Old 10-13-2015, 05:39 PM   #57
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Originally Posted by Scott@HKSUSA View Post
It's totally going to depend on how you drive it.
I can tell you that our car has basically been a supercharged test and demo. mule since day 1 of ownership. From that point until now literally, dozens of people have driven it with no regard for clutch longevity (everyone has beaten the crap out of our car). Dozens of dyno pulls, Michael Essa drove it 10/10 at 86Fest, Kevin Byrd drove it 10/10 in the V3 video, + employees, + customers... We're at ~20,000 miles now and the stock clutch doesn't slip under acceleration, but it doesn't have the initial bite it used to. We were just talking about installing a HKS LA Clutch in it today actually.
Thanks Scott. Thats exactly the answer I was looking for. Im not one to skimp on half assing things when I start a project. Its just more less a way for me to plan my build right now, as I have already determined I want to use all HKS products. Ill be curious to find out more about the HKS clutch after you install it from a daily driving aspect.
learnerspermit is offline   Reply With Quote
Old 10-13-2015, 08:40 PM   #58
Jackmayne
Drives: 15 frs/16 Corolla/ 10 challenger
Dang I just bought my frs and live in WV wished I would have known as this is the supercharger I'm saving for. No clue where Im going to buy it or if I'll attempt to install it myself. This only mods Ive ever installed are cai and tuners.
Jackmayne is offline   Reply With Quote
Old 10-14-2015, 03:58 AM   #59
kbye
kbye's Avatar
Drives: 2014 FR-S
Yes you can use the HKS Air intake duct without having to modify it with this kit. Using this part will actually save you from having to cut the end off the factory one.
This post says otherwise though? (although its the v2) http://www.ft86club.com/forums/showp...&postcount=155
kbye is offline   Reply With Quote
Old 10-14-2015, 09:25 PM   #60
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
Can I make more power than 310HP on e85? I'm really interested but I was hoping to make alittle bit over 350HP. Should I be going v2 instead? Assuming I have headers/intake/exhaust/injectors/fuelpump
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 10-14-2015, 09:46 PM   #61
vividracing
vividracing's Avatar
The V3 has a revised inlet compared to the V2. Perhaps that's why?
According to the press release from HKS, the V3 makes more power than the V1 and V2. Therefore, I would say the answer is no. However, according to the press release I have, the V3 on 900cc injectors made 319whp/234wtq on E85, so it's a touch above 310whp. Maybe Scott can clarify.
Oh, and for those asking for an underhood picture, I hope this tickles your fancy
-Seth
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
CxG (10-20-2015)
Old 10-14-2015, 10:29 PM   #62
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
anyone knows the exact size of V3 pulley?
if restrictor not exist in V3, I think it should be larger than 100mm
and then maybe mid boost is lower than V2.
Yobiwan is offline   Reply With Quote
Old 10-23-2015, 03:20 PM   #63
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Absolutely. The supplied HKS E85 cal. is good for 319 whp. The 7040L s/c has the potential to push enough air for ~450 hp at the crank. If we figure ~20% for average drivetrain loss, the 7040L will max out around 360 whp. Of course this will always vary a little based on: your mods, your tune, your dyno, your air, your fuel, your elevation, etc.
Very astute! 110mm
Scott@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Scott@HKSUSA For This Useful Post:
Yobiwan (10-23-2015)
Old 10-25-2015, 06:30 AM   #64
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Pics of the installed duct + V3 or never happend. Scott is notorious for false statements, 0 trust to words. Just like Putin Pls show me photo evidences!
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
kbye (10-26-2015)
Old 10-27-2015, 10:29 PM   #65
learnerspermit
Drives: C-17A
So if you have the HKS exhaust components without the cat installed and v3 with the flash editor, is it pre programmed not to throw the CEL for emissions? I know on my S2000 the Mugen ECU did no throw a CEL with a test pipe or lack of air pump.
Thanks
The Following User Says Thank You to learnerspermit For This Useful Post:
CxG (10-28-2015)
Old 10-29-2015, 04:18 PM   #66
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
HKS started racing & setting records with supercharged FA20s in 2013.
http://www.ft86club.com/?p=2613
For anyone attending 86Fest this weekend, I'll be in the HKS booth with two V3 equipped cars for everyone to check out. We'll have some other FA20 goodies on display, we'll be giving away HKS t-shirts, and we'll be conducting raffles for ride-alongs in the HKSUSA FR-S with Formula D driver Michael Essa.
Can you DM me with a price (incl shipping) to South Africa?
86 South Africa is offline   Reply With Quote
Old 10-29-2015, 04:41 PM   #67
CxG
Drives: Pearl White '13 ZN6
If someone went with the V3 and later down the road decided to use the HKS stroker kit could they upgrade pulleys and push more boost?
CxG is offline   Reply With Quote
Old 10-29-2015, 04:43 PM   #68
86 South Africa
Dyno charts (using supplied Flash Editor calibrations):
Note, ALL of the dyno results above reflect the installation of:
#70999-AT001 HKS Air Intake Scoop
#32016-AT023 HKS Hi-Power Spec-L exhaust
#33002-BT001 HKS Stainless Exhaust Manifold
#33004-BT002 HKS Stainless Front Pipe
#50003-M50HL HKS Super Fire Racing Spark Plugs.
I've had my heart set on the Edelbrock kit, then saw this V3 - and started wondering if this was a better option... until I saw this post.
Adding all these parts to make the additional power means it is no longer a like-for-like comparison, and the Edelbrock comes out on top (for me anyway) again. From what I can tell it runs cooler too.
I still want the HKS exhaust because I like the sound, the EL headers and the weight savings! Just struggling to justify the price of it - so I'm looking around at other options that might be just as good.
Old 10-29-2015, 04:55 PM   #69
kch
Senior Misanthrope
kch's Avatar
That's a question better suited for your professional tuner and not a bunch of forum jockeys.
The Following User Says Thank You to kch For This Useful Post:
CxG (10-30-2015)
Old 10-29-2015, 07:21 PM   #70
kbye
kbye's Avatar
Drives: 2014 FR-S
It could never be a fair comparison in the first place - roots type superchargers behave differently from centrifugal superchargers. Edelbrock will give you more low end torque whereas the HKS will yield more power in the top-end.
A more fair comparison against HKS would be JRSC/Kraftwerks, and for Edelbrock it would be against Cosworth/Harrop or even Sprintex in a way.
The Following User Says Thank You to kbye For This Useful Post:
CxG (10-30-2015)
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
