| Member's Car Journals Car journals by our members. |
Drives: Toyota GT86 euro version
Paulo86 GT86 black AT from France.
Hi everyone i'm paul from france and this is my Toyota GT86.
![]() ![]() Stock options : -Leather alcantara heated seats -Reverse backup radar -Rear tinted windows Exhaust : -TOMEI UEL header -TOMEI Overpipe -Fujitsubo double resonated catless Front pipe -PERRIN 2.5" resonated Cat-back wheels and chassis : -Eibach pro kit springs -Apex ARC-8 17x9 ET42 with Yokohama AD08R 245/40/17 -Goodridge braided lines, Ferodo ds2500 pads -Zenky 50mm black lug nuts lights : -Full LED interior kit LedPerf -OLM Vision+ LED licence plate light -bi-xenon OLM fog lights with H11B 6500k Morimoto kit -LedPerf reverse light -High mount INTEC JAPAN third stop light -Intec japan Tail lights -Intec japan Headlight -f1 style brake light in rear fog housing -third position light in rear fog housing -EXled usa footlight -Tapturn flasher -plastidip on stock turn signals -tinted side stock markers Interior : -Autoradio gps Pioneer avic-f60dab -Mtx thunderform for gt86 with Pioneer subwoofer champion series and Pioneer amp others : -shark Silk Blaze Helical antenna -R-magic wing made in japan -Grimspeed hood struts -Blitz Touch Brain with junction box, boost sensor, oil pressure sensor and diff temp sensor engine : internal : -CP Carrillo pistons 12.5:1 86.5mm -CP Carrillo pro H rods -King bearing XPG main bearings -King bearing XPG rod bearings -ARP block bolts -ARP head bolts -beehive GSC valve springs -TODA oil pump bolt ons: -Edelbrock supercharger. -Delicious tuning tune 98ron Flexfuel E85 -Kit Flexfuel Delicious tuning kit mk1+ DESS -D-box Delicious Tuning for Edelbrock -700cc DW fuel injectors -300c DW fuel pump -fuel injector Hard connectors Delicious Tuning -Cusco engine mounts -TODA idler and tensioner pulley -dual radiator JACKSON RACING -catch can pcv RADIUM -fumoto oil drain valve -Glowshift oil pressure adaptator Transmission: -LSD Cusco Rs 1.5 way -5.125 cusco final drive + 29 tooth flange -Cusco solid crush sleeve -Cusco differential silent block insert Last edited by Paulo86; 02-06-2018 at 09:21 AM. Reason: update pictures |
#2 |
#3 |
The pictures of my work on the euro version headlight
#4 |
[ame="https://www.youtube.com/watch?v=ILvOGUBKxDQ"]Toyota GT86 full led rear lights - YouTube[/ame]
Rear lights of my gt86
#5 |
Drives: 2015 BRZ
First I've seen these rims on a FT-86. I need to look up how much the weigh. I have been looking into the F14's and I may like the look of your Rota's better.
Great looking car man, bravo.
#6 |
Thanks man
![]() If i remember well those torque was second lightweight in this size, just behind the volk te37
#7 |
Drives: 2013 FR-S, 9300 miles, auto trans
Those tail lights look surprisingly at home on a black car!
Nice car! |
#8 |
#9 |
my custom job on toyota 86 stock headlight.
Many thank's to www.flyryde.com ! [ame="https://www.youtube.com/watch?v=cNIGVxIA-M0"]Toyota gt86 custom headlights - YouTube[/ame] |
#10 |
[ame="https://www.youtube.com/watch?v=VTiWi3PabRo"]Toyota gt86 custom headlight - YouTube[/ame]
#11 |
[ame="https://www.youtube.com/watch?v=JP9rRpAYfU4"]https://www.youtube.com/watch?v=JP9rRpAYfU4[/ame]
#12 |
Drives: Toyota GT86
Hi Paul
how are you since june ? I m happy to see you again. I will fallow all your modification.
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more... My Journal/Garage |
#13 | |
Great to read you here ! A little bit more modification will follow by the end of february. Edelbrock supercharger (with delicious tuning ron98 tune) Olm bi xenon fog with morimoto 5500k bulbs and xb35 ballast Grimmspeed hood dampers. Morimoto 5500k d4s bulbs for stock bi-xenon headlight to match the color of the fogs. After those thing i think my gt gonna be finished ! I will just need to enjoy driving it ^^ |
#14 |
Some updates :
Rear lights as changed a little bit (just the fog) I ordered 2 exled modules -1 tpc 3a module -1 brake light flasher module "mode 1" The tpc allow the whelen vertex hide a way to be fix bright red when on and allow the stop wire to make the fog wire turn off and put the flashing mod on when hitting the brakes. So it's possible with this setup to put one led bulb and make it work as fog and F1 stop. I also put a position led bulb in the fog. [ame="https://www.youtube.com/watch?v=jS440qTaz4w"]https://www.youtube.com/watch?v=jS440qTaz4w[/ame] Last edited by Paulo86; 01-08-2016 at 07:15 AM. Reason: video link |
| Black GT86 | DeaconRoc | Member's Car Journals | 66 | 12-29-2016 05:30 PM |
| UK to France & Spain | Kodename47 | EUROPE | 1 | 09-07-2014 09:25 AM |
| Fuel Help - France & Spain | Kodename47 | EUROPE | 3 | 08-13-2014 05:37 PM |
| My Black GT86 | Abdulla827 | Member's Car Journals | 0 | 01-21-2014 08:24 AM |
| Jeremy Clarkson and Richard Hammond Busted for Speeding in France: Lincenses Supsende | Whitigir | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-18-2013 12:59 PM |
