Old 12-06-2015, 12:37 AM   #1
Dreyup
Dreyup's Avatar
Drives: 2015 Scion FRS
Tamara tow strap
If anyone is interested in knowing how to do this ill post pictures or any questiins..
Sent from my VS985 4G using Tapatalk
Dreyup is offline   Reply With Quote
Old 12-06-2015, 05:43 AM   #2
TheMuffinMan
Slowpoke
TheMuffinMan's Avatar
Drives: FR-S Whiteout MT
Can you explain how you mounted it? More pictures would be appreciated as well.
TheMuffinMan is offline   Reply With Quote
Old 12-06-2015, 07:38 AM   #3
Dreyup
Dreyup's Avatar
So I been meaning to put this strap on for awhile now just didn't exactly how to do it because I didn't wanna drill into the car and because of the 2 diffrent sizes of bolts,one of the bolts is 7/16 which goes on the strap and the other was what comes with the car oem hook, So I had no other sulotion but to use the oem thread and the 7/16 that were both cut with a big industrial saw,welded all the way around(oem bolt is a zinc metal "which is bad to be smelling while welding because of the coding it has", and the 7/16 was a stainless steel),So I measured how much of the strap I wanted out I took the oem hook and tighten it all the way and marked it so that was my length. One also has to heat up the stainless in the strap to bend what ever way they like, I'll post lengths to both of the threads and stuff in the morning if you'll like ... But does it work to actually pull you out a ditch who knows I believe it will it's only 2700 pounds but my intentions were not to make it functional but just for looks and just did that ...
Old 12-06-2015, 07:42 AM   #4
Dreyup
Dreyup's Avatar
Old 12-06-2015, 01:47 PM   #5
8R6
8R6's Avatar
Drives: FRS
"Tamara"?
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
JustBoostin (12-08-2015)
Old 12-06-2015, 01:49 PM   #6
Dreyup
Dreyup's Avatar
Originally Posted by 8R6 View Post
"Tamara"?
Takata*
Old 12-06-2015, 02:04 PM   #7
stugray
Drives: 2013 GBS BRZ Limited
The strap type look to me like they will flap in the wind and mar the paint.
Old 12-06-2015, 03:56 PM   #8
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Thats what I'm thinking as well, also I like the look of tow hooks better. Straps look a little, off or out of place.
YamahaR86 is offline   Reply With Quote
Old 12-06-2015, 05:11 PM   #9
Dreyup
Dreyup's Avatar
I havents had trouble with it maring paint plus i use to detail cars so it's not big deal it that's a problem.
Old 12-07-2015, 11:57 AM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Why did you not just go through the factory hole/mounting point?
Why can't you take a photo straight on either :p
Old 12-07-2015, 12:05 PM   #11
Dreyup
Dreyup's Avatar
Less pain, and the car was in the garage when I installed it I'll get better pictures
Old 12-12-2015, 07:56 PM   #12
Dreyup
Dreyup's Avatar
The Following 2 Users Say Thank You to Dreyup For This Useful Post:
Alaa86 (06-17-2016), SkAsphalt (12-14-2015)
Old 06-17-2016, 07:25 AM   #13
Alaa86
Drives: White 86 W/ Aero Bodykit
Wink
Im installing mine soon and I wanted to know whether it damaged the paint or not.
Im installing it for the looks and not planning to cover it.
Plz update us.
Alaa86 is offline   Reply With Quote
Old 07-09-2017, 05:03 PM   #14
Ninjadanny
Drives: Scion FR-S
Hi
Plz update us.
Hey did you did your already ? And how is it ?
I plan to intall it too Takat tow strap in the front. I wanna do something like in the picture.
Do you guys have some picture of how you merge the 2 component to attach it inside ? Im looking for a tool to attach this.
Ninjadanny is offline   Reply With Quote
Fs: TRS tow strap $30 Sold. Jcl Exterior Parts (Aero, Lighting, Etc.) 3 06-04-2015 04:26 PM
Takata tow strap Thatguyjeremy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-20-2015 10:25 AM
FS: Takata Tow strap Tengu Exterior Parts (Aero, Lighting, Etc.) 1 02-26-2014 09:36 AM
rear tow strap karma003 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-23-2013 10:00 PM
Help me strap down my tires qoncept Tracking / Autocross / HPDE / Drifting 5 06-20-2013 05:06 PM
