Old 12-15-2015, 10:46 PM   #197
dj2020
This is something CSG and Shawn have experience with; it's been around for years, even on this platform
Do tell us more! I'm wondering if I should go a pure tune route through Church to make 91 safer or should I explore this wastegate/boost control option.
dj2020 is offline   Reply With Quote
Old 12-15-2015, 10:53 PM   #198
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Just out of curiosity.....is the JRSC maxed out with this smaller pulley? What % of capacity is it running? Just wondering if one could go another tiny step smaller. I think this is a 100mm pulley right? And standard is 110mm? So maybe a 95mm? Just curious.
xsnapshot is offline   Reply With Quote
Old 12-15-2015, 10:59 PM   #199
CSG Mike
CSG Mike's Avatar
That depends on RPM for your given redline. At 7400, it is at 97% with the 100mm pulley.
Old 12-16-2015, 12:12 PM   #200
xsnapshot
Fast enough
Let's say you left redline at 7400. What would a 95mm pulley put the blower at? My guess is over 100%, but by how much would be the question.
Old 12-16-2015, 03:50 PM   #201
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Originally Posted by dj2020 View Post
I'm thinking of doing this soon and Shawn Church says it's no problem for him doing a 91/e85 flex fuel tune. I'll probably run e85 full time but he says he can make it safe when on 91 for road trips.
He also said something interesting that I never thought of, which is to add a wastegate to the intake tube to limit your boost to 9psi on the HBP. That would be another way of making the HBP safer for 91 octane. I did some research and it looks like a lot of domestic muscle cars on centrifugal SCs will run a higher boost pulley but limit the actual boost at the top end with a wastegate. That way you'll have higher boost levels at a lower rpm. Just thought I'd share and have a discussion.
Yeah, we have done this on different applications. There are additional components, cost, and complication associated with it. But yes, it works.
If you are planning to run E85 most of the time, it really would never be used. Also, guys are running around with 91/E85 flexfuel without the wastage system. We don't recommend using 91 octane with the high boost pulley because the benefit of the additional boost is taken away by the amount of timing you need to pull out.
Jackson Racing is offline   Reply With Quote
The Following User Says Thank You to Jackson Racing For This Useful Post:
dj2020 (12-16-2015)
Old 12-16-2015, 04:06 PM   #202
CSG Mike
CSG Mike's Avatar
About 102%.
But, you need to leave overhead for slight overrevs. Don't do it. You *will* destroy your supercharger.
Old 12-16-2015, 04:10 PM   #203
DaiTT500
DaiTT500's Avatar
Drives:
Has any testing be done with supercharger efficiency past stock redline with built heads and upgraded valvetrain?
DaiTT500 is online now   Reply With Quote
Old 12-16-2015, 04:28 PM   #204
CSG Mike
CSG Mike's Avatar
That's more of an engine efficiency question, than supercharger.
If the engine is free flowing, then the SC will keep reving.
Example: S2ks rev higher, so the supercharger's pulley ratio (vs crank) is higher to spin it "slower per rev". But, up at 9000 (engine) RPMs, it's singing along just as happily.
Old 12-16-2015, 04:44 PM   #205
dj2020
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release
Couldn't find it on this thread: what are the torque specs for the supercharger pulley bolts?
Also, any pros and cons using a 2.5 vs 3.0 bar MAP sensor on this type of set up?
Old 12-16-2015, 07:03 PM   #206
xsnapshot
Fast enough
About 102%.
Oh I'll never need more power than the highboost pulley provides
I was just curious as to the theoretical max of this supercharger. Thanks for the info though!
Old 12-16-2015, 10:15 PM   #207
CSG Mike
CSG Mike's Avatar
locktite red and... something low.
lower map sensor gives you more resolution; higher bar map sensor gives you more theoretical overhead.
Both will be fine for a JRSC.
dj2020 (12-17-2015)
Old 12-17-2015, 12:54 AM   #208
dj2020
Googled and got these specs:
http://www.rotrex.com/media/7df7470f...30%20Range_pdf
Mounting torque pulley bolt: looks like it's M10 bolts, torqued to 37 ft-lb. Much higher than the oil banjo and and bracket mounting bolts. Anyone, please correct me if I'm wrong because it does seem awfully high for such small bolts.
Also, any brand map sensor is okay? All similar quality?
Old 12-17-2015, 12:57 AM   #209
CSG Mike
CSG Mike's Avatar
Jackson Racing also offers a MAP sensor now; PM @CounterSpace Garage to get one.
Rapiddan45 (12-17-2015)
Old 12-17-2015, 01:29 AM   #210
CSG Mike
CSG Mike's Avatar
Torque to 9ft lbs, per the Installation Manual from JR.
dj2020 (12-17-2015), Jackson Racing (12-18-2015)
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
