#15 |
Drives: 2014 Scion FRS
#16 |
Then hard for them to say it was because of a cracked housing. Get one if you can but if not don't sweat it .
| The Following User Says Thank You to Tcoat For This Useful Post: | WhiteFRS69 (10-22-2015) |
#17 |
Now my windows are working. Think I messed up somewhere with fuses.
I'm working in the dark. But everything seems fine Sent from my SM-N920T using Tapatalk |
#18 |
well did everything i could
got the windows working, just a bad fuse! gonna replace all the LED's on the car with the stock Bulbs, put the stock tail lights back on and call the dealer |
| The Following 2 Users Say Thank You to WhiteFRS69 For This Useful Post: | MisterSheep (10-23-2015), Tcoat (10-23-2015) |
#19 |
Killed Scion
Drives: 2013 FR-S Whiteout
In for updates. I'm personally considering aftermarket lights and I am afraid of something like this happening.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | Tcoat (10-23-2015) |
#20 |
#21 |
Update 1: dealership has no idea what is causing it. Trying to blame it on my stereo system. I'm fighting it!
Sent from my Galaxy Note 5 |
| The Following User Says Thank You to WhiteFRS69 For This Useful Post: | Tcoat (10-23-2015) |
#22 |
update 2:
they called again, part wont be here till tuesday, claim it will most likely be warrantied, not in the clear yet but its looking good i forgot to ask what part they are replacing |
#23 |
update:
dealership called yesterday, part is on backorder, they dont know when they will be getting it in i asked for a loaner.. they dont have any still asked them to cover the Fee for a Rental... have to wait till monday to see if they will cover it..... again!!!! i forgot to ask what part they are replacing! ill call monday and find out contacted the company i bought my Tail lights from to see if i could swap them out for a new pair, im afraid if i put the tail lights back on, i may be in this same situation Last edited by WhiteFRS69; 10-25-2015 at 04:09 PM. |
#24 |
got the car back
it was my Brake light Switch Part Number su00302490 could anyone tell me if that could have just been faulty? or caused from the tail lights ???? |
#25 |
Drives: SWP BRZ
I have no idea but OP, you also had LED bulbs for interior lights?
i remember my doom light did not work when door is opened after i switched to LED for while. it worked for while but one day, Boom! it did not work. BCU was damaged. ever since then, i don't use LEDs for interior. I only use LEDs on exterior light such as headlight,brake, license plate light, etc. I don't fully understand why LEDs causing it but didnt want to risk it again. anyway, glad you got the parts fixed under warranty! |
#26 | |
in the trunk and the dome light been on the car for almost 2 years, just weird im seeing this problem now now that ive had this problem, i may just stick to regular bulbs in the Interior |
#27 |
Drives: 2015 FRS Asphalt
I had a similar incident with LED bulbs.
I removed the dome LED, trunk & DRL bulbs before taking my car for it's first oil change. When I put them back in that's when my headlights would not go on. I had remembered reading another member had it's BCU fried because of the interior dome light. I can't remember specific details. I removed the LED dome & trunk bulbs and put the OEM bulbs back in. So far my headlights are fine now. Go figure huh.
#28 | |
im going to swap back in the stock Bulbs |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 169 | 08-20-2016 01:15 PM |
| SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light | AtlasMick | Exterior Parts (Aero, Lighting, Etc.) | 8 | 03-07-2015 06:51 PM |
| New VALENTI TAIL LIGHTS. yes TAILS | VakaGT | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-27-2015 03:59 PM |
| Valenti Fourth Brake Light With Stock Tails | mackdaddytran | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-20-2014 11:03 AM |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 187 | 05-15-2013 01:07 AM |
