go_a_way1
Old 09-20-2015, 01:00 AM   #2927
Mr671grains
So, I received from JRSC on Monday - Thanks CSG for everything. Well started off just fine removal of the bumper, etc, but then went to remove the plastic idler pulley and well what do you know, a boat load of metal was embedded into the thread on the bolt. There was no binding really it just came out like it should. I examined the threaded hole of the alternator bracket and there really isnt anything left. I went ahead and tried to thread the bolt back in and it seats in somewhat but it will never tighten down fully, kinda just spins with effort. Go figure that this would happen on a Saturday evening.
Mr671grains is offline   Reply With Quote
Old 09-20-2015, 04:30 AM   #2928
CSG Mike
CSG Mike's Avatar
Sounds like it is stripped... you may need to drill it out and sleeve it =X
Old 09-22-2015, 04:32 PM   #2929
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
I am from Alaska, Does this SC have any issues with running in cold weather.
I don't plan on running it in the winter/snow/ice, but want to have a strong reliable SC for the majority of the months here in Alaska.
Also does anybody have a Jackson Supercharger Coupon. IF so, this would really help me jump the gun in getting the unit.
mixedjuice is offline   Reply With Quote
Old 09-22-2015, 05:16 PM   #2930
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Not entirely sure, but I believe there are a handful of folks front the Midwest on this thread who have similar harsh winter weather. If memory serves me right, there is at least on user with an e-tune (I wanna say delicious?) that needed modification on the tune to run better at lower temps.
Good luck with the coupon search, the kit is still in high demand and I don't think there's going to be discounts any time soon.
The Following User Says Thank You to BigFatFlip For This Useful Post:
mixedjuice (09-24-2015)
Old 09-22-2015, 06:05 PM   #2931
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I DD'd my FRS through the entire winter and had no problems with the CARB tune. Even parked it outside every night and it would start up and run every morning just like stock. My kit saw a lot of snow and road salt and never had any issues. I also didn't do any preventative maintenance or special care for it during the winter, just drove it normally.
Last I checked there is still a waiting list a few months long for these kits. You might get lucky trying to find one used, but I can guarantee you won't find a discount on a new kit.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 09-22-2015, 07:18 PM   #2932
CSG Mike
CSG Mike's Avatar
There are no coupons or discounts on the Jackson Racing supercharger. Any vendor selling the kit discounted is in direct violation of Jackson Racing policy.
The kit is good for -40F/-40C. If you're running a custom tune, and not the Jackson Racing Factory Tune, then you'll want to make sure your tuner is aware of your conditions.
Currently the lead time is about 3-4 weeks. It was down to about 2 weeks at one point but the demand went back up...
Old 09-22-2015, 08:15 PM   #2933
mixedjuice
Great, so you are saying IF i place my order today. It may not be shipped for a couple weeks or so...
Wow that is awesome that the demand is extremely high meaning a valued product
Old 09-22-2015, 08:27 PM   #2934
Porcupint
Drives: 13 GBS BRZ
Probably around the same time a lot of belts started getting chewed up.
Porcupint is offline   Reply With Quote
Old 09-22-2015, 09:16 PM   #2935
CSG Mike
CSG Mike's Avatar
Correct; kits are shipped in the order in which the orders are received
Old 09-22-2015, 11:14 PM   #2936
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
I have the Factory Tuned/CARB JRSC kit in stock.
Infamous Performance is offline   Reply With Quote
Old 09-23-2015, 11:03 PM   #2937
LS1M
Drives: 2015 BRZ
Does anyone know the exact requirements for the evap obd2 test? I've had the JRSC kit installed for a few hundred miles now, and it still says incomplete. I'm beginning to wonder if it has something to do with the ambient air temperature sensor. It always reads high now, over 90 degF, and I think I read somewhere that the evap test only occurs below that?
Thanks
-Mark
LS1M is offline   Reply With Quote
The Following User Says Thank You to LS1M For This Useful Post:
JDKane527 (09-25-2015)
Old 09-24-2015, 02:48 PM   #2938
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
JRSC Hose Routing
Hey All,
I rerouted my lines because of my Radium catch cans, so the oil reservoir is on the other side near the battery. Attached is a very rough drawing I made comparing the setups recommended by the install guide vs. how I routed the lines.
Does it matter which lines go in and out of the 10-row Setrab cooler?
Basically, the OUT line from the Rotrex dumps directly into the cooler, I cut the hose short since the location was so close. The oil cooler then pumps upwards to the relocated oil reservoir, which again, now resides next to the battery. From there, it feeds to through the oil filter to the IN on the Rotrex.
My concern is how short the line is coming from the OUT as compared to Jackson's recommendation, where the line takes a longer path before it hits the oil cooler.
Thanks!
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
CSG Mike (09-25-2015)
Old 09-24-2015, 07:40 PM   #2939
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
I'd like to see your placement of the cans. I've yet to install my 2nd because of the oil reservoir. I was considering relocating that vs the can.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 09-24-2015, 09:10 PM   #2940
Xuningshen
Drives: Subaru BRZ
^ there is a post somewhere that shows you how to cut the radium bracket so that they'll both fit next to the brake booster just fine. I did it myself with a hacksaw and it works great and holds them both well.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following User Says Thank You to Xuningshen For This Useful Post:
CxG (04-02-2018)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
