Old 10-03-2015, 11:58 AM   #1
Cole
Not a troll
Cole's Avatar
Stock suspension
Ok, so the situation:
I'm currently on coils, but ideally would like to return to my stock suspension for the winter. I switched over the front pieces no problem, then got the rear disassembled without issue.
The trouble is, once I get onto the re assembly of the rear, I can't get the lca to bolt up. I can either attach it to the hub or the part by the diff, but not both. Is this due to my toe arms? Is there anyone who had been through the same process and has any tricks to getting this accomplished?
Cole is offline   Reply With Quote
Old 10-03-2015, 12:05 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Disconnect the sway bar from the other side so it can pivot up and out of the way. I'm guessing that's your problem. Barring that, post pictures of what's going on.
Old 10-03-2015, 12:15 PM   #3
Cole
Not a troll
Cole's Avatar
Has nothing to do with the sway bar. It's like the LCA is too long to go between the hub and the frame (?) connection point.
Old 10-03-2015, 12:32 PM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Whats a LCA?
Found it...derp lower control arm. (no coffee yet)
Tried moving wheel assembly to see if it moved?
Old 10-03-2015, 12:35 PM   #5
wparsons
wparsons's Avatar
That's impossible based on how the suspension works, unless you're blocking the wheel from changing camber angle. Tilt the bottom of the hub outwards and there will be plenty of room to get the LCA in.
flickr
Calum (10-03-2015)
Old 10-03-2015, 12:54 PM   #6
Cole
Not a troll
Cole's Avatar
I'll try and get some pictures, but a friend and I were trying to make it go yesterday with zero luck.
One of us was pulling on the hub, the other was trying to get the lca lined up to the bolting point. It just wouldn't go. I'm seriously confused at this point.
Could it have something to do with my toe arms?
Edit: ok. Got the LCA on now. However, can't get the oem struts in there.
Old 10-03-2015, 01:29 PM   #7
Cole
Not a troll
Cole's Avatar
This has been sorted. Spent 30 minutes on one corner and got the strut and lca bolted up. Not sure what I was doing wrong yesterday...
Old 10-03-2015, 06:25 PM   #8
wparsons
wparsons's Avatar
Next time you're trying to get the shock(s) in there, disconnect one sway bar end link. It'll make your life MUCH easier.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Cole (10-04-2015), D_Thissen (10-04-2015), Ultramaroon (10-05-2015)
Old 10-04-2015, 01:25 PM   #9
Cole
Not a troll
Cole's Avatar
I did have the sway bar links disconnected.
It was such a weird thing. It could have been due to frustration, or maybe the order I tried bolting it up in. I don't know, but it seemed absolutely impossible. Anyways, got it done, now just waiting on an alignment when I have the time. Have to remember to bring my camber bolts when I take it in.
Old 10-04-2015, 01:31 PM   #10
D_Thissen
D_Thissen's Avatar
Sometimes, the best solution is to call it a day, have a beer, then try again the next day lol.
The Following 4 Users Say Thank You to D_Thissen For This Useful Post:
8R6 (10-05-2015), chaoskaze (10-05-2015), Cole (10-04-2015), Ultramaroon (10-05-2015)
Old 10-04-2015, 01:48 PM   #11
Cole
Not a troll
Cole's Avatar
Too many beers during the first day may have been the problem haha.
The second attempt, I ended up really hurting my arm while undoing some bolts, so I was taking a bunch of breaks and just taking a good look at what was going on during the install. Funnily enough, I've done aftermarket coils and RLCAs on my car and a friend's car in my garage and both of those installs went off without a hitch. The whole going back to stock was the real problem and I don't even know why. Most likely due to rushing it and not taking my time to actually troubleshoot.
Old 10-04-2015, 09:53 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Sometimes it helps to have someone stand on the hub lol
Old 10-05-2015, 06:37 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Hahaha well said SIR!
FS Stock Suspension and stock exhaust Illinois Full_Throttle_86 Great Lakes 2 09-24-2015 11:44 AM
WTB stock rear tophats or complete stock suspension s13kid989 Want-To-Buy Requests 3 10-09-2014 08:11 AM
Mix & Match stock FR-S and stock BRZ suspension and/or springs Weasel Soup Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-08-2014 02:53 PM
Fs stock 86 suspension Carlie Australia Classifieds 0 03-28-2014 09:19 PM
FS: Stock FR-S Suspension Kai Uhl Brakes, Suspension, Chassis 4 08-20-2013 11:41 PM
