Old 09-16-2015, 05:15 PM   #1
pasternak
Drives: Asphalt FR-S
Weird: Can't unlock FR-S driver door from inside
So I'm ready to exit the car and the unlock button on the driver door won't do anything. I'm sitting there pressing it over and over - nothing. Driver side door is locked and I'm getting hot. So I unlock using the button on the key and it works fine.
This also happened once a year or so ago.
2013 FR-S - bone stock.
pasternak is offline   Reply With Quote
Old 09-16-2015, 05:20 PM   #2
Zed
Drives: 2013 Subaru BRZ Limited GBS
maybe a bad wire connection or bad switch on the door?
Zed is offline   Reply With Quote
Old 09-16-2015, 05:40 PM   #3
Zoik
Drives: 2013 black gt86
hapenned a couple times when i had my keyfob and the phone on the same pocket.
magnetic field dont like more intense magnetic field
Zoik is offline   Reply With Quote
Old 09-17-2015, 01:20 AM   #4
hmmmm.........that just happened to me the other day.
I restarted the engine and it then let me out. It hasn't happened since then.
Sometimes my right shoulder hurts for no reason ..... then it is OK ..... I just don't worry about things like that anymore.....
Old 09-17-2015, 01:38 AM   #5
You're the best.
humfrz (09-17-2015)
Old 09-17-2015, 01:54 AM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
take door apart, blow air to wires. Cross fingers.
Loose nut rolling around inside door? Mexibeetle Issues | Warranty | Recalls / TSB 36 01-18-2019 04:07 PM
Door Unlock Issue TONYpepperon1 Issues | Warranty | Recalls / TSB 20 01-05-2018 08:06 PM
Door handle lock/unlock issue. Skeneypoo Electronics | Audio | NAV | Infotainment 4 12-03-2014 05:55 PM
Red inside door handle grips how to install? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 03-24-2014 01:21 AM
Automatic Door Lock/Unlock - Do we have the option? RYU Electronics | Audio | NAV | Infotainment 17 10-04-2012 02:15 AM
