Antenna Delete no Weld Version with Carbon Plaque
So I hate the look of the antenna on the roof, just think it ruins the fine shape of this car... anyway I used a Carbon Fiber Console Plaque. It was meant for that purpose but I changed a design. So I bought the center plaque from http://www.innovateddynamics.com/pro...-holder-plaque
For $15 it is a steal. It's hand made to order. So I decided to give it a try using it to use as a cover for the hole well it worked. I plan to paint it when the weather outside allows as I do not have a garage. So it can be very easy or slightly difficult. Easy version, remove old antenna, clean area the size of the plaque use 3M DS tape and add silicone sealant around the rectangular hole for peace of mind and done! For even more peace of mind I epoxied a 3/4" long 1/4-20 thread cut off a bolt. This takes more time and I secure it with a flat washer and wing nut. Overkill but I'd rather make sure it doesn't fly off. But tape should be fine. I will upload more detailed pics later but here's the result before I paint it this spring. I have the simple install instructions in my build thread page 12
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 01-01-2016 at 10:00 PM. |
#2 |
Not a troll
Haha. You think the antenna ruins the lines of the car so you stick a rectangular piece of metal on there that doesn't sit flush? Logic.
| The Following 3 Users Say Thank You to Cole For This Useful Post: |
#3 |
Sorry that looks terrible IMO.
| The Following 4 Users Say Thank You to DIM For This Useful Post: |
#4 |
If welding and painting was $15 I'd do that. Lol. This is not the best way but the best I could figure out that is cost effective.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 01-01-2016 at 08:51 PM. |
#5 |
You're so good looking!!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#6 |
Nah I'll pass. :]
| The Following User Says Thank You to stevesnj For This Useful Post: | new2subaru (01-01-2016) |
#7 |
Drives: Subaru BRZ Limited
If the objective was to remove the antennae and cover the hole, it looks like a success. But aesthetically speaking, the solution does not look good.
#8 | |
| The Following User Says Thank You to stevesnj For This Useful Post: | JoeC (01-01-2016) |
#9 |
OP as long as you're happy, that's all that matters. Unfortunately this is a public forum so when you post something like this, you will get opinions from others. Some of those opinions may disagree with yours. Its your car, as long as you like it
| The Following 2 Users Say Thank You to D_Thissen For This Useful Post: | FRSBRZGT86FAN (01-02-2016), Phantobe (01-03-2016) |
#10 | |
#11 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Or you could just vinyl wrap the whole roof?? Personally I dont like the whole wrap thing but at least it wont be such an eye sore. Wrap can be had cheap and you can install yourself. |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Cole (01-01-2016) |
#12 | |
#13 |
Not Bаnned Anymore
You can buy enough to do the whole roof for $25 off ebay I bet haha. Yeah each to his own, to be totally honest I hate the stock antenna as well, and dislike my sharkfin but I live with it for now. Oneday I might have to hole filled and roof painted.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | stevesnj (01-01-2016) |
#14 |
Drives: FRS
if you do only vinyl and wrap the roof, the hole area will still be visible as that part will "sink" in compared to the rest of the roof. plus the vinyl will be so thin that if anything scratches it or even if theres enough air pressure, it'll puncture and make a hole.
| ***NEW***Beatsonic Version 2 Sharkfin Antenna | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-27-2016 05:32 PM |
| FS: Beatsonic Sharkfin Antenna - Sterling Silver/Argento FDA9 (Version 2) | chermo12 | Canada Classifieds | 3 | 06-02-2015 09:45 AM |
| "86" Dash Plaque - VG Shark fin antenna - Hot Lava | seven | Interior Parts (Incl. Lighting) | 3 | 04-17-2013 12:24 AM |
| VG Shark fin antenna - Hot Lava - "86" Dash Plaque | seven | Exterior Parts (Aero, Lighting, Etc.) | 1 | 04-17-2013 12:24 AM |
| 1st 86 Final Gift : Carbon look Coin Tray badge, Plaque, FR-S Book, CNC Aluminum Box | MarkRacerX | Interior Parts (Incl. Lighting) | 3 | 12-14-2012 01:30 PM |
