go_a_way1
Old 12-10-2015, 04:16 PM   #57
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by Summerwolf View Post
Its probably a cost thing.
If they sell you a precut pipe....wouldn't they just be selling you a catback? Which he says they are preparing to offer as well. So.... it makes sense, multiple options at differing price levels. This is all prototype stuff still anyways.
Very true only time will tell, so far it all looks promising.
Very interested in the header.
Old 12-10-2015, 04:28 PM   #58
SoCal996JT
SoCal996JT's Avatar
Drives: 2016 Scion FR-S
Thumbs up
+1....thank you for explaining.
SoCal996JT is offline   Reply With Quote
Old 12-10-2015, 04:58 PM   #59
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by SoCal996JT View Post
Yeah, when I dropped off the vehicle, they did not mess around, it went straight to the dyno to get a baseline. They are working on the cat backs now and if all goes well, they said they would be working on a UEL header next week.
They should have started with the header first.
Catback's and the remainder of the exhaust will most likely require a redesign after they remove the major source of exhaust noise suppression... the factory header... Just sayin
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
Cole (12-16-2015), JazzleSAURUS (12-10-2015)
Old 12-10-2015, 06:16 PM   #60
icybrzzz
Drives: 2015 Scion frz
I must say those exhausts look really GOOD!
Looking forward to seeing the finished product and the UEL.
icybrzzz is offline   Reply With Quote
Old 12-10-2015, 09:15 PM   #61
nimble
nimble's Avatar
Drives: 2013 WO FR-S
Wow looks really good! If the rest of the specs are up to par, sign me up for one!
nimble is offline   Reply With Quote
Old 12-16-2015, 11:25 AM   #62
SoCal996JT
SoCal996JT's Avatar
Guys, I just gave Holley a call and I will be going over there after lunch to check out the UEL catless header and header w/ cat prototype.
I also talked to them again about this forum and it looks like they will be purchasing a company FR-S for their long term development. They really want to be involved on this platform and want to offer the best possible solutions since they are late to market. They also are throwing around the idea of a tuner but that takes 6-9 months from start to finish of development.
Pics to come!!!!!!
The Following 3 Users Say Thank You to SoCal996JT For This Useful Post:
kmbkk (12-16-2015), nickmerronesucks (12-16-2015), Teseo (12-17-2015)
Old 12-16-2015, 04:04 PM   #63
SoCal996JT
SoCal996JT's Avatar
Guys, here are some shots of the prototype UEL header and the header w/ cats. I had very limited time but I managed to take some installed shots of the UEL header on and off my car but only had a chance to shoot the header w/ cat off my car.
I do really like the "race inspired" thermal expansion spring slip joint set up over the flex pipes on the market right now, plus, the engineer in charge said that he choose the slip joint/spring design since it flows better than flex pipes, plus it makes install easier since the cylinder are opposing sides.
I should get the car back for the holidays with the header w/ cats prototype on as they would like for me to drive it 500 to 800 miles to ensure the CEL does not emit.
The Following 7 Users Say Thank You to SoCal996JT For This Useful Post:
BWilky (12-17-2015), Cole (12-16-2015), DAEMANO (01-03-2016), G-awesome (12-16-2015), Hyper4mance2k (12-16-2015), Teseo (12-17-2015), venturaII (12-17-2015)
Old 12-16-2015, 07:41 PM   #64
churchx
churchx's Avatar
Drives: 2014 GT86
Thermal expansion spring slip joint .. imho redundant. Several headers out there without them and not showing up any problems due that, but it will make production more expensive. Instead of those slip joints i'd rather spend design/manufacturing budget to get longer runners in and shallower angle merges by eliminating those short tubes pre/post cat, or between merge point and header flange.
Also any aftermarket header can sooner or later throw out CEL, even catted ones. Even with spacers for O2 sensor. Hence i wouldn't spend lot of time on trying to avoid that, but would rather concentrate efforts on fine tuning ecu tune to get most power out of headers. Tune will take care about CELs anyway.
The Following 3 Users Say Thank You to churchx For This Useful Post:
JazzleSAURUS (12-17-2015), Shark_Bait88 (12-17-2015), wparsons (12-17-2015)
Old 12-17-2015, 10:07 AM   #65
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Nice work OP.
I agree with churchx, and would like to see pics of the collector.
JazzleSAURUS is offline   Reply With Quote
Old 12-17-2015, 10:20 AM   #66
SoCal996JT
SoCal996JT's Avatar
They also did it not only for thermal expansion but also make it an easier install the for the consumer. Having opposing ends, it allows you to close up/lengthen the flange to get it accurately over the studs.
I will drive it for the holidays after they dyno and need about 500 to 800 miles with multiple key cycles so we'll see if my car emits a CEL. I should get it back this Friday.
Old 12-17-2015, 10:24 AM   #67
SoCal996JT
SoCal996JT's Avatar
Originally Posted by JazzleSAURUS View Post
Nice work OP.
I'll try to get collector shots Friday when I pick up the car. From what the engineer was trying to explain to me, they choose a mitered merge collector over a formed collector to precisely tune the collector length/volume instead of universal formed collectors and the mitered merge collectors also allow more length to the primary tubes.
Old 12-17-2015, 10:24 AM   #68
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
If the collector looks good its probably going to be a more competitively priced alternative to Tomei. I am actually glad some large American companies are taking interest in this vehicle.
Old 12-17-2015, 12:05 PM   #69
Teseo
Drives: frs
Good, the tubes did not aproached to the oil pan
Edit: any warranty for headers? In for videos
Old 12-17-2015, 12:29 PM   #70
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Didn't notice any mention of it in the thread...have there been any hints as to pricing?
Headers RS performance paoness Engine, Exhaust, Transmission 2 04-06-2015 05:41 PM
MXP Performance Equal Length Headers jordanrw260 Engine, Exhaust, Transmission 13 06-27-2013 10:00 AM
Lachute performance headers! grostoine Engine, Exhaust, Transmission 0 04-23-2013 08:05 PM
Lachute Performance Headers Cotnoir Engine, Exhaust, Transmission 54 08-02-2012 11:23 PM
