| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1569 |
Drives: 2016 Halo FRS
what's the reason people run stretched tires? is everyone "stanced"?
or is it because they like the rims to take curb rash before the tire does? not trolling. legitimate question. |
#1570 |
Drives: 2018 Golf R
I foresee this thread going down the tubes.
Sent from my XT1095 using Tapatalk
Parting out HERE
#1571 |
Drives: 2014 GT86
Trust86: stretching reduces sidewall flex. Origin was to stiffen in cheap/hackish way sidewall in normal (cheap) street tires to make sharper turn in/steering by amateur drifters/touge drivers (hmm, wasn't it called "hipari"?). Cheap/hackish way to do that, at expense of smaller contact patch, risking separation of tire from rim, easier to damage wheel sides, heavier wheels (weight increases not just from diameter but also from width). But later it become overhyped, at some scenes seemed cool, and most often then not was done for looks. These days with better tire choice for any taste with any sidewall stiffness and more modern suspensions i see no reasons to do that with practical sense. Why get cons if you can get wished result in normal ways?
#1572 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
The car has more lateral grip and thus negates under-steer better with a wider tire. Yes, the momentum of a wider tire may be higher and therefore turn-in requires more effort and accordingly turn in on a skinnier tire may be 'easier' due to lower momentum but for my money that not does not mean 'better'. I've gone from 215/45/17 to 245/35/18 back to 215/45/17 and now on 255/35/18 in the three years I've owned my car and for me, on balance for spirited back country road driving, wider tires provide a much improved driving experience through grip and stability primarily. The downside is tram-lining and a reluctance to return 'on center' but I got used to these and just enjoy railing corners at speeds that are far in excess of what I've experienced (and are comfortable doing) on skinny road tires. Edit: running staggered tires will not reduce under-steer, it will increase it.
BRZ001: Peace Love and Wheelies @metabrz on IG
#1573 |
001 of 012
iPhone pics
#1574 |
Drives: 86
TOYO R888 - 265/35/18
Camber - F: -3/R: -2 |
#1575 |
Drives: 13' Scion FRS
Hopefully soon enough I'll be a part of this thread...well, I actually already bought the wheels. Just need coilovers and tires. Lol
#1576 |
Drives: 4 wheels
I had similar and it look like I would have to run to aggressive alignment setup, but now I am regretting getting rid of it.
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
#1577 |
Drives: 86
#1578 |
Drives: 2015 BRZ
Ambit 18x9.5 +38
Dunlop Spec star II 265/35 18 front: -1.7 Rear: -1.5 St Coilovers Front Fenders pulled 10MM ![]() ![]() ![]()
#1579 | |
Drives: 2014 BRZ Limited
I see you are running Star Specs. So few people run them. I have them also, 255/40, and I love them. Your setup looks nice
#1580 |
Drives: 2018 Golf R
I used to run them as well but switched to the PSS. They weren't bad but they didn't last long.
Parting out HERE
#1581 |
#1582 |
Drives: Raven Toyota GT86
18x9.5 ET44 + 255/35/18
Got my wheels & tires installed today
Squared setup is as follows: 18x9.5 ET44 (Rota RKR) with 255/35/18 Hankook Ventus V12. Also, my car is lowered around 35mm on Bilstein B14's ![]() ![]() ![]() ![]()
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
