#169 | |
1337
Drives: 2013 BRZ WRB S/C
1) Can you update the f/r bias chart you did to include sport front and sport rear? 2) I noticed the sport rear has only BP20 as a pad option, but the sport front defaults to BP10 pad - is there a reason for that? Should they be matched if you order both? I don't want squeal, and I mostly daily drive on the street (99.5% of the time )3) Also the sport rear has a high-downforce option - I assume the default for this should be the non-high downforce if you don't have a giant wing? 4) The rotor pictured for the front sport kit has one direction slots, but the rear has opposing direction slots, are the pictures correct? Thanks again! |
| The Following User Says Thank You to djdnz For This Useful Post: | Lynxis (11-18-2015) |
#170 | |
Drives: 2014 Ultramarine FR-S
If the Stage I kit requires less clearance does the Stage I front kit fit the stock wheels without a spacer at all? The last post I saw mentioned something about 10mm. Maybe that was the Stage II and I was misunderstanding...
#171 |
Drives: GT-86
Check your PM
#172 |
Drives: 2015 Subaru BRZ Pearl White
Rafi
How long will the sale on the sport setup for the BRZ run ? Can't find my way clear to make a purchase till the end of Dec. |
#173 | |
Drives: 2013 WRB BRZ 6MT
I don't really see the rear kit as an enticing value proposition compared to the front kit because the pads are listed as only slightly thicker than stock. I'd consider getting the rear kit to have a match to the front kit because I'm OCD like that but it seems the rear rotors have a different slot pattern than the fronts which would bug me. Can you clarify on the rotor setup or any way to get matching rotors if they are different? Last edited by Lynxis; 11-18-2015 at 05:50 PM. |
#174 | |
Drives: Toyota GT86
Yes, regarding BBK fitment for stock wheels, what you wrote is correct. The Sport Performance Rear 4 piston BBK is a huge value proposition because what we achieved is more heat capacity AND a big shift in rear bias which benefits braking performance tremendously. The rear pad wear rate is much less than fronts, so the thickness of the pads is plenty sufficient. You will find that the rear pads will still outlast the thick pads we use on our front BBK's, so this is a non-issue. Next week we will have front rotors that match the Sport Performance kit rears. I will post pics of the new front rotor option that matches rears by next week. Bias chart: |
#175 |
Where would the Sport Performance Front setup fall in that brake bias chart? I think seeing the Sport Performance Front/OE Rear bias and the Sport Performance Front/Sport Performance Rear bias would be helpful. I would assume the 4 piston Front would have a smaller piston area and that would cause the brake bias to be pushed further back. It seems like the Sport performance Fronts with OE rears would be a very attractive setup for budget minded buyers.
#176 | ||
| The Following User Says Thank You to Lynxis For This Useful Post: | ハチロク (11-19-2015) |
#177 | |
#178 |
Can you post pictures with stock wheels please?
#179 | |
Drives: Toyota GT86
All our front BBK kits (Sport Performance 4 piston, or the Stage 1-4 six piston kits) have exactly the same piston area. Sport Performance 4 piston kit is the ultimate budget BBK... and you can get our Sport Performance front AND rear 4 piston kits for less than most reputable front kits alone. It is a great performance and value proposition. Rafi |
#180 |
Drives: GT86-ACE-JRZ-RPF1-Essex
The kit looks really good.
I took that with my phone : |
| The Following 2 Users Say Thank You to MaximeT For This Useful Post: | DAEMANO (11-23-2015), Rafi@RR-racing (11-22-2015) |
#181 |
#182 |
Rafi,
What is your thoughts on mixing the Sport Rears with the compition fronts? I see you have a holiday sale going on, that is a $100 of the purchase of a F/R sport kit. But, would prefer the 6 piston fronts. |
| Tags |
| big brake kit, competition, track |
| AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 08:43 PM |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 06:53 PM |
| AP Racing Factory Big Brake Kit, NOT Competition | Lonergt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 05:51 PM |
| Official street racing thread. All street racing goes here! | bkblitzed | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 07-19-2013 12:31 PM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
