Old 10-21-2015, 07:49 PM   #1
HKSpadez
Drives: Brz
Side Marker came out
Side marker came out cause of a car wash
any ideas what I could do if the clip is broken? For the time being I put a little bit of glue + tape to keep it on but going to remove it soon to take a look.
Anyone has any easy fixes for if the clip is broken? I'm hopeful it just came loose but I doubt it could come loose without the clip being broken.
anyone else deal with same issue?
Thanks,
HK
HKSpadez is offline   Reply With Quote
Old 10-23-2015, 10:40 PM   #2
Greazly
Greazly's Avatar
Drives: brz limited sterling silver 14
I had a driver side side marker that kept coming loose. Finally end up just using a double side tape.
Sent from my D6603 using Tapatalk
Greazly is offline   Reply With Quote
Old 10-24-2015, 12:22 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks,
HK
Honestly, the clips are so flimsy and pop out, but if you can get epoxy to reinstall them on the sidemarker you can replace them with these:
http://www.fteightysix.com/appearanc...er-clips-pair/
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Bramick (10-25-2015)
Old 10-24-2015, 03:49 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Time for clear ones!
Old 10-25-2015, 05:40 AM   #5
HKSpadez
Drives: Brz
thanks for the heads up. i might try that
haha but yeah. it may be time for clear ones XD
Old 10-25-2015, 06:33 PM   #6
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Mine are a bit loose (or something) but the clips are still there, I just added some double-sided tape which hope keeps them firmly in place.
02.ACCORD.DUDE is offline   Reply With Quote
Old 10-29-2015, 12:52 PM   #7
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
the clips suck on these.
Fill the hole for the clip w/ epoxy or super glue after you install the clip. That should keep the clip securely in the side marker housing. I think there's a place you can buy replacement clips if you lost yours.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 10-29-2015, 03:36 PM   #8
stevesnj
stevesnj's Avatar
Thanks,
HK
Can you see a letter on the clip? It's the metal clip that broke or the plastic the clip goes on?
My 2016 Build thread
Old 10-29-2015, 04:01 PM   #9
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
I drilled a hole in mine and ziptied it to my bumper.
fker is not going anywhere
#TrackDayBro
Kuri is offline   Reply With Quote
Old 10-29-2015, 10:57 PM   #10
JB86'd
JB86'd's Avatar
Drives: JAWS
I recently had to replace my sidemarker bulbs and the clips on one side were dunzo. I used some clear silicone rubber on the contact points, shit isn't going anywhere, but is mellow enough to come apart if I need to take it off.
JB86'd is offline   Reply With Quote
Old 10-29-2015, 11:19 PM   #11
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
If the clip is broken, you can try replacing it; @fteightysix sells all three of the clips in individual pairs for jsut $5.00 USD - http://www.fteightysix.com/appearanc.../#.VjLTgberSUk. Otherwise, a few of the suggestions offered in this thread are a decent option - or just upgrading the clear side markers
Ammunition is offline   Reply With Quote
The Following User Says Thank You to Ammunition For This Useful Post:
MTeator (10-30-2015)
Old 10-30-2015, 06:13 PM   #12
02.ACCORD.DUDE
Car N00B
So I used double-sided tape on both markers - one marker is firmly in place (after 600 mi) the other one still gets loose... So for the cheapest easiest solution, I'd just go with the tape but take the time to do it right.
No real drawbacks to using it...
Old 10-30-2015, 08:21 PM   #13
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I have smoked sidemarkers. Transferred my clips over from OEM and they're still loose
YamahaR86 is offline   Reply With Quote
Old 10-31-2015, 12:16 PM   #14
stevesnj
stevesnj's Avatar
Just bend them out, releasing the clips sometimes bends them in with the effect of making the markers loose on reinstall. Actually take the clip off and heat it up then bend it. Apparently they tend to break when cold. Heating them then re attaching the clip to the marker should reduce the breakage chance.
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 09:56 PM
wtb oem side marker WATCHMEHEAL Want-To-Buy Requests 0 07-31-2014 12:37 AM
WTB side marker jupillam Want-To-Buy Requests 4 07-26-2014 12:32 AM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 05:29 AM
