Old 09-29-2015, 06:28 PM   #85
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by DGM33 View Post
FWIW, I had this problem a few times but found that it NEVER happens if I only use Manual mode. It only happens if I've been in Auto and then switch to Manual. So I use either one or the other when I'm driving and don't switch back and forth and have no issues.
Yup I described that earlier, it only occurs when your driving along in auto mode for a while then decide to go to manual mode it will randomly occur, if I start the car and go straight to manual mode it doesn't appear and works beautifully hopefully the TSB fixes the TCM logic and gets rid of the issue
Old 09-30-2015, 12:20 AM   #86
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Time for @Cole to get a reflash
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Cole (09-30-2015)
Old 09-30-2015, 08:46 AM   #87
Cole
Not a troll
Cole's Avatar
Dat reflash doe.
I'll get it done with my dealership oil change on Thursday or Friday
Cole is offline   Reply With Quote
Old 09-30-2015, 12:55 PM   #88
FRSBRZGT86FAN
Originally Posted by Cole View Post
Dat reflash doe.
Originally Posted by casemanase View Post
I think I have a way to reproduce it. I always noticed that it showed up when I was in manual, switched to Drive for whatever reason - cruising on the highway with heavy traffic, etc. - and then when going back to manual, rev matching stops working and all of my shifts are jerky, more from 1-2 and progressively better, almost unnoticable 5-6.
I found that if I drive about 2 miles, change back to drive, WOT and let automatic do 3-4 shifts, when I go back to manual it starts doing it. I am not switching to manual right away, usually doing 20-40, then once I let go of the throttle and it is realtively stable, I switch back to manual mode.
I just left the dealer for my 12,000 tuneup and had him make notes that this had been happening. I don't want to suffer from transmission issues because the ECU or whatever is managing rev matching, is forcing my car to beat on the tranny. This first showed up at 300 miles with no spirited driving, and I don't believe I had even broken 2500 RPMs at that point.
I'll be taking this back if I can get some dry days around here to test it a little more - it always happens when the dealer is closed...
I have attached the TSB document for you guys to print out and give to a tech
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Cole (09-30-2015)
Old 10-01-2015, 01:30 AM   #89
redmoon
Drives: 2015 LR Subaru BRZ
Anybody knows if there is a similar TSB for us BRZ guys or do you think that we can bring the Scion TSB to a Subaru dealership and able to get the TCM reflashed? I hope we're not shit out of luck. Thanks!
redmoon is offline   Reply With Quote
Old 10-01-2015, 04:14 AM   #90
FRSBRZGT86FAN
We don't really even know if it'll fix the shifting issue yet it's just a hunch, however you should get a tsb soon, I can't access the subaru equivalent of techstream
Old 10-04-2015, 01:55 PM   #91
Cole
Not a troll
Cole's Avatar
Thanks for the attachment. Took it in with me to get it done with my oil change on Friday.
Apparently it's a US only TSB, so the dealership refused to do it. Guess I'll have to patiently wait.
Old 10-22-2015, 09:51 PM   #92
FRSBRZGT86FAN
Created this thread to gauge the issue here guys:
http://www.ft86club.com/forums/showthread.php?t=96615
Old 12-04-2015, 02:11 AM   #93
casemanase
casemanase's Avatar
Drives: '15 CWP BRZ
TCM,huh? I haven't noticed a hunting idle, but I did have my dealership in Florida report it to Subaru (I made sure it was on my warranty maintenance notes anyway). I'll recreate it again this weekend (It does take about half an hour of driving it seems). I can slam it in and out of manual and auto for the first 10 -15 minutes without the issue.
casemanase is offline   Reply With Quote
Can't downshift while warming up HMX-92 Issues | Warranty | Recalls / TSB 25 12-20-2014 03:20 PM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
