Old 12-27-2015, 02:18 AM   #827
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by solidONE View Post
Looks pretty damn good. MafV goes as high as 4.13v which is as much as I've seen with my catless headers/stock airbox setup in cold weather. AFR look good except where LTFT was subtracting fuel at the lower range. Not too bad though. With a log looking like this I would not hesitate adding .5 or a degree of timing in the entire range. I'm sure there is a little more power on the table.
But that pull doesn't look like a good candidate to convert to dynograph with a lot of little dips and spikes in the rpm. I like to use 2 smoothing on virtual dyno.
http://datazap.me/u/makinenkr/201512...66-92-97-86-73
I would suggest doing many back to back pulls on a nice and flat/level surface to get good/consistent data for conversion. At least 3-4 pulls. I do about 10 in a row then a 3to4to5 gear at the end for good measure and good data to see if you can add or pull some timing for better power or knock resistance
Thanks for your comment.
Interesting point is, if I advance one cell by 0.350 at 2800RPM certain point IAM drops to 0.88.
Fortunately over 6800RPM, I can advance one or two clicks from above logged data so more flattened power output at those high area.
Edit:
After adding some ign advance to the high RPM and got FLKC -0.65 from 7343RPM just before retarding by the ign map.
http://datazap.me/u/makinenkr/201512...7-112&mark=107
For the Virtual Dyno graphs, smoothing works great! In my cases, smoothing 3 is more realistic I think.
makinen is offline   Reply With Quote
Old 12-27-2015, 07:06 PM   #828
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
This pull is not a good candidate for conversion either. Do you have bouncy suspension or this is a rough road?
http://datazap.me/u/makinenkr/201512...84-81-79-80-78
@makinen This is a 3rd gear pull I did at a slight downhill grade.
http://datazap.me/u/solidone/cw1z2-1...5012&mark=4887
Notice there are no dips or spikes in the RPM. good candidate for conversion if I had done it on a level surface.
1smoothing coverted from this log
2 smoothing with same log:
While the curvature of the line reflects the actual output the line is shifted up by about 20~25 WHP at the peak from what I'd get on a level surface.
Intent > Content
Old 12-28-2015, 10:32 AM   #829
makinen
makinen's Avatar
Drives: Toyota 86
My test course is little bumpy to my suspension (RCE Tarmac/Koni Yellow). Plus winter tyres do not grip well.
I've increased smoothing factor to 5 and the result resembles actual Dynojet numbers.
Old 12-28-2015, 03:24 PM   #830
Akya2120
Drives: 2016 Oceanic FR-S
Maybe someone can help me here. For some reason OF Manager freezes every time I try to export my log. I am using windows 10, and I am not sure if it is an OFT issue or if it's an OS issue. When I click download all it will bring up the log file. Then when I click the log file it will go through a process and after that OFM is frozen. Not sure if it's actually downloading it or not, but I have been unsuccessful trying to find it. Thanks in advance for any help.
Akya2120 is offline   Reply With Quote
Old 12-28-2015, 03:46 PM   #831
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Make sure your OFM is up to date and make sure the OFT is up to date. Older OFT software would let you create logs that were too big (more than about 20 minutes) and would lock up the OFM. You might have to quickly click the delete button to get rid of the corrupted log file and make a new one after updating everything.
The Following User Says Thank You to DocWalt For This Useful Post:
Akya2120 (12-28-2015)
Old 12-28-2015, 03:49 PM   #832
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Had some troubles in the last two weeks with my Twin Screw. Turns out my pre-o2 sensor exhaust leak (against block), was causing the sensor to read lean and dump gas into the block. Developed a bad knock. Pulled the oil, smelled like gas. Changed oil, stripped the car to stock, ran it for a week, no issues. Tuner sent me a new tune with less timing, ran that for a week with no issues. I flashed the final tune (original one) back on it, and have been running it for 24 hours now. I've also sent him these logs and am awaiting confirmation that I'm good to go. If anyone can take a look and tell me how these look, that'd be awesome.
There's a bunch of 2nd/3rd gear pulls, and one decent 4th pull. Wasn't on the highway, so I did what I could.
http://datazap.me/u/rifle/final?log=0&data=6
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 12-28-2015, 03:54 PM   #833
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
IMO it looks a bit lean for FI and the trims during "normal" driving are pretty far negative.
Old 12-28-2015, 04:53 PM   #834
Rifle
Rifle's Avatar
It felt a bit weird, to tell you the truth. Just want to make sure I'm not starving the motor or anything. I'll see what he has to say. Thanks!
295WHP/220TQ
Old 12-28-2015, 05:29 PM   #835
solidONE
solidONE's Avatar
Unless you want just some inconsistent and inaccurate dynographs to look at, you need to figure how to set it up so its at very least repeatable and consistent if not accurate. Otherwise those virtual dynos are pretty much useless as far as using it as data to gauge power output.
Virtual dyno can be very consistent and accurate if you do it correctly.
Intent > Content
Old 12-28-2015, 10:46 PM   #836
Akya2120
I thought it was all up to date, I'll upload the most recent template, and I know I have the most recent OFM unless they updated it between Saturday and today. I guess I'll just have to delete the log and try again.
Old 12-29-2015, 07:44 AM   #837
steve99
Drives: FT86
just remember the tuner may not have rescaled the o2 sensor, the stock o2 sensor scaling only reads down to about 11.8 afr so you cannot trust the afr reading it may be running richer.
Old 12-29-2015, 09:23 AM   #838
Rifle
Rifle's Avatar
No clue. I'll ask!
295WHP/220TQ
Old 12-29-2015, 01:06 PM   #839
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
True, but considering it was pretty lean at WOT (leaner than I am NA anyway) well before it got to 11.8...
Old 12-29-2015, 04:14 PM   #840
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's if you trust the sensor output as the genuine AFR....
.: Stealth 86 :.
Kodename 47 DJ:
DocWalt (12-29-2015)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
