#43 |
I've helped a few people fix their bumper issues. The main issue is in a design flaw in how the bumper is supported or more to the point, is not supported. The whole bumper is essentially supported from the top strip that also holds the hood seal. The fasteners all across the bottom loosely hold up that forward bottom plate. I don't know what it's called.
I've had mine off a couple times and reinstalled it with no issue. the trick is to install it so it loosely hangs off of the top fasteners. Do not tighten them. Carefully pop the corners into the clips. Loosely attach all the fasteners across the bottom. While everything is still loose, grab the bottom of the bumper cover and lift. Notice the effect it has on the fit of the corner clips. Tighten the top strip from the center outward while supporting the bottom. There's not much slop in those mounts but it makes a difference. That's the key. The real fix for the bumper is to support it from the bottom using something along the line of those turnbuckles that I see on aftermarket splitters. @AznKirby, I bet your corner clips fit nicely with the way you mounted your splitter.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Cole (12-18-2015) |
#44 | |
Newbie
Drives: Gt86
Have a nice day. |
#45 | |
Dude just give it up.
| The Following User Says Thank You to Tcoat For This Useful Post: | Cole (12-18-2015) |
#46 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | brandonblt2 (12-18-2015), Cole (12-18-2015) |
#47 |
Newbie
Drives: Gt86
Are you saying "residue" dosent build up in gas tanks? It accumulates in the bottom, so when you let your fuel light come on a regular basis, that "residue" goes through your fuel line to different parts of the engine causing all sorts of issues. There's hundreds of links that say this. Do you have one that says it dosent?
I may have just walked away and presumed you know everything there is to know about the gt86 and fuel but after reading about handbrake's vs brakes and uphill start I'm finding it a bit hard. |
#48 |
Newbie
Drives: Gt86
Oh wtf happened to the links. I'll repost the correct ones. Sorry.
#49 | |
2) You need to chill out, the links you posted are from bias gas companies trying to sell you on things, and vehiclemd is owned by TKO multimedia which is known for putting quick clickbait articles online to get views, notice none of the quotes are fully cited. Also the authors lack of knowledge is astounding because they are just writers from TKO multimedia assigned a topic for their "Car" site. Spamming links doesn't help anyone 3) Stop antagonizing people that may know more than you I suggest you stop posting all together you have single-handedly derailed the thread, idk what the mods will do but if you keep it up you may get banned
| The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: |
#50 |
Newbie
Drives: Gt86
“Numerous ASE (Automotive Society of Engineers) papers document that it is the nature of internal combustion engines to produce deposits,” said Owen Heatwole, Technical Support and Environmental Health and Safety manager for Solid Start. “Any time an engine shuts down, it goes through a ‘hot soak.’ A ‘hot soak’ is when your engine is still producing heat, but there is no air flowing through it to cool it down. During the ‘hot soak’ period, fuel residues become thin deposits called gum and varnish. With time, these thin residues accumulate and bake into rock-hard carbon deposits, which can be very difficult to remove.”
1.http://www.racq.com.au/cars-and-driv...ector-cleaning 2. https://books.google.ae/books?id=gGt...%20why&f=false 3. http://www.totalautowny.com/support/low_gas.mgi Sorry for the off topic but somehow it got derailed, it's all in the off topic "shitstorm" thread. Last edited by Eighty 6; 12-18-2015 at 07:39 AM. |
#51 | |
http://www.solidstart.biz/products.html HE does not once mention a specific ASE article.... 1) This article talks about build up of carbon deposits on injectors, not an issue on our cars because we have port and direct injection, the direct injection may get carbon buildup, but the port injection helps "wash" that off. What they describe does not occur at the high pressure fuel pump it is not hot enough for that to happen. 2) Article would not load correctly because of .ae designation in the site tags which leads me to believe you are from the UAE? Also check the copyright date of that, fuels are much more different today than the 90s 3) What are you trying to prove with this article? It talks about moisture in gas tanks nothing about residue you are so adamant about Stop random googling in hopes of proving something this thread needs to be locked
#52 |
In before the lock
| The Following User Says Thank You to Ashikabi For This Useful Post: | Eighty 6 (12-18-2015) |
#53 |
Hail Magnet
All this has gone to show is that people will cherry-pick articles and information (sometimes ignoring outright, basic, unbiased facts and science) to back up their opinions. Yes, heat soak does happen, carbon buildup is real, but we're talking about over the lifetime of the car. Unless you are a true car abuser, this really won't apply to you.
To think, I was actually curious about the bumper misalignment, since mine has been that way for over a year now. I agree, time to lock the thread. |
| The Following 5 Users Say Thank You to HunterGreene For This Useful Post: | Cole (12-18-2015), Eighty 6 (12-18-2015), FRSBRZGT86FAN (12-18-2015), fumanchu1 (12-18-2015), Tcoat (12-18-2015) |
#54 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#55 |
But this thread has so much more potential. Look at the Uphill Start thread, it's made it like 27 pages
#56 |
Newbie
Drives: Gt86
Take this to the "shitstorm" thread, this is too off topic. Read my last post and answer clearly.
