Old 12-14-2015, 09:21 PM   #57
dill916
http://www.carjoying.com/quad-core-a...vr-steeri.html
on the website above it states;
"Bulit-in WiFi, Support 3G/4G/Wifi hotspot sharing"
so do i get free data to this radio?
dill916 is offline   Reply With Quote
Old 12-14-2015, 09:31 PM   #58
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by dill916 View Post
do you need some sort of data plan for this radio?
You need some form of internet connectivity, whether it's tether through your phone or a mobile hotspot. Actually you don't need internet, unless you want to do things that need internet
Sent from my XT1096 using Tapatalk
B-R-Z is offline   Reply With Quote
Old 12-14-2015, 09:44 PM   #59
dill916
ah so I could just connect via bluetooth and run off my phones data as the stock radio does. Great! I am a big android fan. Not many radios like to recognize my Oneplus One phone via USB cable and the Bluetooth in my car is random when it decides to connect so i think i will be purchasing this in the future. Much appreciated!
Old 12-15-2015, 01:38 PM   #60
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
So this is where the mic connects and this is the mic it came with. Where do you guys suggest I should put it? Tia!
Sent from my SM-N920P using Tapatalk
eurominican e u r o m i n i c a n
eurominican is offline   Reply With Quote
Old 12-15-2015, 09:02 PM   #61
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
I suppose this location would give you the best results?
Although it looks soo weird sticking out the dash console like that. Is there noway to reuse the oem mic?
shadoken is offline   Reply With Quote
The Following User Says Thank You to shadoken For This Useful Post:
eurominican (12-16-2015)
Old 12-16-2015, 03:13 AM   #62
eurominican
Great idea! I was thinking running the cable behind A pillar and putting mic ant the top but here looks more discrete. Thanks!
It's been said in this thread you would have to solder to be able to use stock mic unfortunately.
Old 12-17-2015, 12:01 PM   #63
eurominican
So where do you put the antenna wire?
The diagram/instructions say to wire it to blue cable but that's the pin everyone says to move from pin 8 to 9 (or viceversa) to make the stock amp work for the door speakers so tap that wire for the stock antenna power?
EDIT: I tapped the blue wire and it works fine.
Old 12-17-2015, 12:34 PM   #64
B-R-Z
B-R-Z's Avatar
I believe I connected the antenna booster wire to the amp remote turn on wire, usually it's blue
Old 12-17-2015, 03:53 PM   #65
eurominican
Got you.. I soldered the amp remote to it. Will also tap it for the antenna booster then..
Thanks!
Old 12-17-2015, 03:58 PM   #66
eurominican
So there's no use for this plug? The harness that came with the HU does not match
Also, I got this adapter for the stock usb port and it does not fit... and there are a bunch of people in the amazon product page saying that it does. Smh....
Metra AX-TOYUSB-2 2010-Up Toyota USB Adaptor https://www.amazon.com/dp/B00EAYYQDO
Bunch of liars!!! (Unless I'm missing something)
Old 12-17-2015, 04:46 PM   #67
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Lol those reviews ... Looks like the seller listed the wrong item.
Old 12-17-2015, 06:46 PM   #68
B-R-Z
B-R-Z's Avatar
Edit: Links fixed
Here are the exact parts I bought to connect my radio to my car. Copied directly from my amazon order history. These all fit and work:
[ame="http://www.amazon.com/gp/product/B00BXF5A74?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s01"]Axxess AX-TOY28SWC Steering Wheel Controller Add-On Harness with RCA and 28-Pin Connector for Toyota Vehicles [/ame]
[ame="http://www.amazon.com/gp/product/B003VYWSES?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s01"]Metra 40-LX11 Lexus Antenna Adaptor Cable 2002-Up[/ame]
[ame="http://www.amazon.com/gp/product/B00EAYYQDO?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s00"]Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles [/ame]
The Following 3 Users Say Thank You to B-R-Z For This Useful Post:
Binary_fission (12-17-2015), eurominican (12-17-2015), ricotheraccoon (03-01-2016)
Old 12-17-2015, 07:22 PM   #69
eurominican
Thanks you've been great help in this thread! I have a base FRS with no controls on the steering wheel but those who have premium BRZ will greatly appreciate the part # for the controls!
Sidenote - amazon is amazing, they refunded the charge for the wrong usb adapter, didn't ask for it back
Old 12-17-2015, 10:13 PM   #70
B-R-Z
B-R-Z's Avatar
This post might be helpful. It does specify that you need AX-TOYUSB not AX-TOYUSB2 like you purchased.
http://www.ft86club.com/forums/showp...postcount=1645
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 01:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 12:55 PM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 12:57 PM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 03:42 AM
