Old 10-24-2015, 07:50 PM   #323
93Targa
Brown rice
93Targa's Avatar
Drives: 93' Supra TT, 13' FRS
Originally Posted by solidONE View Post
Those torque specs look a bit low. Particularly the strut to knuckle hardware torque. Were talking about 19mm and 17mm hardware. They can take much more torque than 59 ft lb.
Did a little bit of research and found that 59 ft-lb is accurate. Below from Toyota:
Link to full suspension torque specs: http://www.ft86club.com/forums/showthread.php?t=92592
93Targa is offline   Reply With Quote
The Following 3 Users Say Thank You to 93Targa For This Useful Post:
freerunner (01-04-2025), shellslinger (10-24-2015), solidONE (10-24-2015)
Old 10-24-2015, 08:09 PM   #324
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Ah okay.. he said "strut" so I got a little confused there. 114 ft lb for the 19mm strut mount bolts.
Although those 17mm bolts in there rear are plenty beefy to handle more than 59 ft. lbs.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
93Targa (10-24-2015), freerunner (01-04-2025)
Old 10-25-2015, 10:18 PM   #325
icybrzzz
Drives: 2015 Scion frz
From everything I'm reading this really seems like a good setup for the street. Thinking of picking up this setup come spring time.
Tein Flex Z coilovers
SPC Rear LCA
Megan Racing rear strut tower bar
Anyone on here running a similar setup to this? This is my DD so this is why I'm considering these coilovers. Good setup for the money it seems for what you get. Might do 1 or 2 track days next season realistically but this will be a DD street car.
icybrzzz is offline   Reply With Quote
Old 10-26-2015, 12:44 AM   #326
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
SPC Rear LCA
Same set up I have minus the rear strut bar, I have a cusco bar up front. Loving it all.
BDotG is offline   Reply With Quote
Old 10-26-2015, 03:33 PM   #327
CSG David
CSG David's Avatar
SPC Rear LCA
This is a very good DD setup.
Old 10-26-2015, 04:26 PM   #328
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
SPC Rear LCA
Skip the rear brace, put that towards a front one
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Trettiosjuan (10-29-2015)
Old 10-26-2015, 04:55 PM   #329
icybrzzz
Hmmm interesting. Why do you recommend the front versus the rear? I'm open to different setups. Won't be doing this till spring time anyways so lots of time to figure out a setup for my car.
Old 10-26-2015, 09:44 PM   #330
solidONE
solidONE's Avatar
Honestly, and I'm a huge proponent of chassis bracing, you really don't need front nor rear strut bars on this car (maybe front bars). Unless you are running r-comps or really sticky street tires along with really firm spring rates it's just extra weight and "bling." Don't get me wrong, I got nothing against blinging your car, but in terms of performance or feel the difference is negligible to none. The rear bar moreso than the front bar. Plus you aint going to see the rear bar often and it will take up cargo capacity.
Intent > Content
Old 10-26-2015, 09:49 PM   #331
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
You'd be hard pressed to feel a difference of a rear bar for DD duty. The front bar is arguably negligible also IMO.
The single greatest changes you're gonna be making with the coils and alignment will make the bars a wash. Again all IMO
Sent from my A0001 using Tapatalk
Old 10-26-2015, 09:59 PM   #332
icybrzzz
Alright, so other then getting my suspension and alignment sorted... What other suspension mods would you guys recommend for my street car? I really just want to be able to hug the corners with confidence.
Other mods to note that affect handling:
17x9 +35 RPF1 with 245-40-17 Michelin PSS
You think just the coilovers will be enough to satisfy my needs? Oh and I might be getting hanook RS-3's in the spring to replace the PSS.
Old 10-26-2015, 10:45 PM   #333
solidONE
solidONE's Avatar
^ Go do some track days and or autocross? The stock hardware is plenty good as is without mods. Though alignment really made a huge difference for myself.
Side note: I find it funny how ppl are scared to voice their opinions and experiences because of forum douche-trolls. It's okay, buh. Don't be scared of them. You are allowed to think for yourselves. lol
Intent > Content
Old 10-26-2015, 10:57 PM   #334
icybrzzz
That was my plan initially but now that I got new rims the wheel gap is starting to bother me. Was gonna go with a spring kit but from what I've read you are better off just getting coilovers.
Still a long way from spring so I may change my mind... I could just get the SPC rear LCA and front camber bolts to get my car aligned with stock suspension correct? Might go that route first and see what happens.
Old 10-27-2015, 01:11 AM   #335
solidONE
solidONE's Avatar
Those are all good choices. Alignment alone is good, springs with stock damper work well too, these teins are surprisingly good as well. It's all what you are willing or wanting to spend. I just wonder how well these dampers will work long term, a year or 2 years down the road and if durability will be an issue especially if you beat on them hard.
Intent > Content
Old 10-27-2015, 01:30 AM   #336
CSG Mike
CSG Mike's Avatar
I like the front strut tower brace with master cylinder brace. Mostly because of the MCB.
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
