Old 10-19-2015, 04:40 PM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Work Meister S1R 17" & 18" staggered
Couldn't decide between 17s and 18s. When I had 18s on, the fronts looked too big. When I had 17s on, the rears looked too small. Because the front is smaller, I run more profile to make up the difference. This is nice as it gives me for feel on the front, and the rears let go easier because less sidewall.
I still don't have the rears sitting right. These ones pictured will become drift spares. New ones on order that will sit better; 13mm less offset than pictured. But the fronts are right where I want them.
The height is perfect. Can JUST get my trolley jack under the front tow hook, so no planks. Fronts can be at full lock and the suspension can still compress without the top of the tyre clipping the fender lip. I tried the suspension lower, but it drives/drifts nicer at this height.
Manji is offline   Reply With Quote
The Following User Says Thank You to Manji For This Useful Post:
DuMa (10-21-2015)
Old 10-19-2015, 04:47 PM   #2
TRAKRAVN
Drives: 2015 Scion FRS - Raven
What are the wheel and tire specs that you have in the photos? Size, offset and disk please.
TRAKRAVN is offline   Reply With Quote
Old 10-19-2015, 05:19 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
iono but front is too small and rear is too big.
Old 10-19-2015, 05:22 PM   #4
Manji
Manji's Avatar
The fronts are 215/45/17 Bridgestone RE003 on 17x8.5 +16 A disk. I went with A disk as O disk didn't have enough clearance for the Essex/AP Sprint BBK.
The rears in the pictures are mostly 225/40/18 on 18x9 +35 O disk. After I got my rear alignment where I wanted it, I played round with slip on spacers (as I did when working out the front fitment) and saw I could've gone another 13mm less offset. So I've bought a pair of the same wheels in +22 offset, which havn't arrived yet. I'll then use the 4x +35 wheels for drift days.
I cross referenced the meaty tire thread quite a bit as well. I like how a couple of setups "sat". 265/35/18 on +38/35 offset wheels etc. But have no interest running tyres that wide on the front or the rear. My fronts sit the same as such a setup, but have far more inner clearance, so I get heaps of steering lock. I don't ever find the 215 lacking grip. In my eyes, I get the wide tyre look, without actually having to run wide tyres, or put up with the lack of lock / rubbing / weight / expense of running wide tyres.
My priorities were basically in this order
Retain stock body (no widebody)
Achieve same stance look as 265/35/18 setups
Retain as much front inner clearance as possible, for most steering lock
Setup height so that...
1. It doesn't bottom out on my test road
2. I can get the trolley jack under the front and back, without planks etc
TRAKRAVN (10-19-2015)
Old 10-20-2015, 09:09 PM   #5
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Looks baller Mike. Clever work - I was thinking you'd put some fat meats on there but no.
Congrats.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following User Says Thank You to Metabrz For This Useful Post:
Manji (10-20-2015)
Old 10-20-2015, 10:08 PM   #6
djliquidsteele
Drives: Scion FR-S
Kind of digging it. Ive always wondered what this might look like with like a forgestar F14. Would even like to see 18" front 19"rear.
djliquidsteele is offline   Reply With Quote
Work Meister S1R New Size 17" mike_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 01-12-2015 01:39 AM
WORK Emotion D9R and RAYS ZE40 -- 18" Staggered In Stock Sales RavSpec Wheels and Tires 16 11-12-2014 06:57 PM
WTB: 5x100 18" Work Meister S1's or SSR SP1's asphaltkyle Wheels and Tires 1 04-15-2014 10:48 PM
WORK Meister S1R - 17"/18"/19" Any Spec --- Winter Promotion - end 10/31/13 !!!!! RavSpec Wheels and Tires 1 10-29-2013 12:31 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
