#197 |
#198 |
Fast enough
Drives: 2013 Subaru BRZ AT
Just out of curiosity.....is the JRSC maxed out with this smaller pulley? What % of capacity is it running? Just wondering if one could go another tiny step smaller. I think this is a 100mm pulley right? And standard is 110mm? So maybe a 95mm? Just curious.
#199 |
That depends on RPM for your given redline. At 7400, it is at 97% with the 100mm pulley.
#200 |
Fast enough
#201 | |
Drives: JR FR-S,
If you are planning to run E85 most of the time, it really would never be used. Also, guys are running around with 91/E85 flexfuel without the wastage system. We don't recommend using 91 octane with the high boost pulley because the benefit of the additional boost is taken away by the amount of timing you need to pull out. Last edited by Jackson Racing; 12-16-2015 at 04:04 PM. |
| The Following User Says Thank You to Jackson Racing For This Useful Post: | dj2020 (12-16-2015) |
#202 |
#203 |
Drives:
Has any testing be done with supercharger efficiency past stock redline with built heads and upgraded valvetrain?
#204 | |
If the engine is free flowing, then the SC will keep reving. Example: S2ks rev higher, so the supercharger's pulley ratio (vs crank) is higher to spin it "slower per rev". But, up at 9000 (engine) RPMs, it's singing along just as happily. |
#205 |
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release
Couldn't find it on this thread: what are the torque specs for the supercharger pulley bolts?
Also, any pros and cons using a 2.5 vs 3.0 bar MAP sensor on this type of set up? |
#206 | |
Fast enough
![]() I was just curious as to the theoretical max of this supercharger. Thanks for the info though! |
#207 | |
lower map sensor gives you more resolution; higher bar map sensor gives you more theoretical overhead. Both will be fine for a JRSC. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dj2020 (12-17-2015) |
#208 | |
Googled and got these specs: http://www.rotrex.com/media/7df7470f...30%20Range_pdf Mounting torque pulley bolt: looks like it's M10 bolts, torqued to 37 ft-lb. Much higher than the oil banjo and and bracket mounting bolts. Anyone, please correct me if I'm wrong because it does seem awfully high for such small bolts. Also, any brand map sensor is okay? All similar quality? |
#209 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Rapiddan45 (12-17-2015) |
#210 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | dj2020 (12-17-2015), Jackson Racing (12-18-2015) |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
