thanks.
Pat
fasteddy is offline   Reply With Quote
Old 03-11-2015, 03:50 PM   #18
CSG Mike
CSG Mike's Avatar
Thanks.
Pat
You'll need to top off about 1qt.
fasteddy (03-12-2015)
Old 01-04-2016, 02:51 AM   #19
themajesticone
themajesticone's Avatar
Drives: '13 UM86
So along with the s/c kit itself, which includes an intercooler and a single oil cooler, you also need to get second oil cooler? So you're running two total?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 01-04-2016, 06:06 AM   #20
CSG Mike
CSG Mike's Avatar
The included cooler cools the Rotrex (supercharger) fluid. This thread is for the engine oil cooler, which is independent of the supercharger system.
Not everyone who supercharges their car needs/wants an oil cooler.
Jackson Racing (01-04-2016), themajesticone (01-11-2016)
Old 01-04-2016, 03:32 PM   #21
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
With the oil cooler I understand I need an additional 1qt, but what about when I change my oil? How do I get it out of the oil cooler? Use a pump or something? Or do I just let it drain what it can then fill up with 6 instead of 7qts?
phanguy is offline   Reply With Quote
Old 01-04-2016, 03:34 PM   #22
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Don't worry about it and just add ~5.5 liters of fresh oil. It's okay if you don't drain the cooler assuming you're changing the oil and filter every 3-5k miles.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
phanguy (01-04-2016), Sportsguy83 (04-27-2016)
Old 04-27-2016, 11:49 AM   #23
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@CSG Mike @Jackson Racing one thing about the NA JR cooler that's been bothering me a bit is that my oil lines rest slightly on top of the front bumper beam in the recommended routing (and in fact, the only routing possible given length). Has anyone run into issues with this? I decided to give my hoses an inspection last week and noticed it had already started to strip the paint away from the bumper beam surface through abrasion.
1Cor10:23 is offline   Reply With Quote
Old 04-27-2016, 01:49 PM   #24
CSG Mike
CSG Mike's Avatar
That's intentional. Your impact beam protects the oil line from being exposed to worse things.
Old 04-27-2016, 01:59 PM   #25
1Cor10:23
1Cor10:23's Avatar
Agreed that it does help against other, sharp edges but curious what the lasting impact of the rubbing will be.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 01:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
