#225 |
Drives: 1992 Nissan Skyline GTS-t Type-M
Had it tuned over the weekend. Making 295 @ 8.5psi
#226 |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#227 |
| The Following User Says Thank You to FyeaFRS For This Useful Post: | Cal3000 (11-14-2015) |
#228 |
Drives: BRZ Limited
I am running the 3.12 and making 7.5 peak boost... gotta be belt slip??? how do I know?
#229 |
#230 | |
Drives: Panda FR-S
Also, just check you hoses.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#231 | |
Drives: Panda FR-S
#232 | ||
Drives: BRZ Limited
also i have a catless exhaust system do you think the lack of back pressure would cause a low boost? Last edited by MattHoffman; 11-15-2015 at 11:56 PM. |
#233 |
Drives: 2013 FRS- Hot Lava
Can anyone with this kit verify how much vacuum at idle is normal? I am logging with an OFT and only seeing 9 inches roughly.
#234 |
I'll let you know this afternoon, I'm thinking like 20 on cold startup, then like 10-15. That's on an autometer mechanical vacuum/boost gauge and I think obd2/dash command was saying about the same.
Update: So the gauge was reading about 20 at idle after warm up and the obd2 was reading about half that. So I'd say the digital readout isn't that accurate. Last edited by FyeaFRS; 12-09-2015 at 08:56 AM. |
#235 |
Drives: Asphalt 2014 FRS
How many miles have you guys clocked on your kits? I found a pretty good deal on one from someone local but it has about 25k miles on it. Owner only put it through 2 track days and the rest were from DD'ing. Has anybody developed problems with that kind of mileage?
#236 | |
#237 |
Drives: Toyota GT86
36K km, except one belt change. Belt was OEM and has been replaced with a quality one. No tracking, only German autobahn and country roads. ;-)
Gesendet von meinem SM-G925F mit Tapatalk |
#238 |
Platinum Member
Drives: Toyota 86 Vortech SC
40,000kms over 2 years which includes 25 track days without any problems whatsoever.
Vortech rules!!
| STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 05:16 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 03:05 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 01:50 AM |
| Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 03:58 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 12:09 PM |
