#3025 | |
Drives: 2023 BRZ
#3026 |
Hi Mike, last weekend I ran the first Autox event with coil-overs on the FR-S. The car seemed to be more loose and I spun it in the last section. There is a 15 mm difference in the amount of left and right rear droop? I tried to adjust the right rear strut length (TEIN Street-Flex) to make them equal but the LCA is binding? Any ideas on what can cause this binding before I tear it all down. Thanks in advance, DP.
#3027 |
Drives: 2013 Firestorm FR-S
I did not. In retrospect it probably would have been a good idea to let one of the instructors do a few laps.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#3028 |
Drives: Fr-s
Are you sure you have the correct line through the kink? Did the instructor mention anything?
#3029 |
I wasn't perfect every time, it was my first track day afterall. But I kept pretty consistent, although with some early turn ins. By the end of the 1st day I had a pretty good feel for the line, and stayed consistent through the 2nd day for the most part. Even on the times I got the line pretty much perfect it couldn't take any more speed. The instructors all said I had a good consistent line, despite the occasional early turn ins. But anytime I tried to increase entry speed to the kink, the car just didn't feel right.
#3030 | |
My guess is that you're just at the limit of your current setup; getting faster from here means learning to throttle steer the car and getting comfortable with the rear being loose. |
#3031 | |
Do you have aftermarket LCAs? Pics of your setup? |
#3032 | |
I'd be surprised if I was already hitting the limits of my setup. I know I've got a lot to learn still. I also found it curious that I'd hit the limits of the car before my buddy did on the stock tires. He's also in a BRZ with ST coilovers though, so perhaps that had something to do with him being able to hit higher speeds through the kink. I know the stock spring rates are tuned to give the car a more loose rear end, and dropping all the weight with the muffler delete and trunk junk (spare, jack, and tools) probably doesn't help that any. That's an additional 54lbs out of the rear. Perhaps it's time to look for a suspension setup that would give the car more neutral handling.
#3033 | |
Drives: '13 FRS - STX
Sorry, I just find it hard to believe that with significantly better grip (Rivals to Primacy's) you're lagging that far behind in the same section, my money is on either there's more grip that you weren't using or your tires were worn out before you got there. Check out how much tire noise CSG Mike gets on this session. Now I'm not advocating you drift every corner, only that there may be more grip than you think, I am working on stepping up to that limit as well, finding that limit is not easy. [ame="https://www.youtube.com/watch?v=WrMAudOAEF8"]Buttonwillow 13CW CSG spec Tein SRC testing with NorCal 86CUP - YouTube[/ame] I'm on stock springs/dampers as well and I've been fighting understeer understeer understeer, all oversteer has been driver induced (and a good chunk of understeer as well). Camber works wonders on this car and may be something your buddy also has a big advantage on you with coilovers, I'm up to running about -3.0 degrees camber autocrossing up front (no adjustment in the rear yet, @ ~-1.4 degrees) and I'll be trying more soon. |
#3034 |
#3035 | |
I plan to get a fresh set of tires on it for next year. I'll probably do my first track day next season and see how it feels with different tires. From there assess what to do next. I'm sure the majority of my problems are driver input. lol
#3036 | |
#3037 | |
What is the difference in cars? My car on stock tires is actually impressive if you are easy with the right foot, but I have a bunch of suspension work. As for the carousel, what letter were you aiming for when going under the sign? What gear were you in, 3rd or 4th? After snagging an instructor I was told to aim for the D, and then stay above the line from the pavement until you start turning deeper for the apex. His biggest piece of advise was smooth on the input and patience while waiting for the right time to turn in deeper for the apex cone. Here is me at Road America: |
#3038 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
