Old 02-26-2015, 01:00 AM   #1121
winsometang
Drives: Scion F-RS 2013 Asphalt MT
my crickets went away after 5k of driving the car... since then ive flashed to e85 tune via oft(ran only one tank), however flashing back to 91 brought the crickets back to my car ... note that i was cricket free for almost 25k miles. currently battling with crickets again at 33k
winsometang is offline   Reply With Quote
Old 02-26-2015, 06:40 AM   #1122
sledheadguy
Drives: 2014 FRS firestorm red (MT)
k dont beat me up here.. Im a new frs owner....come on here and all I here about is crickets...lol...fuck me...I am not going read this whole thread...... does anyone have a video of this.........amuse me please...
sledheadguy is offline   Reply With Quote
Old 02-26-2015, 07:21 AM   #1123
Originally Posted by Mikeez View Post
No sir, you got mad . Just admit I got you. I actually don't have this problem yet ahaha!
Nope not "mad" although people seem to read everything that is written on here as if the author was mad!
I knew immediately what you were up to as I have read many of your posts before and know you are not a fool!
I was more disappointed (still not mad) at Celadrielas for falling for it and giving serious reply number1,265,864,082 on the subject!
Old 03-03-2015, 10:33 PM   #1124
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
wait, so is there a fix now? its been 2 years...
nos145 is offline   Reply With Quote
Old 03-03-2015, 11:47 PM   #1125
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
http://help-me-my-ft86-is-chirping.com/
pushrod is offline   Reply With Quote
The Following 3 Users Say Thank You to pushrod For This Useful Post:
Asphalt TG (06-06-2015), Dadhawk (03-04-2015), swarb (03-03-2015)
Old 03-03-2015, 11:48 PM   #1126
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Nope, but you can move to Japan. You never hear cricket there.... Ok, I will see myself out.
Old 10-07-2015, 11:02 AM   #1127
Ginger Academy
Drives: 2015 FRS
Hey guys just wanted to post my experience. I have had the cricket noise since day 1 at 22 miles, I now have around 1,000 miles. It has had only 93 gas put in until a couple weeks ago, I drove it to empty and filled her up with 91 E/0 crickets went away after I burned through half a tank. Not wanting to continue to run on 91, I am back up to 93 with the crickets returning.
Ginger Academy is offline   Reply With Quote
Old 10-07-2015, 11:10 AM   #1128
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Is there any way to tell in the states if a certain kind of gas doesnt have any ethanol content in it? I've tried Shell's 91 and Chevron's 91 yet still get crickets. I have heard stories of people being successful with either or, but I see to have the queen cricket with her army still in the hood of the car.
Instagram: trevor.parque
Old 10-07-2015, 11:17 AM   #1129
ka-t_240
It is hit or miss. My car made all sorts fo noises when I got it. Had the pump replaced last summer. Prior to the pump replacement I started running E0 fuel, as some have said they have success with that. I ran E0 for 4-5 tanks after the replacment as well..... crickets came back in about 200 miles after the new pump install.
No alteration in noise based on when/where I fill up, almost always constant no matter how much Ethonal is in my fuel.
Likely.... this is related to the internal pump pressures and flow thru the pump. My dad works exclusivenly with high pressure fuel pumps(rebuilding and calibrating), when he heard the noise, he said it sounds like a pump with air in it on his test benches or when the pressures are too high.
ka-t_240 is offline   Reply With Quote
Old 10-07-2015, 12:27 PM   #1130
HunterGreene
Hail Magnet
HunterGreene's Avatar
Your dad isn't too far off. The TSB related to this actually mentions cavitation in the pump being the likely cause of the noise.
It has priests in it?
Old 10-07-2015, 12:55 PM   #1131
ka-t_240
Sweet, I assumed he was on the correct path. He rebuilds HPFP and injectors for diesels. Has been messign with the stuff for 20+ years. I haven't followed these threads as it seems there is no hope of a "proper" fix any time soon if it hasn't been corrected in ~ 4 years. I just pop in and see if there is any posts on new updates/ecu flashes/ect.
The Following User Says Thank You to ka-t_240 For This Useful Post:
HunterGreene (10-07-2015)
Old 11-27-2015, 01:15 AM   #1132
alchemis
Drives: JDM Toyota 86 GT limited
surprisingly..... JDM Toyota 86... my car... with millage of 17000KM, there are live crickets there... not as per what the rest claims it doesn't affect Japan vehicles...
fuel type.. Ron97 with additive bumping up to roughly ron98 or 99. because i bought the car used from Japan, it doesn't make sense to spend a few hundred USD on the pump to eliminate the noise... probably just drive around with it.
alchemis is offline   Reply With Quote
Old 11-27-2015, 03:06 AM   #1133
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That's not what people were doing, they were legitimately going to the dealer repeatedly after hearing about a new fix on the forums (bear in mind this was being done awhile back) and getting it done for free with the only cost being time without their car. Honestly, it's pretty damn obvious this pump won't be sourced from anywhere else let alone any more changes as it's a non detrimental issue. I suspect this "issue" (in quotes due to it not being an issue just people being stupid over a noise) won't be fixed till a major engine update of some sort....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
HunterGreene (12-02-2015)
Old 11-29-2015, 11:07 AM   #1134
alchemis
saw some of the members kept on going to dealers and kept changing the fuel pump whenever they got the sound.
but i do suspect brand of fuel does make difference... i was on ron95 bhp brand no such sound.. but this is the first time i'm filling up ron97 shell. and i got that noise...
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 01:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 11:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 10:57 PM
