#15 |
Newbie
Drives: Gt86
I keep my tank full, never below the quarter mark, And so far no crickets. Have you ever taken out an old car's reservoir to clean and seen the shit that comes out? I used to have to change my fuel pump every 6 months on an old scirocco till I went to the source of the problem which was the fuel tank.
#16 | |
Newbie
Drives: Gt86
#17 | |
Have you owned your car when it was hot out? Do you use 10% ethanol gas?
| The Following User Says Thank You to Tcoat For This Useful Post: | FRSBRZGT86FAN (12-18-2015) |
#18 | |
Newbie
Drives: Gt86
#19 | ||
It is hot by the way Cole.
| The Following User Says Thank You to Tcoat For This Useful Post: | Cole (12-17-2015) |
#20 | |
Go read one of the 200 threads on the subject.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#21 |
Newbie
Drives: Gt86
Hot out? And no we don't use 10% ethanol gas. You know this is a vast subject and we could go backwards and forwards for hours without reaching a solution. To cut a long story short if you do know what causes crickets by all means send the manufacturer proof and you would help the 86 community a lot.
#22 |
Well there is your answer to why you don't have them.
#23 | |
Newbie
Drives: Gt86
#24 |
Not that I see no.
Go read the existing threads on the subject. I am done here.
#25 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Even now that this thread turned south and no one learned anything, I'm sure after he keeps filling up when he gets down to 7/8 of a tank, whether it's a week, or a month, or 5 years, he'll learn this is a fallacy eventually. If you can own the car long enough and use shitty enough gas to accumulate said crap in your tank, which may take a while, that can only go so far as to cause blockages, poor flow and pressure in lines, or pump failure. Has jack shit to do with noise in a hpfp...
| The Following User Says Thank You to Toyarzee For This Useful Post: | Tcoat (12-17-2015) |
#26 |
Newbie
Drives: Gt86
So if it's the ethanol that's causing the crickets why haven't they done anything about it? If you've found what the problem is, document some proof and post it here and maybe send the manufacturer an e mail.
#27 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | Tcoat (12-17-2015) |
#28 | ||
Hail Magnet
The common problem with old fuel is "varnishing," usually due to oxidiation of the fuel (read: improperly sealed container). I would be suspect of any gas that has been stored for over a year, though. Fuel stored this length of time can end up with the "gums" or residue you are so afraid of. However, note that I am talking about storage here. In a car, unless you are storing it for a period of years, the gasoline is usually refreshed and used in the system on a fairly regular basis. Basically, there isnt any time for the "residues" you are so afraid of to form. In addition to this, the recommended treatment of these problems is to mix the old gas with fresh gas, which, go figure, dissolves the "residues" and makes the gas usable again (although its recommended to use the blend immediately). As far as residues coming from the station, unless it is some Maw and Paw joint that sees barely any business, they are getting fresh shipments of fuel daily, weekly, and occasionally monthly based on traffic. The likelyhood of getting "residue" in your gas from a well-served station is just about zero. Additionally, there are filters in the trucks that deliver, the pumps that dispense, and the fuel filter in your own car that would prevent this "gunk" from entering your engine. Granted, if your gas is really old, the octane rating will be junk, and your car will run like sh*t, but as soon as you add new gas, that problem will solve itself very quickly. So, to summarize, like many stories you hear "from your Uncle," this one is hearsay and complete hogwash. There is no long-term residue built up in your tank unless you are storing the car with an improperly sealed tank for years at a time. As for the crickets...haven't heard mine in months, since it got cooler again. 'nuff said. |
| The Following 8 Users Say Thank You to HunterGreene For This Useful Post: | brandonblt2 (12-18-2015), Cole (12-17-2015), FRSBRZGT86FAN (12-18-2015), Jayzl (06-30-2016), Looshkin (12-18-2015), Tcoat (12-17-2015), TheVoiceOfReason (12-17-2015), Ultramaroon (12-18-2015) |
