Old 10-12-2015, 03:01 PM   #393
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Gee_ View Post
Curious I want this rear diffuser also and am also using the type-80, What else did you do to make the type 80 fit?
We are going to work on a Tomei Type 80 "kit" that will be added at checkout for those that want these diffusers to fit the Type 80. I have FT-86 SpeedFactory's Type 80 here and will be working with @jdnguyen to get everything sorted out. Installation instructions, templates, etc will all be included.
Originally Posted by G-awesome View Post
Finally after drooling since the concept design...arrived yesterday and installed it today on a rainy Saturday. Fairly easy installation after watching the install ft86speedfactory vid. Fits perfectly with a TRD exhaust with the smallest spacer option and looks great! Attachment 122482Attachment 122483
I love how it fits and looks with the TRD exhaust! The flat bottom of the tips make it look like it was a match made to be.
VerusEric is offline
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
G-awesome (10-12-2015), Gee_ (10-19-2015), jdnguyen (10-12-2015)
Old 10-12-2015, 03:36 PM   #394
projectXTR
Drives: Sterling Silver BRZ
Originally Posted by Timmy_Jones View Post
Any more info on the center mount exhaust??
Apparently more info will be released along with their turbo kit somewhere early 2016.
projectXTR is offline
The Following User Says Thank You to projectXTR For This Useful Post:
Timmy_Jones (10-12-2015)
Old 10-17-2015, 09:02 PM   #395
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
It fits the RS 1.0
socal_48 is offline
The Following 5 Users Say Thank You to socal_48 For This Useful Post:
Crashdummy (11-17-2015), DAEMANO (10-18-2015), FT-86 SpeedFactory (10-19-2015), Slowmotion (12-10-2015), VerusEric (10-17-2015)
Old 10-21-2015, 04:58 PM   #396
rx3
Originally Posted by NotEric6 View Post
Alternate (tame) version should be completed this week potentially. I then need to open each box and check the quality before sending to FT-86 SpeedFactory. Bear with me, should be to them mid-late September . Pictures to come soon!!!
I also wanted to share some photos that have been shared on our facebook wall.
Jason Nguyen at Road America
On his way through Dallas he got rear ended. "A true test of strength. I'm very surprised how well my rear diffuser held up after being rear ended in Dallas, TX.
After the accident I continued my trip safely to Omaha, NE and even did a track day there with zero issues! Velox, I'll be in need of another one of these!"
"Perfect fit with Nur Spec Aero kit and Fujitsubo Authorize R Type S. Great product guys, very happy customer downunder." - GM Steely
I will continue to do my best to update with pictures that are sent our way. We greatly appreciate them!
Thanks,
Eric
While I do like the non-aggressive version of this diffuser and I'm impressed by its strength, one could also argue that it therefore could have been made out of thinner aluminum sheet metal and thus be lighter. (I hope you don't mind my criticism, but I just like any mods to be as light as possible).
rx3 is offline
Old 10-21-2015, 05:42 PM   #397
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
FT-86 SpeedFactory Diffuser by Velox - Complete Aero Solution
Do you have one of these to make that statement? They practically weigh nothing, the included toolset in your trunk weighs more than diffuser.
.ck
|| My Build Thread ||
ck-GT86 is offline
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
DAEMANO (10-21-2015), jdnguyen (10-21-2015)
Old 10-21-2015, 06:07 PM   #398
johan
Drives: '14 981CS, '99 NB1
.ck
Adding weight to the back of the car is actually better for handling anyways.
johan is offline
The Following User Says Thank You to johan For This Useful Post:
MisterSheep (04-13-2016)
Old 10-21-2015, 09:02 PM   #399
VerusEric
VerusEric's Avatar
Thanks for your thoughts, I appreciate it. The unit weighs somewhere around 7 lbs, which really isn't bad considering its size. If we went thinner, some would most certainly argue that it isn't strong enough or that it is flimsy.
We did get it quoted out of carbon fiber during prototyping and even a carbon unit would have only saved us 2.5 lbs, while increasing the pricing to double it is now, not including the $16,000 in tooling.
The thickness and thus strength of the unit is subjective to each person. One persons overbuilt, is someone else's under-built. We went with what we thought would satisfy the majority of consumers and I would like to think most have been satisfied with the unit(s) so far.
The Following 5 Users Say Thank You to VerusEric For This Useful Post:
ck-GT86 (10-22-2015), HATED1 (10-21-2015), johan (10-21-2015), R2RO (11-17-2015), rx3 (10-22-2015)
Old 10-22-2015, 05:08 AM   #400
rx3
True, but I don't drive around with that tool set (when it matters).
The diffusers still adds about the same weight than what the lightest legal cat-back does substract.
Glass filled epoxy laminate sheets could be a lighter, affordable alternative, but I'm not sure whether the heat radiation of the muffler would be a problem. (The guide vanes could be used to shape it, since this is not a material that can be formed cold as sheet metal can.)
I can see that most people would probably prefer a diffuser out of (thicker) aluminum sheet metal.
rx3 is offline
Old 10-27-2015, 05:05 PM   #401
VerusEric
VerusEric's Avatar
Just wanted to let everyone know the *aggressive* units are back in stock, so both styles should be in stock and available. As are the rear diff/suspension covers and the OEM exhaust cover . We are working on coming up with a Type 80 kit that will be added at checkout for those customers as well. I would expect something around the first of the year (hopeful thinking).
I've spent the past few weekends doing some further testing to continually prove our CFD does in fact translate to real world results. We have had some warranted skepticism of if the air is staying attached to the rear up-turned lip that has become a staple for our diffusers. Our CFD showed that it does stay attached but CFD is just a tool, a simulation that can deviate from real world results. This applies to wind tunnels as well, can't stress that real world results can deviate from wind tunnel testing as well!
So what did we come up with? We decided we could tuft test the diffuser on an open stretch of road. We are in the process of developing an educational video detailing what we found. Below is a preliminary picture of the diffuser with the tufts attached. This was actually a lot of fun, more fun than I was anticipating, but also quite time consuming.
Looking forward to posting the video in a few weeks when I find time to finish it up .
The Following 11 Users Say Thank You to VerusEric For This Useful Post:
Ammunition (10-27-2015), BatStig (11-01-2015), civicdrivr (10-28-2015), DAEMANO (11-18-2015), GSpeed (10-27-2015), jdnguyen (10-27-2015), johan (10-27-2015), Kostamojen (10-29-2015), SPCorBUST (10-27-2015), WRB5titch (10-27-2015), zerodark (10-28-2015)
Old 10-27-2015, 10:19 PM   #402
Funk
No-Club
Drives: Subaru Brz
i want that freaking exhaust lol
whens that releasing
Funk is offline
Old 10-27-2015, 10:21 PM   #403
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
I've been super busy with my job. Once I get some free time I'm going to help velox get the data they needed to help the rest of the community!
jdnguyen is offline
Old 10-27-2015, 10:59 PM   #404
cjd
cjd's Avatar
Drives: 2017 BRZ
Any chance the mount point at the swaybar could be moved ~6-8mm toward the rear of the car without much trouble? If so, the bolt could be swapped for a threaded rod and a nut for the swaybar mount (the thickness of which would determine how far back from current this would be mounted,0 and a second nut for the diffuser, making this one heck of a lot easier to take on/off the car.
Why would you do that? I would because it's not legal when I AutoX
cjd is offline
Old 10-28-2015, 12:29 PM   #405
VerusEric
VerusEric's Avatar
Yes, I could see this being done fairly easily. The entire diffuser would sit back that 6-8mm, but 1/4-5/16" really isn't that far back. I would then install the rivet nuts in the plastic behind the rear wheels that 1/4"-5/16" more rearward, those (2) points should line up great then. The rear middle most holes may have enough play to not need any modification at all to fit. If they do, I would slot that hole ever so slightly till it all bolts together.
Honestly, I see no issues with an install in this fashion .
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
cjd (10-28-2015), wparsons (11-18-2015)
Old 11-08-2015, 02:07 PM   #406
VerusEric
VerusEric's Avatar
Tuft testing video is now up. Please let us know if you have any questions/comments regarding it!
[ame="https://www.youtube.com/watch?v=rPgpuZeHvzY"]Velox Rear Diffuser FRS BRZ GT86 Tuft Test - YouTube[/ame]
This was a lot of fun but fairly time consuming. Glad we did it though.
The Following 7 Users Say Thank You to VerusEric For This Useful Post:
8R6 (11-17-2015), DAEMANO (11-18-2015), Fastbrew (11-22-2015), IceFyre13th (11-10-2015), Joe-G (11-23-2015), makinen (11-09-2015), Pin Flare (09-10-2016)
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 03:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 08:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 02:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 08:20 AM
