#2745 |
Drives: 2015 BRZ
Apologies if this has been asked before, but I'd like to get as much experience on the stock suspension and wheel/tire setup before making any major modifications.
Plan is to take it autocrossing at least a few times a year and hopefully finally to a track event. Before that I'd like to get the car precisely aligned. I plan to purchase a set of SPC camber bolts for the front and SPC LCAs in the rear. The rest of the car will be stock. Car is mostly just a fun weekend car, that's also a part time commuter (car is too fun!), so some highway stability would be nice as well. Given my intended usage, any recommendations for alignment settings? |
#2746 | |
![]() Start with 0 toe front and 1/16th toe in rear. For camber start with -2.0 front and -1.75 rear. You could go with more camber, but this is a good fun commuter compromise. - Andrew |
#2747 | |
Drives: 2017 BRZ
Also unsure you'll see the recommended -2 front with just one bolt each side... |
#2748 | |
Drives: GT86-ACE-JRZ-RPF1-Essex
Is your answer still the same ? You would use 10k/12k spring rates with semi slick tires for a road going track day car ? What spring rates with more road friendly track tires ? (This one is for a friend) kind of 50% road 50% track car. I do like a slight understeer, but I m more into setting it with sway bar than springs.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#2749 | |
Drives: 2017 BRZ
9/10k are the softer rates for the SRC, if I remember the documentation and previous replies. I assume that holds for the CSG spec. |
| The Following User Says Thank You to cjd For This Useful Post: | CSG Mike (10-29-2015) |
#2750 | |
Even if I know what's neutral for you is maybe loose for me
#2751 | |
Drives: 2015 BRZ
From what I understand, I doubt I'll be able to get -2.0 in the front with the SPC bolts. Assuming I can't, should I request the alignment shop to max out the fronts and set the rears to ~.25 less? |
#2752 | |
Drives: 2017 BRZ
I'm not at all comfortable with the balance and it shows in my times, but while I am more comfortable with more understeer, I'm still faster this way. I imagine the comfort comes with time - I gained a lot of confidence this weekend, partly due to the slippery conditions. I wasn't fast Sunday really, but I was able to push the envelope of my previous comfort zone from the first run, not just after a few. I need seat time, and some alignment tweaks. tl:dr; I think balanced is balanced, and probably as fast as it can get. That probably is unrelated to your comfort zone. C |
#2753 | |
For sure the car is not crazy loose. Looking at CSG Mike steering wheel inputs, I see why he likes a slightly loose setup. He got a linear steering angle increase starting on center. Mine jump slightly then become linear, making use of the slight understeer I like and making it more neutral. Looking at that video, I guess I can move from slight oversteer to slight understeer with sway bars and damping. Edit: I'm concerned about corner entry oversteer. Middle and corner out are much less of a concern.
#2754 | |
Drives: 2017 BRZ
I may yet tweak swaybars, but I can't imagine needing more roll resistance. It seems like the wrong place to tweak. But I'm a bench racer still when it comes to suspension, still learning what really happens vs what I think will happen. I suspect the softer rates may be more to your liking though... Assuming my thinking bears any resemblance to reality. ![]() I should add, this discussion is helpful to me too, forcing me to quantify and consider. Hopefully someone I trust more than me chimes in. |
#2755 | |
You can always fine tune with damper settings, tire pressures, tire stagger, braking techniques, corner entry style, and sway bars. The damper setup is designed to be extremely flexible and adaptable to virtually any (fast) driving style. 9k/10k will yield a more understeery setup, that again, can be fine tuned for the balance you prefer. |
#2756 | |
#2757 | |
Drives: 2017 BRZ
I also seem to have too much rear negative camber for the way I'm using the car - not too much front though, and its at -3.3. temps and wear tell so much, even without proper tools. I neglected to budget for analysis tools this year, somehow.I'd guess a little toe out in the back could cure the setup of understeer too. ![]() I still can't quite get over the fact my wife has no problem knitting on road tripa with these spring rates.
| The Following User Says Thank You to cjd For This Useful Post: | Ultramaroon (10-30-2015) |
#2758 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | cjd (10-30-2015) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
