Old 10-14-2015, 02:13 PM   #3053
jvincent
jvincent's Avatar
If it's a bit loose, but you're still on throttle, I'd say go with 90
I was talking to a guy about my plans for the car next year and as I like to say, lap times are a function of equipment, skill, and balls.
There are a couple of places on my home track where the car is starting to feel unsettled as my speeds get higher. A really experienced driver would probably be fine, but since I have to drive my car home and there's nothing on the line I just keep it to a speed I'm comfortable at.
That said, I'm running stock suspension with camber bolts on Hankook V12s, so a little loose is not exactly unexpected. Getting use to that feeling at a relatively lower speed compared is, in my mind, a good thing.
I'm planning some mild suspension upgrades for next season so hopefully the car will feel that much more stable and I should get a little faster. At which points the V12s will be worn out.
Old 10-14-2015, 02:58 PM   #3054
CSG Mike
CSG Mike's Avatar
Absolutely that! Too many people have it in their minds that their cars need to be fully decked out before they can even set foot on the track.
Rather than getting a suspension upgrade, I would recommend you upgrade tires first, so that you can 1. get a little more grip but 2. get more quality lap times within each session. Most of the tires in the 200TW range have much more heat tolerance, allowing you to run for longer without having your tires overheat on you.
Old 10-14-2015, 04:13 PM   #3055
jvincent
jvincent's Avatar
@CSG Mike , I hadn't thought of that aspect.
One other variable, I DD my car all year, including the winter, so it sees a fair amount of pot-hole pounding not to mention the insane construction that we've in my neck of the woods since I've had the car.
By next spring I'll be pretty close to 100K km, so my guess is that I might be approaching a good time to change out the suspension anyway. Thoughts?
Old 10-14-2015, 05:29 PM   #3056
CSG Mike
CSG Mike's Avatar
It's difficult to say; everyone's experience with the dampers varies. If the car starts becoming *unpredictable*, it's time to change out the suspension.
Old 10-14-2015, 06:30 PM   #3057
jvincent
jvincent's Avatar
Thanks for the input.
Old 10-16-2015, 03:06 PM   #3058
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Looking for some input on tire selection next year. I was thinking of getting RS3s but I'm concerned that they may be too much tire for my skill level and maybe I should look at something else if you have any suggestions.
This was my first year ever doing any sort of high performance driving so I spent the year on a bone stock car including the Primacy's. I did 4 track days and 10 autocross throughout the season plus daily driving an average of 4kms/day and I feel like I was just starting to push myself to the limits of the tires when the season ended. The tires were completely wore out after the 9th autocross event and I borrowed a set from a friend for my last event.
I expect to do about the same amount and type of driving next year. The car will remain stock next year except that I've got a set of HKS Hipermax 4 GT coilovers that will go on the car next year but I'm curious if you have any opinions on what tires I should look at given my skill level and amount of driving I do. I'd prefer something that will get me through the entire season.
Lynxis is offline   Reply With Quote
Old 10-16-2015, 03:09 PM   #3059
Pat
Pat's Avatar
Drives: 2023 BRZ
Were you getting the most out of the stock tires by the last event?
Old 10-16-2015, 03:25 PM   #3060
Lynxis
Lynxis's Avatar
It's hard for me to say given my lack of experience but I do feel like I was starting to push the limits of grip on the Primacy's during my last 2 events. Autocross event 9 was the first event where I ever wished I had a bit more grip.
Old 10-16-2015, 03:56 PM   #3061
CSG Mike
CSG Mike's Avatar
I think with that amount of seat time, you'd be okay on the RS3. You may want an easier tire to drive, like the AD08R though.
Old 10-16-2015, 04:33 PM   #3062
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
@Lynxis I was in a very similar boat in January of last year, felt like I could still learn more on the Primacy but felt that I was due for new tires after 30k miles and a handful of events. Ended up buying some ZII SS in OEM size and while they certainly added to the ceiling and I definitely underperformed the tires for awhile they are definitely not 'too much tire' for the car. Once you trust them and find the edges of grip you can certainly explore the limits comfortably, they communicate rather well and once you find a suitable air pressure the consistency throughout a session is nice.
Last I checked ZII and RS3 were both cheaper than the Primacy in OEM size, while it may band-aid your bad habits for awhile you'll get used to them and start learning again soon enough imo.
I'd say either jump up to good street tires like you planned or pick up a set of tires someone is trying to get rid of locally to get some cheap education out of 'em (shipping costs probably not worth it though):
http://www.ft86club.com/forums/showthread.php?t=96248
http://www.ft86club.com/forums/showthread.php?t=96115
http://www.ft86club.com/forums/showthread.php?t=95623
Burn the tires up and sell the wheels to a guy who wants 'em for his Prius or TC.
Edit: @CSGMike AD08R is an 'easier' tire to drive than RS3? I assume the RS3 has a bit more durability to it which explains why you prefer it?
ineedyourdiddly
Old 10-16-2015, 04:38 PM   #3063
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
I have a question. Can I remove the airbags from my gutted street car / track toy and still be street legal ?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Old 10-16-2015, 05:04 PM   #3064
Lynxis
Lynxis's Avatar
I can answer this. The answer is no. It is illegal to remove or tamper with the vehicles standard safety equipment on a street going car.
Old 10-16-2015, 05:06 PM   #3065
strat61caster
Texas has safety inspection don't they?
According to this site airbags aren't on the inpection list but I can't determine how legitimate/comprehensive it is.
http://www.txdps.state.tx.us/RSD/VI/...nCriteria.aspx
ineedyourdiddly
Old 10-16-2015, 05:49 PM   #3066
CSG Mike
CSG Mike's Avatar
In most states, no.
Even 4/5/6 point harnesses are illegal for street use (and I would NOT recommend you ever do so.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
