Sam Strano
Old 10-05-2015, 03:36 PM   #3767
Biggins
Drives: Yes
Originally Posted by ryan t View Post
has anyone seen the kumho v720 run firsthand yet?
I want to try them, but the Bridgestone and BFGs are proven. The acura in STF made them work well at Nats, but it's a bit of an unknown.
Biggins is offline   Reply With Quote
Old 10-05-2015, 07:11 PM   #3768
RandyP
Drives: Asphalt FRS
Originally Posted by Mark99es View Post
Thanks Mike, I am going to take the plunge and try 245. I may wish that I didn't but only one way to find out!
I had a set and they are a fine tire. Fronts rubbed on TRD lowering springs for me until I added longer studs and a 1/4" spacer.
RandyP is offline   Reply With Quote
Old 10-05-2015, 10:40 PM   #3769
Wahoo5
Drives: '13 FR-S, '06 F430
Originally Posted by solort View Post
So what was the tire solution at Nationals? Was Dave on the 245/40 or 225/45 (or 235/45 on back for gearing)?
Dave was on 225/45s.
Wahoo5 is offline   Reply With Quote
The Following User Says Thank You to Wahoo5 For This Useful Post:
solort (10-06-2015)
Old 10-06-2015, 07:54 AM   #3770
Mark99es
Drives: 2013 Scion FRS
I got 42mm offset wheels hoping that will clear the spring. Fingers crossed! Dave said he was on the 225's. Its hard to argue that tire but I figured I would try them and see. I will kill a set of tires trying to learn the car anyways. haha
Mark99es is offline   Reply With Quote
Old 10-06-2015, 04:54 PM   #3771
Mark99es
Question for you guys. Can you run crash bolts in the front and if so where can you get them? I went to the parts department and it looks like they just offer one size.
Thanks!
Old 10-06-2015, 05:07 PM   #3772
SVLTE
Thanks!
Part #s are on the first page of this thread.
SVLTE is offline   Reply With Quote
Old 10-06-2015, 05:45 PM   #3773
Mark99es
Doh! Thank you!!! I get the newbie fail award!
Old 10-06-2015, 06:37 PM   #3774
Lonergt
Drives: '13 FR-S ultramarine
Bilstein B8's
This may or may not have been answered, but I wanted confirmation before ordering. I recently discovered a leaking front shock on the FRS and was looking at Koni vs Bilstein's for replacements. I have the TRD springs on the FRS, and was looking at the B8's designed for lowered springs. Are these C-stock compliant or are they illegal. Thanks
Lonergt is offline   Reply With Quote
Old 10-06-2015, 06:46 PM   #3775
simpleisbest
Senior Citizen
Drives: Scion FR-S
B6 would be the Street legal versions.
simpleisbest is offline   Reply With Quote
Old 10-06-2015, 07:37 PM   #3776
Lonergt
So, without getting into the really expensive set-ups Koni's are the way to go for the TRD springs or will the B6's work despite being designed for the stock springs.
Old 10-07-2015, 08:04 AM   #3777
solort
Drives: Series 10 FRS
Is the largest bar setup for CS the TRD rear (and sell the front) and the Whiteline 22mm adjustable (for good balance)?
solort is offline   Reply With Quote
Old 10-07-2015, 08:13 AM   #3778
Biggins
Drives: Yes
The car I drove recently had the Hotchkis 25mm front bar. It was pushier than what I have on my car now (19mm), but we were both pretty quick on a slalom/transition intensive course. I like my car pretty loose, so when I add the rear bar and springs, I'm going to at least try an event with the 19mm on the stiffer setting. I suspect I'll end up putting the TRD bar on the front after some testing. I don't think you will have any problems with a 22mm bar though.
Old 10-07-2015, 11:59 AM   #3779
ryan t
Drives: frs
try it and sell me the trd front bar!
ryan t is offline   Reply With Quote
Old 10-07-2015, 12:33 PM   #3780
simpleisbest
Senior Citizen
Drives: Scion FR-S
B6's will work fine, as they seem to be the preferred choice to pair with RCE springs, if I remember correctly.
Koni's are the go-to budget build shocks. Personally, I do not think they have enough rebound, but what do I know. At least you can get them revalved by ProParts for moar shock force.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
