Old 11-17-2015, 10:18 AM   #407
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@NotEric6 @FT-86 SpeedFactory hey guys, I ordered the diffuser through your partner up here in Canada and had a bent strake (+chip on that strake) and a big dent by the leading edge near the diff cutout. After reading the thread here, it occurred to me that I received the V1 packaging as opposed to V2 despite ordering just a couple weeks ago.
I was able to use some simple tools (i.e. hammer + wooden block haha) to get it back into decent shape (but far from perfect) but I'm fairly irked that this happened to something brand new.
1Cor10:23 is offline
Old 11-17-2015, 10:53 AM   #408
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm sorry to hear about your shipping issue. You are going to want to e-mail FT-86 SpeedFactory directly as forum notifications can get lost quite easily. They have made it right in the past, and I have no doubt that they will continue to do so in the future as shipping these large units inevitably will result in some issues along the way. I'm sure they would appreciate it if you send some photos to show them how they can improve packaging in those areas.
I appreciate your patience in this matter and apologize for the "irk" feeling.
VerusEric is offline
Old 11-17-2015, 10:58 AM   #409
1Cor10:23
1Cor10:23's Avatar
@NotEric6 thanks, will do - I think they did improve packaging to resolve but somehow I got the packaging from the first version which doesn't have as much support :/
Old 11-17-2015, 11:37 AM   #410
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
There simply is not any "V1" packaging being done for shipment. After the first couple issues any and all diffusers that leave us to anyone; whether it is an end user or a reseller, they all get double boxed and padded inside of that double box. If someone changes the packaging or takes it out of this secure shell to ship a second time than that is their call. But I can 200% guarantee no diffuser has left our building in months now without them being double boxed. This process has been done for months now.
FT-86 SpeedFactory is offline
Old 11-17-2015, 11:47 AM   #411
1Cor10:23
1Cor10:23's Avatar
@FT-86 SpeedFactory ok, plot thickens...sent you guys an email. I made the order just a couple of weeks ago, my packaging is exactly identical to the one below (courtesy of @ATL BRZ)
Really want to get to the bottom of this, love the product, love your company!
Old 11-17-2015, 11:53 AM   #412
FT-86 SpeedFactory
They still come in that original box, but we box them inside of a box. If that makes sense.
Best way to describe it is Original Box + 1" to 1.5" cardboard/foam padding all sides + inside another box that is thicker with more edge crush test and is side load.
Old 11-17-2015, 11:56 AM   #413
1Cor10:23
1Cor10:23's Avatar
@FT-86 SpeedFactory ugh..I see okay - thanks guys!
Old 11-17-2015, 07:53 PM   #414
lokiwho
lokiwho's Avatar
Drives: 15' Halo FR-S 6MT
I know where was some issues with is fitting over the nameless axleback exhaust as it was rubbing on the muffler passenger side, has this issue been fixed? It says on the website that nameless is a confirmed fitment but just curious what the say is on this issue now.
Thank you
lokiwho is offline
Old 11-18-2015, 01:07 AM   #415
VerusEric
VerusEric's Avatar
Thank you
Yes, I believe it has been as it was a very slight rub on our initial release unit. We then added an additional 1/4" of downward allowance.
Old 11-18-2015, 02:28 AM   #416
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@NotEric6 Any ETA on the Type-80 diffuser?
Bach415 is offline
Old 11-18-2015, 03:43 AM   #417
VerusEric
VerusEric's Avatar
Trying to have it done by end of year but my plate is fairly full from now till then. I'll do my best.
Old 11-18-2015, 03:53 PM   #418
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
That type 80
jdnguyen is offline
Old 12-06-2015, 06:14 PM   #419
VerusEric
VerusEric's Avatar
We finally got the trans tunnel cover cut out and test fit. These will reduce under body drag and can be used with or without JDM under panels. It requires drilling (4) pre-existing holes 63 thou larger for rivet nuts to be installed.
Currently we will utilize spacers to drop the entire plate down lower for various exhaust fitment. If there are other ideas on how to fit various exhausts that sit significantly lower than OEM, we would like to hear these ideas out though. The more of a single design we can produce, the less the end part will be. We have confirmed mounting points which is a great start though.
We plan to coat these in a durable black powder coat like the diffusers. We also plan to continue our way further backwards and tying this into our rear diff/suspension covers if all goes well. Enjoy the pictures.
Thanks,
Eric
Old 12-07-2015, 08:56 AM   #420
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Originally Posted by socal_48 View Post
It fits the RS 1.0
Do you have anymore pics? I've got an RS 1.0 as well and I'm curious to see other angles.
megamarines is offline
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
