Old 06-06-2012, 09:57 AM   #71
slow_frs
Drives: turbo scion tc
So wait we order the software, and then how do we connect to the obs1 do we have to buy a tectrix
slow_frs is offline
Old 06-06-2012, 09:58 AM   #72
Visconti
Drives: 05 STi
No it's software / cable package.
EcuTek has their own cable that comes with the software .
John
Visconti is offline
Old 06-06-2012, 01:02 PM   #73
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by John@TheShopCT View Post
On a side note if PROTUNERs are looking to purchase the ecutek software you can PM me or email me and I'll help get the order rolling for you.
Thanks
John
PM Sent...
Drift-Office is offline
Old 06-06-2012, 02:04 PM   #74
djliquidsteele
Drives: Scion FR-S
Just so I have this straight, as a consumer, I don't need to purchase any kind of cable or software if I don't want to do the tuning myself? Basically I am looking for a tuner who uses ECUTek and they will charge me whatever they choose to do a tune?
djliquidsteele is offline
Old 06-06-2012, 02:15 PM   #75
Visconti
Drives: 05 STi
Well you'll soon have a few different options.
Currently were setting up EcuTek BRZ ProTuners across the country.
I'll let everyone know when the dealer list is updated on EcuTek's website.
Once the dealers are setup you'll be able to vist them in person and get a tune or purchase a cable and get a etune from them.
Currently the software is only PC based.
This is what it looks like
-John
Visconti is offline
Old 06-06-2012, 02:37 PM   #76
bimmerboy
Drives: 2009 135i
Guys relax- in 3 months there will be MULTIPLE tuning solutions for this platform...
Lets give EcuTek a fresh chance as this is a new platform with some new hardware/software..
@theshop- Part of getting people to be more open-minded about EcuTek is to perhaps admit at all the mishaps that happened in the past and learn from them, rather than throwing them under the mat like they never happened... Maybe even learn from vividracing and what they have done to do a 180 on their PR.
My $.02
bimmerboy is offline
Old 06-06-2012, 02:48 PM   #77
Dimman
Kuruma Otaku
Dimman's Avatar
My $.02
By reporting every mention of their terrible past for deletion? They are doing a far more aggressive job at hiding their past than this...
Because titanium.
Dimman is offline
Old 06-06-2012, 03:43 PM   #78
Visconti
Drives: 05 STi
My $.02
I would love to see "MULTIPLE tuning solutions for this platform".
Standalone or piggy computers will come and go but the factory ecu is the way to go.
As your know competition normally works in favor of the consumer!
-John
Visconti is offline
Old 06-06-2012, 04:09 PM   #79
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
I have been e-mailing John and PMing him and he's been very responsive.
John - Just to be clear, which of the following does ECUTEK give full or partial control over?:
Port Injector mapping
Direct Injector mapping
ignition mapping
Target A/F mapping
VVT mapping (all 4 cams)
Knock response mapping
DTCs
Traction control
Boosted2.0 is offline
Old 06-06-2012, 04:44 PM   #80
Visconti
Drives: 05 STi
ignition mapping
Target A/F mapping
DTCs
Traction control
Good Question.
Let me find out exactly what EcuTek has done so far.
-John
Visconti is offline
Old 06-08-2012, 10:04 PM   #81
octagon
Drives: 04 WRX
Originally Posted by TwinscrollGT35R View Post
Are they still locking the ecu's down so you can't remove Ecutek in the future?
This is the question people that really needs to be answered. In the past, when ecutek was installed on certain subaru ecu's it could not be completely removed. As a result an owner could NOT install another tuning software such as Cobb AP or OS on that ecu. The ONLY solution I'm aware of involves getting a new ecu. I had an Ecutek license for my 04 WRX and fortunately Crawford was able to swap ecu's for me when I wanted to switch to Cobb AP.
I guess since Ecutek will be the first to release their product (as they were with the WRX) they won't know if it any other tuning software can be used on an ecu after a Ecutek tune is "removed". I personally will wait until other tuning options are available to find out if there are any other compatibility issues.
octagon is offline
Old 06-08-2012, 11:19 PM   #82
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
-John
Very interesting.
Symbiont is offline
Old 06-09-2012, 12:01 AM   #83
arghx7
Drives: car
Ok, time for substantive questions. I see the torque calculation map, which is fine, but it's rather minor. Assuming EcuTek reverse engineered it correctly and the load axis is really grams/rev like a Subaru, somebody explain a few things.
1) What is the timing and knock control logic? Does it use a dynamic advance multiplier like the older Subarus? Does it use a calculated octane value (in RON)? Or does it use a basic "high octane" and "low octane" map with interpolation? Does it have an MBT calculation and a borderline knock timing calculation?
2) Have you found the injection timing maps? For both port and direct injection, does the logic go by start-of-injection or end-of-injection? Is there some kind of wall film compensation model for tip-in fuel?
3) There must be some kind of commanded air fuel ratio. Does it use open & closed loop areas, or closed loop through the entire operation? Is there an enrichment/closed-loop delay timer logic?
3) Have you found the MAF sensor scaling?
4) Have you found the cam phasing maps?
5) Can you turn on or off the diagnostic monitors and diagnostic trouble codes (check engine light)?
Please provide more information on what you guys have control over. The Japanese control systems (Denso, Hitachi) don't use full torque-based control like Bosch, Siemens, or Delphi do. So finding that map has limited usefulness.
arghx7 is offline
Old 06-11-2012, 11:50 AM   #84
Visconti
Drives: 05 STi
Hey Guys
The EcuTek BRZ software is already very well defined.
Here is a old screen shot I was sent a few months ago.
There has been progress since then, but this will help you get a idea.
Visconti is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 01:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 08:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 03:27 AM
