Old 05-24-2012, 01:57 PM   #1
MindtheGap
Drives: Ultramarine FRS mt
FRS aftermarket head unit installation - wiring
I apologize in advance if already talked about, but I r search not grood.
Imo bespoke is overpriced and going aftermarket, already have a couple in mind, but open to some suggestions as long as it doesnt thread jack.
What I really want to know is the about wiring up an aftermarket head unit. I maybe jumping the gun, but any plug up harnesses work or maybe a universal type? I really want to avoid any hard wiring/cutting this early.
MindtheGap is offline   Reply With Quote
Old 05-24-2012, 02:19 PM   #2
Jay Grey
Jay Grey's Avatar
Drives: 2013 BRZ Limited DGM MT
I would just hold off till they come out with a kit for the wiring harness to aftermarket head unit. Def dont do any mess with any hard wiring or cutting. You dont wanna take the chance of messing anything up.
My Car Journal Thread: The GreyRZ Build
Jay Grey is offline   Reply With Quote
Old 06-04-2012, 05:22 PM   #3
keithbribac
Drives: Gray
I'm planning to install a new headunit in the next couple of days. I pulled out the factory headunit. It looks like the harness is a regular toyota one on the left. All the way to the right looks like the antenna plug. Is this a subaru antenna?
Heres a pic of the antenna male plug. There's 2 identical plug. On the left was plugged into the head unit and both ones I'm holding was not used by the factory headunit.
keithbribac is offline   Reply With Quote
The Following 4 Users Say Thank You to keithbribac For This Useful Post:
normancw (06-04-2012), Scooby (06-05-2012), SVXdc (07-02-2012), wheeladdict (06-05-2012)
Old 06-04-2012, 08:51 PM   #4
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
I installed a new head unit already. I used the regular toyota harness and it worked just fine. Be sure to hook up the remote/power antenna wire because it turns on the amplifier in the trunk that runs the door speakers. I forgot to hook this wire up and the stereo sounded horrible.
The antenna adaptor is for 02+ Lexus. The exact model I used was Scosche LSAAB.
The dash kit is a different story. I used the Metra dash kit for a Scion TC, but I had to modify it quite a bit. I just used a dremel tool to trim the kit until it fit on the FR-S bracket. It works quite well now.
Nitro is offline   Reply With Quote
The Following 4 Users Say Thank You to Nitro For This Useful Post:
civicdrivr (06-17-2012), CoRi J (06-17-2012), Fly Guy (06-17-2012), wheeladdict (06-05-2012)
Old 06-04-2012, 10:20 PM   #5
keithbribac
Drives: Gray
where do u hook up the remote/power wire? to the toyota harness, lexus harness, or to the cars wiring? and why does the lexus harness have two plugs?
Old 06-04-2012, 10:33 PM   #6
Nitro
Nitro's Avatar
It is just a blue wire on the toyota harness and it should be labeled "power antenna". Hook it to the blue wire with the white stripe coming out of an aftermarket that should be labels "remote".
I don't know why the lexus harness had 2 plugs, but I only used 1.
Old 06-05-2012, 07:03 AM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Pics, please. Even of just the finished product.
Old 06-07-2012, 03:26 AM   #8
keithbribac
Drives: Gray
here's mine
and another one
The Following 2 Users Say Thank You to keithbribac For This Useful Post:
Liquidsnake (06-21-2012), normancw (06-07-2012)
Old 06-07-2012, 03:44 AM   #9
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
here's mine
8400? Looks great. This is the deck I'm going with if/when I decide to replace the stock deck in the BRZ.
Symbiont is offline   Reply With Quote
Old 06-07-2012, 05:25 PM   #10
-max-
Drives: Firestorm FRS
RCAs? Interesting.
-max- is offline   Reply With Quote
Old 06-07-2012, 05:44 PM   #11
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Hi, I would like to pull my radio out of my FRS and was wondering if I may ask for the correct way to do it as not to destroy anything? Do I need any special tools? Thanks in advance.
Roadstercycle is offline   Reply With Quote
Old 06-07-2012, 06:29 PM   #12
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Originally Posted by -max- View Post
RCAs? Interesting.
I'm pretty sure those RCAs are for the Subwoofer pre-out.
Lil Abner is offline   Reply With Quote
Old 06-07-2012, 06:31 PM   #13
Lil Abner
To remove your headunit, try this:
Using a pry tool (I like plastic ones), pull the bottom slightly out
Now, the hard part is carefully wiggling the panel straight out from the radio. There are 4 clips: 2 on top, 2 on bottom. It's hard to get pry tools in the top, so be patient. Try and pull out, but firmly. DO NOT pull on an angle!!
Once the panel is removed, you'll see this:
You should know what to do from this point on.
The Following 13 Users Say Thank You to Lil Abner For This Useful Post:
4Running Daily (06-06-2013), Bonburner (01-11-2013), buzznasa (06-29-2013), calis5nest (01-29-2014), dsgerbc (06-09-2012), encity5 (06-10-2012), Fly Guy (06-09-2012), Kamakanani0 (10-03-2012), Liquidsnake (06-21-2012), lordtakuban (07-18-2012), Roadstercycle (06-17-2012), SubaruOnlineParts.com (08-02-2012), SVXdc (07-02-2012)
Old 06-09-2012, 11:07 AM   #14
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
EDIT: sorry should have said does the stock voice command run through the head unit or will you have to use a separate mic for that?
CoRi J is offline   Reply With Quote
BRZ NAV unit play DVDs when in park? Mango22 Electronics | Audio | NAV | Infotainment 15 09-06-2013 02:28 PM
TRD parts installation manual Nardi330 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-21-2012 03:19 AM
chrome fender trim installation taosracer Cosmetic Modification (Interior/Exterior/Lighting) 1 05-15-2012 03:13 PM
BRZ Nav Unit owner's manuals eikond Electronics | Audio | NAV | Infotainment 0 04-11-2012 04:07 PM
Removal of Radio/Infotainment Unit Captain Snooze Electronics | Audio | NAV | Infotainment 6 03-20-2012 07:46 AM
