Old 11-04-2015, 07:25 PM   #15
Originally Posted by NatedoggGt86 View Post
OK so my buddy and I just went out in the parking lot and observed. I put pressure on individual heat sheilds and the noise didn't vary. It stays constant with rpm at 2600. It comes from the back of the engine and its definitely something that rotates in neutral.
Well, as far as "in the back" of the engine, the crankshaft, flywheel, pressure plate and throw out bearing (on newer cars), rotate when engine is running and a MT is in neutral.
Maybe the starter knocked a tooth off of the flywheel and the piece gets bounced up and is caught by the flywheel and hits the bell housing at 2,600 rpms .......
humfrz - needs a nap
Old 11-04-2015, 07:29 PM   #16
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Crickets?
Braces is offline   Reply With Quote
Old 11-04-2015, 07:37 PM   #17
NatedoggGt86
NatedoggGt86's Avatar
Drives: 13' Scion Fr-s 6MT
Yeah I have the crickets. I'm dropping it off at the dealer tomorrow. Hopefully I get a straightforward answer. I'll update when its figured out.
NatedoggGt86 is offline   Reply With Quote
Old 11-04-2015, 08:59 PM   #18
NatedoggGt86
Quick update. Drove home, about an hour drive. When I got home I noticed that, with the car parked and in neutral, the car makes a faint noise when the clutch is pressed in. Like a very faint fast paced tapping. Any ideas now?
Old 11-04-2015, 10:27 PM   #19
Now, I reckon, you are talking about a bad clutch throw out bearing .....
Old 11-04-2015, 11:11 PM   #20
NatedoggGt86
How much damage is it doing driving in this condition. It shifts fine. I just know one problem unfixed causes worse problems and I've been driving like this for a few weeks now.
Old 11-05-2015, 12:47 AM   #21
Well, if it is a throw out bearing going bad, it could last several miles before it goes completely dry and freezes up.
It has been my experience (back in the day) that a TOB will start to howl, then scream, before it locks up. Worst case is that it will lock up and tear up the fingers of the pressure plate (thus ruining it).
Very worst case it will lock up, fly apart and the pieces will tear up the clutch disk, which will come unglued and tear up the surface of the pressure plate and the surface of the flywheel.
I wouldn't let it go much past the howling stage.
NatedoggGt86 (11-05-2015), Tcoat (11-05-2015)
Old 11-12-2015, 07:07 PM   #22
NatedoggGt86
Hey fellers. Just picked her up from the shop. The heat shield for the catalytic converter was loose and they had to replace the heat sheild and an exhaust clamp. I guess pretty simple fix. They said the hardware is prone to rusting. But all fixed now! Thanks for all your input.
The Following User Says Thank You to NatedoggGt86 For This Useful Post:
Tcoat (11-12-2015)
Old 11-12-2015, 07:13 PM   #23
BoxerBlock88
Drives: 2013 Scion Fr-s
Hello everybody. New member here just picked up my fr-s 3 weeks ago. Absolutely in love with this thing, just one issue. There is a noise coming from the flywheel area at almost exactly 2600rpm. It sounds lIke the flywheel is making very light contact with something stationary. Metal on metal. It does it in gear, under acceleration, deceleration, in neutral with and without the clutch pressed in. The dealer told me it was an exhaust heat sheild, but the replaced it to no avail. It did sound very similar to a heat sheild rattle but now I'm certain it's not. Does anyone have expirience in this area? I can't figure how the flywheel would touch anything at only one specific rpm.
I would look into having the throw out bearing checked. there is a vent hole on the bottom of the transmission where i pulled out metal shavings and clutch material.
BoxerBlock88 is offline   Reply With Quote
Old 11-12-2015, 09:47 PM   #24
Not every noise the car makes is the clutch and not ever car has had or will have throw out bearing issues (beyond the normal wear and tear they take).
humfrz (11-12-2015), NatedoggGt86 (11-14-2015)
Old 11-14-2015, 06:12 PM   #25
NatedoggGt86
Noise came back the next day. So I dug into it myself. Come to find that I have an aftermarket Borla uel header. Kind of a cool discovery however, from what I read the flex portions rattle on their earlier units. That was the cause of my noise. I'm not sure what the dealer did to silence it but thats it! So for anyone with a borla header and a rattle its the flex section. Does anyone know of a remedy other than replacement. I don't think Borla will warranty me since it was on the car before I bought it.
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 11:21 PM
Flywheel and Driveshaft Admired Engine, Exhaust, Transmission 37 06-09-2014 01:46 AM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Toda flywheel diss7 Engine, Exhaust, Transmission 1 08-04-2013 06:54 AM
