Pat.Thornton
Old 12-02-2015, 10:00 AM   #351
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
There must be some water or moisture getting underneath the boot where the clutch fork meets the slave cylinder. Every time it rains for a long period of time the clutch will squeak louder.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-02-2015, 03:31 PM   #352
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by ZZT86 View Post
3 months ago I cleaned/lubed the point where the slave actuator rod meets the clutch fork & it worked a treat . . . . up until now :/ Strange thing is that it's stopped squeaking again but I'm sure not for long.
I'm no expert on this but I'm guessing as it gets so damn dusty/dirty under hood so quickly on these cars that the paint/coating on the fork receptacle has scratched & started to corrode where the ball end of the actuator meets/touches as a result of scuffing which I reckon is causing the squeak. Cleaning the area of all contaminated grease & re-greasing it seems a temporary fix unless I protect the area of dirt.
When that squeak comes back I will clean/lube as done previously (see foot of p13 as per quoted @Ultramaroon instructions) & figure out a solution to prevent anymore dirt attaching itself to the fresh grease - worth a try I guess.
That's definitely worth a try. My dealer dropped my clutch multiple times replacing multiple things including throw out bearing and pressure plate. The noise didn't go away and it ended up all they had to do was what Ultramaroon explained there.
Old 12-02-2015, 03:55 PM   #353
zonda
Drives: 2014 WRB BRZ
notice mine gets worse as i drive for longer periods of time. i sometimes get scared pressing my clutch in driving home from work now ):
zonda is offline   Reply With Quote
Old 12-02-2015, 06:55 PM   #354
track junkie
Drives: 2022 Subaru BRZ
Maybe this Technical service bulletin from Subaru will help.
12-190-15R, Oct. 30, 2015, "Elimination of Creaking Sound from Clutch Pedal Assembly."
"This BRZ bulletin provides a procedure to address customer concerns of a creaking sound heard when operating the clutch pedal. The cause of the sound has been identified as a very slight amount of movement between the 2 layers of metal (circled in yellow) which form the specific clutch and brake pedal assembly mounting bracket shown in the illustration and photos."
track junkie is offline   Reply With Quote
The Following User Says Thank You to track junkie For This Useful Post:
bhbnuckle (06-29-2016)
Old 12-02-2015, 06:56 PM   #355
Synack
Boosted
Synack's Avatar
Drives: Sideways
Sooooo spray some lithium grease on the clutch fork and call it a day?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 12-02-2015, 07:33 PM   #356
Sigh-on-Rice
I wouldn't use spray, although it might work. If something worked well, I would just follow that instead of trying something else that might not work. And even if you use the proper grease, you can call it a day only if you're lucky. If you're unlucky, then you need to drop the tranny to get rid of the noise.
There are 2 points. One is easy, the other requires pulling the geabox.
Locate the point where the slave actuator rod meets the clutch fork.
Have a little grain-of-rice sized dab of grease ready on your thumb.
With the same hand carrying the grease, pull the clutch fork forward, collapsing the slave actuator a little bit.
Then, while holding the rod with the other hand, squish that little dab of grease into the mating receptacle and let the rod seat itself back in.
If that doesn't do the trick, it's time to drop the tranny.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Ultramaroon (12-02-2015)
Old 12-02-2015, 07:34 PM   #357
Sigh-on-Rice
Yes, I want to see this TSB, but can't find it anywhere.
ZZT86 (12-02-2015)
Old 12-02-2015, 08:55 PM   #358
That one isn't the creak. It's a clicking sound. I have it. DGAF because I recognize it. A friend had it. We both laugh now because after giving him a hard time about sweating it, I helped him re-seat his bracket.
It worked for a week or so.
Sigh-on-Rice (12-02-2015), ZZT86 (12-02-2015)
Old 12-02-2015, 09:42 PM   #359
No. Specifically, the service manual calls for Nichimoly N-130 or equivalent.
ConocoPhillips Multiplex Red #2 is an equivalent. Focus on Lithium complex, extreme pressure, high temperature, high tack. There are plenty of similar products out there.
Old 12-03-2015, 09:04 PM   #360
DaTruth
DaTruth's Avatar
Drives: 2014 Firestorm Scion FR-S
Bought mine pre-owned in October, just started squeaking last week. Here we go. At least I work at a Toyota Dealership.
DaTruth is offline   Reply With Quote
Old 12-07-2015, 08:38 PM   #361
ZZT86
ZZT86's Avatar
Drives: BR86
Soooo the squeak came back, car was hot & ambient air temps were also warm, I press the pedal and the squeak is evident, I pulled back on he clutch fork once or twice & noticed no noise. I went back into the car & pressed the clutch & . . . . . . you guessed it no squeak . . . . . . !?
ZZT86 is offline   Reply With Quote
Old 12-07-2015, 11:24 PM   #362
I know. Drives me insane.
Old 12-07-2015, 11:33 PM   #363
ravisraval
Drives: 2013 FRS
Subbed
ravisraval is offline   Reply With Quote
Old 12-11-2015, 10:00 PM   #364
Tt3Sheppard
I'm starting to think that the spring, master cylinder push rod, or the master cylinder piston assembly is what is causing the squeak noise. I've searched other cars online that have this noise while the car is off and on. The clutch squeak noise in those videos sounds identical to my problem and I'm sure many others here as well. I will try and get some videos tomorrow if the squeak decides to be loud tomorrow. I have also upgraded my clutch slave and that did not fix the problem.
[ame="https://www.youtube.com/watch?v=UmMCdWJczIA"]2009 WRX Squeaking Clutch - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=WJ8v9ajrf9I"]Worst 350z Clutch Pedal Squeak/Creak - YouTube[/ame]
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
radroach (12-12-2015)
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
