Old 10-26-2015, 10:41 AM   #225
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Had it tuned over the weekend. Making 295 @ 8.5psi
FyeaFRS is offline   Reply With Quote
Old 10-26-2015, 01:08 PM   #226
DJCarbine
Thupercharged
DJCarbine's Avatar
91/93 or e85
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-26-2015, 01:32 PM   #227
FyeaFRS
Originally Posted by DJCarbine View Post
91/93 or e85
93
Full VDS Performance catless exhaust
The Following User Says Thank You to FyeaFRS For This Useful Post:
Cal3000 (11-14-2015)
Old 11-10-2015, 10:34 PM   #228
MattHoffman
Drives: BRZ Limited
I am running the 3.12 and making 7.5 peak boost... gotta be belt slip??? how do I know?
MattHoffman is offline   Reply With Quote
Old 11-12-2015, 08:43 AM   #229
FyeaFRS
In regards to?
What belt are you running? I'm currently using the upgraded Gates belt.
Old 11-14-2015, 04:24 AM   #230
Cal3000
Drives: Panda FR-S
What belt are you running? Do you have a mechanical gauge, or are you using the torque app? I know sometimes the torque app falls out of calibration. I've had times when it read I was boosting 2 psi max. I restarted the android OS and later read 9psi. I'm on the 3.48 pulley.
Also, just check you hoses.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-14-2015, 04:30 AM   #231
Cal3000
Drives: Panda FR-S
Originally Posted by w0wbagger View Post
Hey guys,
I just experienced a belt rupture with my Vortech. Well not exactly a rupture in a way that I get a belt with an end and a beginning, but more like a rupture in a way that it has been "cut" into two pieces along the circumfence (if you know what I mean). So to say I now have two belts...
This happend just 5000km after the V-2 has been installed with the 3.125" pulley.
I am wondering if the extra heat by the shared oil with the engine caused a belt failure or of maybe one of my pulleys was not perfectly aligned. Nevertheless I will get the 2.87 pulley installed this wednesday and I already have a Gates HD belt ready for installation.
Do you guys know any alternative for the gates belts? I am looking for a reinforced or extra strong one in particular which is compatible with the 2.87" pulley!
I had the same thing happen to me. With mines, my belt somehow jumped the rib edge of the AC compressor pulley and sheared in half. Since I replaces the belt, I haven't seen that problem since. I believe the belt was not aligned on one of the idler pulleys properly causing it to slowly make its way out of alignment on the AC compressor.
Old 11-14-2015, 04:14 PM   #232
MattHoffman
Drives: BRZ Limited
In regards to?
I have a gates belt and its the right one, I have everything clamped, The boost is being read from the datalogs I am running with OFT. I am also getting the P0451 error code. If thats not related than maybe my bypass valve is letting out too much air? or, the checkvalve isn't working right??? any advice is appreciated.
also i have a catless exhaust system do you think the lack of back pressure would cause a low boost?
Old 12-07-2015, 06:11 PM   #233
sirsol66
Drives: 2013 FRS- Hot Lava
Can anyone with this kit verify how much vacuum at idle is normal? I am logging with an OFT and only seeing 9 inches roughly.
sirsol66 is offline   Reply With Quote
Old 12-08-2015, 09:45 AM   #234
FyeaFRS
I'll let you know this afternoon, I'm thinking like 20 on cold startup, then like 10-15. That's on an autometer mechanical vacuum/boost gauge and I think obd2/dash command was saying about the same.
Update:
So the gauge was reading about 20 at idle after warm up and the obd2 was reading about half that. So I'd say the digital readout isn't that accurate.
Old 12-16-2015, 04:38 PM   #235
austin_ellas
Drives: Asphalt 2014 FRS
How many miles have you guys clocked on your kits? I found a pretty good deal on one from someone local but it has about 25k miles on it. Owner only put it through 2 track days and the rest were from DD'ing. Has anybody developed problems with that kind of mileage?
austin_ellas is offline   Reply With Quote
Old 12-17-2015, 07:36 AM   #236
FyeaFRS
Only a few thousand on mine personally, but as long as they did the fluid changes as they should, it should be good to go.
Old 12-18-2015, 09:24 AM   #237
JetNoise
Drives: Toyota GT86
36K km, except one belt change. Belt was OEM and has been replaced with a quality one. No tracking, only German autobahn and country roads. ;-)
Gesendet von meinem SM-G925F mit Tapatalk
JetNoise is offline   Reply With Quote
Old 12-18-2015, 12:10 PM   #238
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
40,000kms over 2 years which includes 25 track days without any problems whatsoever.
Vortech rules!!
Fish Eagle is offline   Reply With Quote
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
